Question about Maytag Dryers
The thermal fuse blew on my dryer so it will not start. if i jump the two white wires together it will start. the wireing diagram says it is not resetable. would that have blown because one of the thermostats quit as well or should i just replace the fuse.
  • Maytag Master
  • 43,501 Answers
Hi, When ever you are replacing one the other(s) should always be replaced...so yes replace everything while you are at it...
heatman101
Posted on Sep 16, 2010
Duet dryer wont start beeps and sensing lights up!
Its likely your thermal fuse is out.
Disconnect the power! Remove the lint filter screen. Remove the two screws from the bottom flange of the toe panel. Pull the toe panel out at the bottom, pull down, and remove the panel. Remove the screw from the lint duct bracket and remove the bracket. Remove the two screws from the lint duct and remove the duct.
Then you will see the white thermal fuse on your blower wheel housing. You can jump it with an alligator clip or take the wires off the thermal fuse and use electrical tape to tape them together to see if it comes on. DON'T LEAVE IT JUMPED TO RUN A CYCLE, order a new one.
Here is a the part.
Oct 20, 2012 | Whirlpool GEW9250 Electric Dryer
Dryer functions but no heat; only cool air
unplug dryer and gain axcess to back of dryer and remove back wall plate look at lint shute bulkhead housing their will be one thermostat with four wires and one white plastic fuse safely remove the wires off fuse and tape together for testing only ...... make sure cover with electrical tape now make sure wires dont touch anything meatal no plug in dryer and check for heat if dryer starts heating goahead and order new fuse and replace thermal fuse ,,, and clean dryer venting and check for any kinks in vent pipe ........ if that test didnt produce any heat replace heating element its in aluminum duct on right side of the back of dryer ...... their is also a high limit tstat on the upper left side of this duct you can jump this out for testing only and check for heat aswell donot operate dryer with these jumped out except for testing theses are safety precautionary thermostats,,,
Jan 28, 2011 | Whirlpool LER4634J Electric Dryer
I have a kenmore dryermofel 110.62212101 and the other day i put a load of was in and set timer closed door and pressed start button and nothing happened. i have since checked all plug connections and the...
This is a common problem caused by the thermal fuse blown. The thermal fuse is wired in series with the motor and will cause the motor not running if it blows. It is located on the blower housing at the rear of the dryer. Remove the rear panel to access the thermal fuse.
Once the rear panel is off, refer to the diagram and locate the thermal fuse on the blower housing. Disconnect the thermal fuse wires and tape them together or jump a wire between them. Insulate them properly then plug the dryer in and start the dryer.
The thermal fuse (part number 3392519) is indeed blown and needs to be replaced including the cycling thermostat, (part number 3387134) also on the blower housing if the dryer start starts and works fine with the thermal fuse bypassed. Do not use the dryer with the thermal fuse bypassed due to fire hazards.
Feel free to update us about the result and development of the troubleshooting. Let us know of you need further assistance regarding the issue with your dryer. Rate the solution if you find it helpful.
Sep 22, 2010 | Dryers
I press start and it won't start. It sounds like a clock ticking
The usual cause of this problem is a blown thermal fuse which is located on the blower housing. It is wired in series with the motor and the dryer will definitely not start if the thermal fuse is blown. Disconnect power to the dryer then remove the rear access panel by removing the screws securing it to the cabinet.
Once the access panel is removed, look for the thermal fuse on the blower housing as shown.
Bypass the thermal fuse by taping together the wires connected to its terminals or jumping a wire between the wires then plug in and start the dryer. The thermal fuse (part number 3392519) is indeed blown and needs to be replaced together with the cycling thermostat (part number 3387134) if the the starts with the thermal fuse bypassed.
Simply unscrew both parts then screw the new parts in place. It's better not to disconnect the wires yet until the new parts are secured then connect the wires to where it should be connected on the newly installed parts. This avoids messing up the wires upon reconnection.
