Question about Gateway E-2000 Deluxe PC Desktop
WHAT KIND OF RAM AND WHAT IT THE MOST IT WILL HOLD?
    President:
  • 623 Answers
The maximum memory for a Gateway E-2000 is 2048MB.
This machine has two slots and each one can hold 1024MB RAM max.
You can use unbuffered DDR PC2700, CL=2.5, NON-ECC, DDR333, 2.5V
Two examples are here and here.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Posted on Sep 16, 2010
How much memory will this model hold and what kind shoud I buy
One way to find out for sure how much RAM your computer can hold is to go to WWW.CRUCIAL.COM and run their SCAN MY COMPUTER feature.
This handy utility will scan your hardware configuration and tell you exactly how much RAM you currently have installed and what type it is.
It will also tell you how many RAM slots are fitted on your motherboard and what the maximum memory capacity is for that motherboard.
If your computer does have room to add more RAM, it will provide you with specific recommendations as to exactly what type and size of RAM stick to get to maximize the memory capacity and performance of your computer.
Thank you and good luck.
Apr 20, 2011 | Computers & Internet
How do I activate new ram?
There is no need to activate Ram. You need to make sure that you purchase the right kind of RAM for example you need to know if your motherboard is compatible with DDR or SD. Then you need to know it can hold up to how many GB.
Once you insert the ram in to the Slot and reboot the PC it will automatically detect.
use the link below to find which RAM your are using.
http://www.google.co.in/imgres?imgurl=http://ayumilove.files.wordpress.com/2009/10/ram-types.jpg&imgrefurl=http://qwickstep.com/search/types-of-computer-ram.html&h=300&w=680&sz=180&tbnid=rEm5C9POjIhLBM:&tbnh=61&tbnw=139&prev=/images%3Fq%3Ddifferent%2Btypes%2Bof%2Bram&zoom=1&q=different+types+of+ram&hl=en&usg=__fDNJGMz4ppWMGEFQRKBgMAwQVcA=&sa=X&ei=DoH-TLipK8TprAe0icXFCA&ved=0CCYQ9QEwBA
Dec 07, 2010 | Everex StepNote NC1500 Notebook
How do I get more RAM
You will have to do a little research, but it is worth the effort. You have to go to the dell website and look for your machine type. once you find it, you should be able to find what kind of ram it uses, and how much each stick is, and the max amount you can hold. Then, just order it from the Dell site, or, you can write down the specifications, and search for a cheaper version of ram with the specifications you wrote down. Please note, Ram thats sold by Dell has been tested and approved for use in Dell computers. Copy-cat ram may NOT work, or it may work just fine. If you arent going to save much money by getting the generic ram, then dont get it, and go with the tested good ram.
Jul 01, 2010 | Dell Dimension E510 PC Desktop
My desktop has intel 845gvsr board, n have a 256 mb ram installed on it. i want to upgrade it to 1gb what kind of ram should i go for
Each memory slot can hold DDR PC2700 or DDR PC3200 Non-ECC, Non-buffered RAM with a maximum of 1GB per slot.
You can refer to this site for more info on your RAM and motherboard.
http://www.crucial.com/store/listparts.aspx?model=D845GVSR
Thanks for using Fixya.
Feb 23, 2010 | Intel D845GVSR Motherboard
When i upgraded the memory to 2G of memory, the screen will not turn on.
Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot. If you have tried putting a single stick of 2 GB or RAM, it won't work.
Ensure you have purchased the proper kind of RAM. Also ensure the stick is seated securely and properly into the slot.
Good Luck,
NOLA Tech
Feb 05, 2010 | IBM ThinkPad R52: R52 P M 760(2.0GHz),...
I need RAM for an older Sony PCV computer. The model number on the computer states it's a PCV-470ODS. But NewEgg lists no such computer. They DO list a PCV-407. Are they the same? And what's the most...
My suggestion would be to go to www.crucial.com and run their System Scan.
It works very well, and will tell you what kind it takes, how much you have now, and how much it will hold.
Oct 29, 2009 | Sony VAIO Digital Studio PCV-RX660 PC...
What is the hidhest ram i can use on a celeron 2.6
Hi. The amount of memory that can be installed is limited by the motherboard, not the CPU. That being said, the motherboard you have listed will take the following memory:
Each memory slot can hold DDR PC2700,DDR PC3200 with a maximum of 1GB per slot.
Sep 28, 2009 | Intel Celeron D 325 2.53GHz 533MHz 256KB...
Ram cards ?
Yes, you will have to purchase the correct RAM modules.
Your 184 pin RAM is DDR. Here is a picture.
07eb2c5.jpg If you count the small copper contacts at the bottom on this side, there are 92. There are also 92 on the other side. (Total of 184) These are the "pins".
Go to www.crucial.com and run their scan program. It is safe. It will scan your system and then tell you how much RAM you have, how much your computer will hold, and what kind of RAM you need.
Jul 01, 2009 | Televison & Video
I dont see what kind of ram for fx6710-01 at newegg could you tell me what kind ie. pc 800 pc 1066 ??
go to www.crucial.com and run the memory utility. It will let you know what kind of memory you need and the maximum memory your computer will hold along with how many slots
Dec 06, 2008 | Computers & Internet
Aboout ram and graphic card
I can help you with the first part.
Go to http://www.crucial.com/ and run the "Scan My System". It will tell you how much RAM you have, what kind, how many empty slots, and how much it will hold. It will also make suggestions.
It works rather well.
As for the graphic card, not sure what kind of motherboard you have. That is, what kind of slot you have. For gaming, I can tell you that you should get the card that has as much video memory you can afford. If you care to comment back with the model of your motherboard I may be able to help you further.
Nov 22, 2008 | AMD Sempron 3000+, 1.6 Ghz (SDA3000AIO2BA)...
Gateway E-2000 Deluxe PC Desktop Logo
26 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
