Question about RCA Thomson Digital Cable Modem (DCM305R)
Lights flossing from right to left on sequence repeatedly and then automatically resetting
    Scholar:
  • 91 Answers
Hi there
With this kind of problem, its showing that the modem is not acting well. You don't want to keep on getting disconnected from you internet. Just call your internet provider and have them replace the modem because modems just don't reset by itself. Be aggressive when asking them to replace the modem . ^_^
Posted on Sep 16, 2010
Error code H4
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Toshiba studo120 H4 error code
May 06, 2015 | Toshiba e-Studio 161 Copier Copier
What is the sequence to reset kenmore dishwasher 665.16719000? The buttons from left to right are pots/pans, normal wash, water miser, china gentle, quick rinse, high temp, air dry, delay wash, start
Press "high temp wash, heated dry, High temp wash, heated dry, high temp wash, heated dry, high temp wash, heated dry, high temp wash"
All the lights will go solid at which point you press cancel to reset the board.
**NOTE** if you don't have a "heated dry" button, use the "air dry" or "energy saver dry" button instead.
Apr 03, 2014 | Kenmore 24 in. 16052 Built-in Dishwasher
WTW4850XQ spins for a few seconds, then quits
Place the unit in diagnostic to do this make sure machine is off turn control knob to the left at least 3 times to clear now turn knob 3 clicks to the right 1 left 1 right all lights should light up do this within 6 seconds if you don't get lights repeat process I do this everyday so be patience once all lights are lit turn to the right until done light is lit press start button you will now see lights flash in varying sequence the way to read this the lit fill/sense light is the f code, wash light =8, rinse =4, spin=2, done=l when fill/sense light is not lit this is the second halve of the code example F7E1 you would have fill/sense lit, rinse=4, spin=2,done=1 F7 code, non lit fill/sense done=1 okay you may have more than 1 code it will continue to read the same code until you turn the knob once to the right the control will hold up to 4 codes at a time once you find the codes we'll go from there
Feb 04, 2014 | Whirlpool Washing Machines
I HAVE A 2007 HARLEY DAVIDSON CLASSIC SOFTTAIL. SECURITY SYSTEM PROBLEM. I HAVE REPLACED BATTERY & KEY FOB STILL COMPUTER WILL NOT ALLOW ME ENTRY TO DISARM & WILL NOT CRANK. DID STEP BY STEP OWNER...
If you do not know the security code, you can reset it to your own choosing.
With the fob present, turn IGN switch:
IGNITION-OFF-IGNITION-OFF-IGNITION
Press LEFT turn signal switch 3 TIMES
Press RIGHT turn signal switch 1 TIME and release
Turn signals will flash 3 times. Current PIN will appear in odometer. The first digit will be flashing.
If changing PIN, enter first digit (a) of new PIN by pressing LEFT signal switch (a) time(s) i.e., for the number 1, press one time. for the number 5, press 5 times.
Press RIGHT signal switch 1 TIME and release.
the new digit (a) will replace the current in odometer window.
Enter second digit (b) with LEFT signal switch.
Repeat until PIN is set.
Once PIN is set (either new or old PIN), to disarm security system, DO NOT sit on seat, lift bike off kick stand, or anything else that will activate the security mode!
Turn IGN to IGNITION.
Quickly (within 2 seconds) hold BOTH turn signal switches until confirmation signal (KEY icon flashes at fast rate, in odometer window, a flashing "-" will be followed by 4 more dashes = "----")
Enter 1st digit (a) in PIN by pressing LEFT turn signal switch (a) times (i.e., 5 times for the number 5)
The 1st "-" will become the 1st digit (i.e., "5")
Press RIGHT switch signal 1 TIME.
The 1st digit is stored and the dash will flash.
Enter 2nd digit (b), and repeat sequence until done.
After the 5th digit is entered, the KEY icon stops blinking, and the system is disarmed.
The system will stay off until the IGN switch is turned off.
If at any time during disarming sequence an error is made, wait 2 minutes before trying again.
Feb 28, 2013 | 2007 Harley Davidson FXSTC Softail Custom
My C310a printer wont align
on the front panel press setup >> Tools >> Clean Cartridges
again press setup >> Tools >> Align Printer...
if it does not work then do a reset on the printer
and to do that Press BL/TL/BR/TL Buttons, in sequence
(BL: Bottom left, TL: Top left, BR: Bottom Right) >> Touch Support Menu >> Press Right arrow for Reset Menu and Touch OK >> Press Right arrow for Partial Reset and Touch OK >>
Wait for unit to Power Down/Turn Off >> Press Power button to turn the Printer On...
the printer would automatically align itself...
Hope this helps...
Oct 30, 2012 | HEWLETT-PACKARD C310a All-In-One InkJet...