Do not use the dryer with the thermal fuse bypassed to avoid incurring further damage to other components and due to fire hazard reasons.
Aug 30, 2010 | Whirlpool LER4634J Electric Dryer
My Whirlpool dryer(supreme) does not start. The timer switch, door switch, start switch can all be heard to electronically switch on and off when I turn the timer around and open and close the door....
the thermal fuse may be faulty. Remove the outer back of the dryer. the thermal fuse is located on the blower assy with 2 wires connected to it. It is white plastic. connect the wires together, then try to start the unit again. If the unit starts, clean the exhaust duct after replacing the thermal fuse.
Jul 20, 2010 | Whirlpool LEQ8000JQ Electric Dryer
Dyer will turn on there is power at the source. When start is push nothing happen
Pull out the dryer and unplug . Remove the back cabinet panel , and on the blower housing , you'll see a 1" long white piece ( thermal fuse ) . The part number for this piece is 3392519 . You can jump these 2 wire together and start the dryer , to verify this is the problem .
Apr 18, 2010 | Estate EED4300SQ Dryer
Dryer won't run.kenmore 80 series
If you have voltage go to the door switch 1st. Make sure there is a clicking when you push the switch manually. If there is remove back panel and you will see a white plastic connetion with 2 wires, this is a safety thermal,(fuse). If you don't have a meter then jump these 2 wires together making sure not touch the cabinet then plug unit in and see if it will start.
Jan 27, 2010 | Kenmore Dryers
Kenmore dryer model 64602 wont turn on???
Check the thermal fuse on the rear of the dryer.
Remove the rear panel. The thermal fuse is 1 and 1/2 inches long by 1/2 inch wide. White in color and located just left of the dryer exhaust vent. 2 purple wires. Jump the wires together and start the dryer. If it runs, replace the thermal fuse.
May 25, 2009 | Kenmore 73952 Gas Dryer
Will not start,door and wall plug in place in the past it went when i switched the switch in hthe fuse panel, but not this time. is there a reset on the dryer?
NO RESET ON THE DRYER,BUT SOUNDS LIKE YOU MAY HAVE A PROBLEM IN YOUR FUSE BOX. IF YOU HAVE A VOLT METER, CHECK FOR 240VOLTS AT THE DRYER OUTLET. IF YOU HAVE 240VOLTS, THERE ARE A FEW ITEMS THAT WILL KEEP THE DRYER FROM RUNNING.
MOST COMMON FAILURE IS THE THERMAL FUSE LOCATED BEHIND THE BACK PANEL DOWN NEAR THE EXHAUST DUCT. IT USUALLY IS WHITE WITH TWO WIRES ATTACHED TO IT. IF IT IS BAD YOU WILL MEASURE 120 VOLTS AT THE TWO TERMINALS OF THE FUSE. YOU CAN JUMPER THE TWO WIRES TOGETHER, BUT MAKE SURE YOU AND THE WIRES ARE ISOLATED FROM EACH OTHER AND GROUND.
IF IT IS BAD , THE DRYER WILL RUN WITH THE WIRES JUMPED AND THE START BUTTON PUSHED.
REPLACE THE THERMAL FUSE.
Apr 01, 2008 | Dryers
Dryer won't tumble
Check thermal fuse located behind rear panel mounted on dryer (depending on model of the dryer) duct. Fuse is the component with 2 blue wires and is white in color. Try jumping 2 wires together or OHM out fuse. Fuse being bad is a sign that either
a) Dryer vent is clogged ..... If dryer takes any longer than 1 60 min cycle to dry loads than the vent IS CLOGGED!!
b) Dryer thermostat (next to fuse with 4 wires 2lg red and 2sm)
is not cycling proper
c) some other electrical short causing element not to cycle proper
Check Temp of discharge air with thermometer
on High should cycle on somewhere around 120
and back off at no higher than 170 no less than 155
Jan 18, 2008 | Dryers
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
