Question about Olympus Stylus 7010 Digital Camera
The zoom is stuck zoomed all the way out. When i turn power on the logo and sound come on then shut right back off without closing lens
    Sergeant:
  • 420 Answers
Its a lens error.. u may oil the contacts.
Posted on Sep 16, 2010
  • firey_green_ Sep 16, 2010
    How do you oil the lens? I'm having the same problem with my camera
  • Kiran Anto Sep 17, 2010
    i mean not the lens lens is covered by a circular iron barrel and it comes out and in..
    so the oil around it so that it can come in and out without friction ...
My camera Cybershot DSC-W150 has a problem with zoom
Sounds like your lens might be stuck. Do not force it closed or pull it out for that might further damage parts that are an integral part of its sliding mechanism. http://www.teleplancamerarepair.com/Sony_Cyber-Shot_DSC-W150 can repair this for you and they also clean your camera as part of the repair.
if there were any parts you were not able to put together after you opened it , make sure to very carefully put those back to go along with your camera.
Jul 08, 2010 | Sony Cameras
My Casio Exilim 7.2 Megapixel camera is stuck on zoom.
ur zoom lens trrip is broken 1side dont use zoom inout strip cost 50$
Jun 18, 2009 | Casio EXILIM Digital Camera
Shuts off when i try to zoom.....
I was also having a similiar problem with my z1275 and tried the "vacuum" thing. BINGO! It worked, and I was about to send the camera back to Kodak for servicing. You saved me money.
What did I do?
I turned my vacuum on, stuck my lense into the vacuum tube, zoomed all they way IN and then turned the vacuum off. My camera now works perfectly.
Before using the vacuum, I was only able to zoom about 50% before the camera would turn off. Thanks for your help.
Jul 29, 2008 | Kodak EasyShare Z1275 Digital Camera
Camera doesn't turn on and zoom screen got stuck because camera shut off!
MY CAMERA IS HAVING TROUBLE TURNING ON. THE OTHER DAY I TOOK A PICTURE AND IT SHUT OFF IN THE MIDDLE OF IT WITH THE ZOOM LENS OUT. NOW WHEN I PRESS POWER IT SAYS RETRY POWER ON OR IT WONT DO ANYTHING AT ALL. THE BATTERY IS CHARGED ALSO BUT NOW I CANT USE IT AT ALL
HELP!!!!
WHAT DO I DO!!!
STACY
Jul 21, 2008 | Casio Exilim EX-S500 Digital Camera
Zoom error
worked on allot of fuji's. first detease, a gear is slipping in the lens retract assembly due to a crack or wear or jam
2nd guest .. zoom errors means its really stuck tight
the gears can be ordered and replaced and one more possibility is that the motor that drives the gear is bad
Also if dropped or zoom lens jammed hard... lens assembly needs total realignment or replacing..
May 23, 2008 | Fuji FinePix F460 Digital Camera
Broken Zoom on Fuji Finepix F470
Try turning the power on and gently pulling the lens outward as it powers up. This may force the gears to re-align themselves. Use "fingertip" pressure only. Don't force it excessively. Also try turning on, and then applying slight pressure to the front of the lens while you power it off. You can also try rotating the lens barrel segments while it powers up or shuts off. Sometimes either can get the lens back on track.
Jan 20, 2008 | Fuji FinePix F470 Digital Camera
Shuts off when I zoom or take photo
Sounds like zoom has sand in it, Or the camera may have taken a hit to the front of the len's, Lens has to be taken apart, Has to be done buy a camera repair shop/or factory. TC
Aug 25, 2007 | Fuji FinePix E500 Digital Camera
Camera is stuck on minimum zoom
Try to replace batteris and look as well for batteries right placement. Good luck!
Jul 15, 2007 | Olympus FE-140 Digital Camera
Lens Stuck Out/Will Not Go Back In
well u have a problem, and u will need to replace the mainboard. if it´s under warranty send it to the repair centre they will replace mainboard for free
Mar 01, 2007 | Olympus D-535 Zoom / C370 Zoom Digital...
Coolpix 8800 shuts down
Make sure to use good NiMH batteries. Another possiblity is a problem with the card. Borrow a card and see if it has any effect. check to see that the pins in the card slot are all aligned, none out of place. check that the card door and the battery door close firmly, with some pressure. The camera can shut down when it has a problem detecting that the doors are closed. When it does turn on, play with the zoom without taking pictures, zoom in and out, if during zoom the camera shuts down then you might have a lens problem, something is malfunctioning in the lens mechanism and the camera shuts down to prevent damage. Good luck
May 19, 2006 | Nikon Coolpix 8800 Digital Camera
Olympus Stylus 7010 Digital Camera Logo
365 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
