Question about Remington MB-400 Beard Trimmer
I have the Remington MB-400 and need to replace the titanium blades because they got damaged when I dropped it. I can't seem to find replacement blades. Been to the Remington website and they don't seem to offer them. Where do I get them?
EwingElect
  • 276 Answers
SOURCE: Replacement blades?
I'm not at work so can't confirm if there's blacdes for the HC920 but the majority of Remington Hair Clippers do have replacement blades.
Go to http://www.remington-products.com/country/index.htm to slect your country.
Authorised Remington Service Centers can be found at http://www.remington-products.com/consumer/asd.htm
Posted on Apr 11, 2009
brector3
  • 1600 Answers
SOURCE: What is the procedure for replacing the batteries
There are three screws on the back of the shaver to be removed. One is easy to see. The second is visable when you extend the trimmer. The third is hard to get to and the trimmer must be disjointed at the top to get to it. Once all three screws are removed, you can remove the back cover. There are two batteries. To remove them you will need to unsnap and remove the long metal clip and then unsolder the wires connected to the batteries. There may also be a gummy substance holding a wire to the side of one of the batteries. You will need to use a razor blade to seperate it off along the side of the battery. Once the old batteries are removed, you can solder in new batteries and ten reassemble the shaver.
You will find batteries at shaveroutlet.com. See link below. You will need to order two.
http://shaveroutlet.com/shaver-battery-pack-for-most-shavers-p-211.html
If you are unable to do this repair yourself, shaveroutlet.com can do it for you. See link below.
http://shaveroutlet.com/professional-battery-replacement-for-most-models-p-374.html
Posted on Mar 17, 2010
brector3
  • 1600 Answers
SOURCE: my remington titanium r-950
You will find the correct type replacement batteries at shaveroutlet.com. See link below. You will need to order two
http://shaveroutlet.com/shaver-replacement-parts/batteries/shaver-battery-pack-for-most-shavers-p-211.html
Posted on Nov 04, 2010
brector3
  • 1600 Answers
SOURCE: I need a charger for Remington Titanium MB 200.
You will find a charger for model MB-200 at shaveroutlet.com. See link below
http://shaveroutlet.com/grooming/remington-charging-cord-adapter-for-mb-200.html
Posted on Nov 12, 2010
The shaver head stopped moving. Yet when I take the heads off the black pins are moving. Any Help
The heads are either damaged causing the blades to lock up or it is clogged up to the point that they can no longer turn. Inspect the outer combs for damage. If damage is visable, you will need to replacethem. You will find replacements for R-950 at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/remington-sp19-titanuim-microflex-replacement-head-set-p-222.html
If no damage is visable, take the blades out and thoroughly clean them. You can soak in rubbing alcohol to help break up any greasy build-up
May 17, 2011 | Remington Titanium Microflex R-950...
How often should i change razor blades
Remington suggests changing the blades every 12 months on model R5103. If replacements are needed, you will find at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/remington-spr-titanium-360-pivot-and-flex-replacement-heads-with-frame.html
Mar 02, 2011 | Remington R5130
Where can I find replacement screen and blades for model F4790Remington shaver in rochester,new york
You will not likely find these in local stores. You will find them at shaveroutlet.com. See link below<br /> <br /> <a href="http://shaveroutlet.com/remington-sp-290-foils-and-cutters-set.html">http://shaveroutlet.com/remington-sp-290-foils-and-cutters-set.html</a>
Aug 30, 2010 | Remington F4790 F4790 Pivot and Flex...
My Remington is charged but doesn't work.
Most likely, the heads are either damaged or are too clogged up to spin. First, try disassembling the blades and cleaning them out thoroughly. If this is not the problem, you may need to change the heads. Remington suggests changing the heads every 12 months. You will find these for model R-650s at shaveroutlet.com. See link below
http://shaveroutlet.com/remington-sp29-titanium-rotary-replacement-heads-p-383.html
Jul 07, 2010 | Remington R-650s Electric Shaver
Remington MB-400 Beard Trimmer Logo
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
SHARCNET-USA
SHARCNET-USA
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
