Question about Kenmore Elite 44723SS Commercial Refrigerator
Kenmore Elite 253.44723100 Commercial refridgerator will not get colder even after adjusting thermostat all the way up. Unplug for a while then plug back in will cool down better but wont stay cooler temperature.
  • 183 Answers
SOURCE: Kenmore Elite side-by-side (1999 model--don't have #)
Evaporator is probably overiced as a result od door not being completly closed at some time recently, turn off and defrost overnight with the doors open, turn on the next day and it should work ok within 24hrs. Regards Advisor
Posted on Aug 31, 2007
aborcass
  • 2651 Answers
SOURCE: wine cooler temperature control
toatlly normal operation, realize that the machine needs to shut off/ on to regualte temp, new electronic thermistors are sensitive enought to detect miute temp flux, i wouldnt be concerned about this
Posted on Feb 23, 2008
SOURCE: Kenmore Model # 596.735032.. Fridge is cool, Freezer is not freezing
After pulling the fridge away from the wall and removing the lower right hand panel I noticed that the compressor (big round black ball with copper tubing) was not turning on. I also noticed that there was a ticking or popping sound comming from it every couple of minutes or so. After doing some research online in numerouse forums I decided to try and replace the overheat relay that is attached to the compressor. It only took maybie five minutes at most to change it and the compressor is now working with nice cold air comming into the fridge and freezer. Hope this helps someone else with the same problem.
Posted on May 10, 2008
SOURCE: Kenmore Elite bottom freezer refridgerator
I just went through this with my refridgerator and actually posted one of the questions. Here is what I found ........
In the freezer compartment behind the panel there is an evaporator fan which pulls cold air from the freezer and pushes it up into the refrridgerator compartment. If the fan is not working it is one of three things.. 1) there is so much frost in the fan area the fan blade is stopped and cannot push the cold air into the refridgerator compartment or the air channel is blocked. 2) there is no electricity going to the fan (usually tied to the door switch of the refirdgerator compartment, and 3) the motor is dead and will have to be replaced.
Solution to #1 - defrost but there is another problem in the "frost-free" part of the system which must be addressed or the frost will return and it will happen again in the future.
Solution #2 - check to see there is power to the fan. (most are 110VAC but some are 100VDC. Use a meter and check)
Solution #3 - If there is power, the motor is dead. Replace the motor. Be aware that AC and DC motors are different and replace per manufacture's specifications.
Posted on Nov 23, 2008
codfish124
  • 36 Answers
SOURCE: kenmore elite 77573600
one of the switches are bad if you have a multimeter check them for resistance
Posted on Dec 12, 2008
Kenmore elite coldspot model 106.74219400 freezes in the fridge never gets above 5 or 10 degrees and it never shuts off.
there is a flap in the refrigerator side usually near or behind the light bulb the freezer side is thermostatically controlled with the compressor being controlled. On the refrigerator side the cold air comes from the freezer side. when this flap is open the refrigerator will cool continuously, Check the flap or the duct assembly
here is an illustration of the part
http://www.repairclinic.com/Kenmore-Refrigerator-Model-10674219400-ID-927868-Duct-Venting-Parts
Apr 14, 2013 | Kenmore Refrigerators
Refrigerator runs and will not shut off, keeps getting colder and colder no matter what setting I put it on?
I have the same problem. My 7 yrs old Beverage Air model MT27 got very cold even with temperature control set to almost off position. It froze all the water and pops in it. Somebody have the solution?
Oct 12, 2011 | Beverage-Air MT27 Beverage Cooler...
Looking for a manual for Kenmore Elite Refridgerator MFG 2005 Model #106.74219400
http://www.managemylife.com/mmh/owner_manuals/5877
/KENMORE-ELITE-Top-Mount-Refrigerator-L0408620
Apr 20, 2011 | Kenmore Top Freezer Refrigerator
Refridgerator is warm, freezer is freezing
Defrost problem. Most likely the defrost heater or defrost thermostat.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 02, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Commercial freezer (Randall) with a Ranco thermostat, not cooling
clean condenser? is evaporator free of ice? may need defrosting or low on freon. Tom
Jun 30, 2009 | Freezers
Refridgerator side of my refridgerator keeps freezing my food
The problem may be low gas or it may be the thermostat is set too low.  First, look at the possibility that you may have the food partly blocking an air channel which is where the very cold air is coming from..  Fridge side should read about 40 F after the door is closed for about an hour.  If colder, adjust.
Nov 15, 2008 | Refrigerators
Kenmore Elite refrigerator problem
Sounds like a defrost problem or a plugged drain... to get it to work temporary defrost the freezer. Unplug the refrigerator, open the door and get a blow dryer and warm up the freezer. wait until the water stop dripping out or about 12 to 24 hours and then you can plug it back in . it will work for 2 to 3 weeks. To unplug the drain.defrost the freezer .remove the back cover. Use a pipe cleaner to clear the drain. pour a few cups of hot water down the drain. The defrost systems is:
HEATER-DEFROST
THERMOSTAT-DEFROST
TIMER-DEFROST (or may have a ADC)
Start with the timer. (if it has a ADC it will not apply) It is just under the front kick plate. there is a knob you can turn it slowly.until it clicks off the compressor. then open the freezer and listen . You should hear the heater come on .. it will sizzle when it comes on ...
You will have to remove the back panel of the freezer to check the heater for and thermostat for continuity. Heater are the lease likely part to go bad... I always change thermostat and timers together.
Aug 31, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite washer Locked
remove bottom panel reach up from bottom to lock area pull the small tear shaped release to open door if water still in tub pump may be plugged to clean turn handle on pump to left and pull out trap and clean ..after dipping as much water out as possible
Jun 26, 2008 | Kenmore Elite 45986 Front Load Washer
-40 F Freezer
Change out the temperature controller ie thermostat with one that will go to -40 degrees. This will be very ******* the compressor and may even cause the comporessor to run continuously and that's not what they are designed to do.
Mar 26, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite 44723SS Commercial Refrigerator Logo
775 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
