Question about Garden
Parts diagram for YANMAR 1500 TRACTOR 1975 thru 1979 for gears bearings seals axels ,seals ,pto,
2 Suggested Answers
  • 4 Answers
SOURCE: PTO switch shuts down tractor
if the pto bearing is locked up it will stop a motor dead this is a common problem. You will have to get a new clutch assemble. The other thing that it could be is the deck has a locked up spindle.
Posted on Aug 20, 2009
Diagram for VW sand rail rear hub axel
Hi. What rear axel type do you have? Is it a 1975 beetle hub?
May 05, 2014 | 1975 Volkswagen Beetle
Yanmar diesel fuel injector leaking
If you removed your injector lines, and then reattached them. You first off got air in the line and you will have to purge them. But, I believe that your injector gasket was probably the culprit and why it was leaking. It sounds like the injector was losing fuel pressure and the pump was unable the push enough fuel to all the cylinders when under load.
If it were me, I would go online to HoyteTractors.com they carry every part for your Yanmar tractor that you will ever need. They also have a tech department too. Since you already have air in your lines, you might as well replace the fuel filter and O-ring and injectors seals. You can also get a service manual from Hoyte for your specific tractor model. If your Yanmar (3000) is like mine, my fuel pump is on the "passenger side" of the tractor and it has a bleed valve on it. So after you replace your parts you can bleed the air out. They are very simple machines to work on. Just in case you didnt know, most Yanmar tractors are a direct cross to John Deere Tractor Models. Any John Deere tractor under 100hp is/was Mfg. by Yanmar for 30-40 yrs or so. Good Luck!!
Jun 10, 2012 | Garden
How to replace bearing in a 1991 chevy 1500 4x4 rear axel at driveshaft?
To replace pinon bearing you need to pull wheels and the brake drums off next pull cover off the back of the rear end (make sure you have a drain pan under rear end) next turn dive shaft till you see a small bolt remove bolt pull center pin out push axle in pull c clips out pull axels out remove four bolts holding ring and spider gears remove gears assembly next remove drive shaft remove bolt from pinon push pinon in remove seal and bearing
Jun 27, 2011 | 1991 Chevrolet K1500
My Cub cadet pto cluch bearing is froze up on my 2518 lawn tracto
A medium length extension (stuck through the grill), a swivel and an impact is all you need to remove the pulley with the frozen bearing. It's just a bolt, a washer, and a lock washer holding it on. You just need to remove the pulley to see if the bearing is stuck. Take the pulley to your local shop that can press bearings and you can be up and running for $20 dollars instead of $300. Here's a diagram I found on partstree:
http://www.partstree.com/parts/?lc=cub_cadet&mn=2518-48+Tractor&dn=0043700012
Apr 08, 2010 | Cub Cadet Street Sign- tractor lawn riding...
How to replace rear axle seals
if the seal (s) is leaking you may have a bad bearing... to change.. remove the rear end cover, reach in pull the c clip on left or rt side. pull the axel out the side, use bearing puller to pull the old bearing, install new replacement bearing seal, put in axel, replace clip, reinstall rear cover, sealing properly, fill with rear gear lube to level of fill hole. get a chiltons manual for pictures and more detailed help.
Mar 10, 2010 | 1987 Chevrolet Caprice
How to remove rear axel from ford crown victoria tne axel is loose and making noise leaking fluid i think it neds a new seal
do u mean the axle has "play" when u grab the tire and wiggle it up and down?? if it has play, then it propbably needs an AXLE SEAL AND AXLE BEARING.you will have to carefully inspect the axle itself where the bearing rides for any gouging or damage. THIS JOB requires a decent amount of mechanical skill. 1ST you need to remove the rear end COVER and drain out the gear oil into a drain pan.2ND remove the brake caliper and rotor . 3RD spin the" ring and pinion " around until u see a 5/16 bolt that passes thru from the pass. side to the drivers side. u have to remove this bolt. u will need to "hold "the gears from turning in order to break loose this bolt. 4TH remove this bolt and slide out the large metal ""PIN" that 'divides" the rear end in half. NOW CAREFULLY WITHOUT TURNING THE REAR END SPIDER GEARS,PUSH IN THE AXLE TOWARDS THE INSIDE SO U CAN REMOVE THE "C-CLIP" AT INNER END OF AXLE. now u can slide out axle and youll be able to replace seal and if needed axle bearing. let me know if u need more info.
Sep 05, 2009 | 2000 Ford Crown Victoria
Aug 19, 2009 | Oregon Scientific Electric PTO Clutch for...
Replace rear axel bearing on 4x4 5.3 Litre gas engine
Loosen differential cover and let oil drain. Remove cover, remove U lock from axel. Pull axel out. Remove bearing seal then bearing. Install new bearing, seal and reinstall axel. Reinstall U lock and new cover gasket. Fill with 75-90wt gear oil. Now I know that sound pretty straight forward. But there are some things to remember. The U lock can be difficult to remove sometimes. The most important thing is the seal, you will need to make sure it gets seated correctly and not torn when installing axel.
Jul 12, 2008 | 2000 GMC New Sierra 1500
Garden Logo
365 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
