Canon MP20DH cacluator. I need a manual or instructions on how to load the ribbon correctly and how do i feed the paper so that I can have a tape??
  • sheryl douglas Sep 16, 2010
    First of all it is not a fax machine. It is a calucator. Second, the web sites that I was given to go and get my information, says access denied and it is worthless to me. So I dont feel that I should have to pay for something that I can not use plus was the wrong product in the first place.
Here is the link for the Canon MP21DX which is very similar to the MP20DH. Click on the link below to download the owners manual:
http://usa.canon.com/cusa/support/consumer/calculators/desktop_printing/mp21dx#BrochuresAndManuals
Posted on Sep 16, 2010
    Guru:
  • 731 Answers
Hi
MP20DH manual from Canon is unavailable. Canon has upgraded this to MP21DX and the manual instructions are the same.
Please click the below links
Instruction manual
http://downloads.canon.com/cpr/software/calculator/MP21DX-(USA-GB).pdf
Full Brochure
http://downloads.canon.com/cpr/software/calculator/Full_Line_Calculator_Brochure_2007.pdf
Regards
Riztech
Typewriter repair manual
I just replaced a ribbon in a 3500 IBM wheelrider ribbon with the following product which is supposed to be combatible.
DataProducts Compatible Typewriter Ribbon
Dataproducts Lift Offf Tape Catridge
I had no problem istalling the tapers, forwarded the ribbon as instructed, but when I type no tryping appears on my paper.
Aug 22, 2014 | IBM Typewriter Wheelwriter III 3 with 2...
Can you tell me where to get a manual for a Canon MP20DH 2 color display calculator?
http://www.manualsonline.com/ex/product/headline/m/canon/d/calculator/p/MP20DH+III
Jun 26, 2014 | Canon MP20DH Electronic Calculator Missing...
CANON ADDING MACHINE model MP20DH III DOES NOT PRINT CORRECTLY
May need to change the ink in it. Staples has them pretty cheap.
Apr 16, 2014 | Office Equipment & Supplies
How do you load paper into a canon p23-dh v
For loading paper into canon p23-dh v is to cut a piece of index card to the length of 3 inches and to the width of the paper you want to load. Tape evenly to the end of the paper roll and put into the ****, pushing gently in and at the same time pressing the 'Feed" button. It will immediately feed since it is firmer than the Poat-it paper.
Apr 26, 2010 | Canon P23-DH Calculator
Have switch it on put paper in and new ink but its not typing on the paper
Check the ribbon first. Remove it and check that the ribbon is feeding properly (letters should be spaced evenly on the ribbon). Ensure the hammer is stiking the paper and that the correction(lift-off ) tape is not in front of the hammer.
Nov 03, 2009 | Office Equipment & Supplies
How to open to change ribbon on a Canon mp25dv
Remove the paper tape by pulling it back out of the calculator.
Feel along the back of the calculator right below where you insert the paper tape for a ridge. Gently lift up on this ridge and a plate will lift out of the machine exposing the ribbon.
Make a note to yourself as to how the old ribbon is in the machine before removing the old ribbon. Just gently lift straight up on both of the spools and the ribbon will lift out of the machie.
When you insert the new ribbon make sure that the ribbon is feeding off of the back side of both spools. You can use a small screwdriver or toothpick etc to position he new ribbon to keep the ink off of your fingers. Make sure the new ribbon feeds around the plates on both sides of the machine and it fits behind the roller that has all the numbers on it and that the red portion of the ribbon is on the bottom.
Take the plastic plate that you removed first and insert the tabs in the front underneath edge of the case on the front and gently push the back side of the plate straight down till it smaps into place.
Refeed the paper tape back into the machine and you are finished!
Hope this helps.
Apr 20, 2009 | Canon MP-25DV Calculator
Correction Tape
The correction tape which should be a yellow spool and the correction ribbon cartridge should be a yellow also, sometimes orange, first. The correction tape has to in front of the black correction ribbon. in othe words this is the order. Platen, paper, correction tape, correctable film ribbon, printwheel. Also make sure correction tape is dull side toward paper. Shinny side should face operator...
Aug 12, 2008 | Brother ML-100 Typewriter
Correction Tape
Two possibilities, one the correction tape is twisted and the wrong side is .facing the paper. The shinny side should be facing you, the dull side facing the paper. Second possibility you must make sure the ribbon is compatible with the correction tape. There are 2 types of ribbons. A correctable one (orange or yellow knob) and a multi strike (blue or purple knob on ribbon cartridge). The lift off correction tape (orange or yellow spools) only works with the correctable ribbon and the cover up correction tape (blue) works with the multistrike ribbon.
Jul 17, 2008 | Brother ML-100 Typewriter
Loading paper
The entry point is on the back bottom of the machine. Cut your paper into a shallow triangle w/a slight point in the middle. Guide it through the slot on the back, and then lift that point up so that it goes into an almost invisible opening with small silver metal tabs on either side. The paper will want to feed underneath the entire black plastic mechanism, but don't let it. As the instructions indicate, the paper does not actually feed "under the black plastic plate", but through it. After you manage to insert the point of your paper through the correct slot, make sure the entire edge of the paper actually enters so it is grabbed when you push "Feed."
Jun 17, 2008 | Canon P1-DHV Calculator
Correction tape problem IBM Selectric II
Take off the ribbon, just inside the rt. side frame of the printer is the mech. for L/O feeding. There is an arm that moves back and allows the feed to ****, that mech. is probably gummy, lube with some WD40 on both sides of the printer (the left side sets up correction lifting.
DickyO
May 19, 2008 | Lexmark Wheelwriter 15 Series II...
1,506 people viewed this question
jasbo
jasbo