All new lines, brake bleeding sequence for 90 chevy g20 van ,4.3 v6
start at right rear then left rear right front left front repeat until you get a good pedal,
May 10, 2012 | 1993 Chevrolet G20
I just replaced my ink on E238 laser printer and the yellow light is flashing. I have been on hold for 45 mins with you help line. Everything still prints but the light is flashing
  1. Enter the printer's Configuration Menu. To do this:
  2. Turn off the printer.
  3. Open the front cover
  4. Press and hold the Continue () button.
  5. With the front cover open and the Continue button pressed down, power on the printer.
  6. Hold the Continue button until all the lights cycle.
  7. When just the Error light (!) is displayed, close the front cover. The top four lights of the operator panel should come on, indicating that the printer is in configuration mode.
  8. Print the Configuration Settings page. To do this:
    • Press and hold the Continue () button until all of the lights flash. This page lists the functions within the Configuration Menu. The functions are the non·indented items listed along the left edge of the page (along the bottom as printed from printer). They are also unshaded.
      Save this page for possible later use.
  9. Reset the photoconductor page count as follows:
  10. Press and release the Cancel button () to move sequentially from one menu item to another. NOTE: If you get lost, you can press and hold the Cancel button to jump to home state (top four lights on).
  11. Press and release the Cancel button until the Toner Low () light is the only light left on.
  12. Press and hold the Continue button until all of the lights flash.
  13. Then release the button. When the Toner Low light is once again the only light left on, the photoconductor page count should be reset to zero.
  14. Return the printer to normal mode. To do this:
    • Power it off for five seconds and then turn it back on.
  15. Print a menu settings page. To do this:
    • When the Ready () light is on, press the Continue button once. The Ready light will begin flashing and one or two pages will print out.
  16. Check the photoconductor reading on the menu settings page. To do this:
  17. Look for a section labeled Cartridge Information and locate the word Photoconductor under that heading.
  18. Confirm that the photoconductor level reading is OK or close to 100%.
  19. If the photoconductor reading is low, try printing 10 - 20 pages.
  20. Print the menu settings page(s) again. Confirm that the photoconductor level reading is OK or close to 100%.
  21. If the photoconductor reading is still low, refer to the Configuration Settings page you printed in Step 2.
  22. Confirm that Reset Photoconductor Counter is listed on the page.
    Also confirm that the light sequence for the photoconductor counter is the Toner Low light.
    • If the light sequence is correct, try repeating this entire procedure again from the beginning to reset the counter once more.
    • If a different light sequence is listed for the photoconductor counter, repeat the procedure but this time, instead of stopping at the Toner Low light (Step 3.2), press the Cancel button until the operator panel shows the light sequence that corresponds to the one listed on the Configuration Settings page. Continue with the remainder of the procedure as before to reset the counter again.
  23. If the photoconductor reading is still low after the page reset procedure has been performed twice, the printer may require service.
May 04, 2011 | Lexmark E238 Laser Printer
I have just bought a new photoconducter unit and put it in the printer. Instructions talk about select, return buttons, menu buttons and exit buttons. My printer does not seem to have this. It only has the...
  3. Open the front cover, as shown below.
  4. Press and hold the Continue (pattlnk_1122005_1857-enus20682_continuebuttonicon_e230_en_us.gif) button.
    • Press and hold the Continue (pattlnk_1122005_1857-enus20682_continuebuttonicon_e230_en_us.gif) button until all of the lights flash. This page lists the functions within the Configuration Menu. The functions are the non·indented items listed along the left edge of the page (along the bottom as printed from printer). They are also unshaded.
  10. Press and release the Cancel button (pattlnk_1122005_1917-enus20682_cancelbuttonicon_e230_en_us.gif) to move sequentially from one menu item to another. NOTE: If you get lost, you can press and hold the Cancel button to jump to home state (top four lights on).
  11. Press and release the Cancel button until the Toner Low (pattlnk_1122005_215-enus20682_tonerlowbuttonicon_e230_en_us.gif) light is the only light left on.
    • When the Ready (pattlnk_1122005_218-enus20682_readylighticon_e230_en_us.gif) light is on, press the Continue button once. The Ready light will begin flashing and one or two pages will print out.
Jan 01, 2009 | Lexmark E238 Laser Printer
Error message H 4
Jul 08, 2008 | Xerox Office Equipment & Supplies
Sharp copier AR5316
H2 or 2H is related to a fuser under heat or overheat.
Try this first,
If this does not clear the problem the fuser will need replaced.
Feb 20, 2008 | Sharp AR-5316 Advanced Digital Imager...
RCA Thomson Digital Cable Modem (DCM305R) Logo
85 people viewed this question
Top RCA Computers & Internet Experts
Julie Endres
george  peters
george peters
Are you a RCA Computer and Internet Expert? Answer questions, earn points and help others
