Question about Dryers
Dryer runs but does not produce any heat - Dryers
  • Dryers Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Sep 16, 2010
Dryer runs takes too long too dry clothes
Start the dryer and let it run for about 5-7 minutes, do you feel any heat if you open the door? If your dryer is producing heat most likely you have a restriction/blocked vent.
Oct 01, 2014 | Kenmore Dryers
I have a Samsung dv220aew xaa dryer that does not produce heat. I've replaced the heating element, the thermistor, and the thermostats with the problem remaining, what could be the problem?
ARE U GETTING THE RIGHT AMOUNT OF VOLTAGE AT THE CONNECTION,? i VE SEEN IN SOME CASES WHERE THE MACHINE ONLY GETTING 120 AND WILL RUN BUT NOT CREATE MUCH HEAT? THE DRYER USES 120 TO RUN THE CYCLE BUT NEEDS A FULL 220 FOR THE HEAT CYCLE TO WORK, THUS IF UR MISSING VOLTAGE IT WILL NOT HEAT? ANOTHER CULPRIT COULD BE A BAD TIMER STUCK ON COOL DOWN OR FLUFF CYCLE AND WILL PRODUCE NO HEAT?
Sep 25, 2014 | Dryers
Dryer Works but does not produce heat
I would first check to see if 240 volts is coming into the machine. The motor runs on 120 the heater need 240. If that is fine remove the rear panel and check the 2 limits and heater on the right hand side for continuity. Here is my video:
Jan 09, 2014 | Whirlpool Dryers
Whirlpool dryer not producing heat
check the piolet light
Nov 16, 2011 | Dryers
My dryer has power and tumbles, but produced no heat (tested with vent tube off). I reset the circuit breaker and now it produces heat. What is up?
If your dryer is clogged up this will not produce heat inside the dryer but will produce heat to the vent tube. Try unclogging the Vent tube and see what happens.
Feb 18, 2011 | Dryers
Dryer produces heat, but clothes don't dry
Sounds like the vent has a lint build up inside of it. A moister sensor detects any lint build up and keeps the heat in check. The dryer will produce very little heat this was. Clean the entire venting tubing and it shall run better for you
Jul 08, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
Not enough heat is produced from the dryer
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 13, 2010 | Maytag Centennial 7.0 Cu. Ft. Super...
LG Dryer not producing heat
heatman101
May 03, 2010 | Dryers
Dryer produced no hot air
many parts in the dryer can cause this however the easiest to check is you house circuit breaker or fuse. a dryer needs 240v to run the heat and if one side (120v) blows it will still run but without heat
Feb 08, 2010 | Kenmore Dryers
No heat is produced when dryer is running. How
most likely the heating element is toast, remove and replace, inexpensive, second could be heat thermostat but unlikely
Aug 08, 2009 | Dryers
Dryers Logo
Top Dryers Experts
