Question about Maytag Neptune MAH5500B Front Load Washer
The spin cycle is noisier than normal, It has been this way for a while but seems to be getting louder
  • Maytag Master
  • 43,501 Answers
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Posted on Sep 16, 2010
Admiral washer thumps after spin
What is the model number of your unit?
Nov 22, 2012 | Washing Machines
701 smart drive washing machine leaking but working no error
is the leaking water brown if so with it being noisier on spin it will prob be the drum bearing are on there way out
May 28, 2012 | Fisher and Paykel Washing Machines
I have a loud knocking sound coming from the back with every evolution during spin cycles. It is my girlfriends machine and I have looked at taking the back off but am not sure how it comes off and don't...
heatman101
Apr 17, 2011 | Samsung Washing Machines
My Hotpoint BWD129 washer/dryer has got noisier and noisier during the spin cycles. It is now so loud it is unbearable to be in the same room as it and it rattles anything off the worktop nearby. Any...
This is most likely the drum bearings failing.
Drum bearings normally last a long time (10 years or more isnt unusual), but quite often drum bearing failure is caused by a faulty drum shaft seal allowing a small amount of water through and in to the bearings. The bearings then start to rust and this accelertes how quickly they deteriorate.
Replacing a drum bearing requires well above average DIY skills, so unless you feel you can do it, can get hold of a tech manual, and can find a supplier for the bearings, it's time to get a quote from an engineer.
Nov 13, 2009 | Washing Machines
When my zanussi aquacycle 1200xc is on the fast spin cycle the spinning drum seems to be getting noisier of late.
Probably the main bearings are going, spin the drum by hand, there should be little or no noise at all, if it feels rough, or noisy, then bearings are failing.
Please rate my solution.
Thanks.
Oct 10, 2009 | Zanussi F1245W Front Load Washer
Noisy spin cycle
It would be noisier than normal if it was not level.
Best way to tell if it is noisier than normal is to spin the drum by hand, there should be little or no noise from it.
If it is noisy or rumbling, or feels rough, then I would suspect that the drum bearings are worn and noisy.
An hour to complete a wash cycle is not abnormal, and they do do several rinses.
Plz rate my solution.
Thanks.
Dec 26, 2008 | Bosch Nexxt 100 Series WFMC1001UC Front...
Loud spin cycle
OTHER THEN CHECKING THE WATER PUMP I THINK YOUR RIGHT THE BEARING ARE GOING,IT WILL WORK FINE TILL THEY LOCKUP THEN THE BELT WILL BURN OFF,BUT I WOULD CHECK THE WATER PUMP ALOT OF TIMES IT JUST THAT,LET ME KNOW -MIKE
Nov 03, 2008 | Frigidaire FTF530ES
Washing machine is louder then normal on the spin cycle.
This sounds like the rear bearing is going. After getting louder, the next problem is grease appearing on your clothes during the spin cycle. This is a very major repair.
Jan 10, 2008 | Kenmore 43042 Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
383 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
