Question about Minolta Office Equipment & Supplies
How to get into service mode and developer and drum intialization
  • Minolta Expert
  • 1,326 Answers
Hi Joe, what model of Minolita do you have? The service mode has changed in the years, but basicly the same. The basic all around one is > Stop - 0 - 0 - Stop - 0 - 1
Posted on Sep 16, 2010
How to fill developer on my Ricoh africo 2035e
first open the front door then side door remove the drum unit than separate the top part of the drum unit and the development unit than pour the developer in the D.V build it up than press back the drum unit in the machine turn on the machine then enter the service mode go to the drum/mode then enter execute it
Oct 22, 2015 | Gestetner Dsm635sp Dsm645g Dsm 635sp Toner...
Konica minolta bizhub 3010 cof 32
When was the last time the developer and drum where replaced? Does the machine say "REPLACE DRUM in the upper left corner of the operation screen? More then likely your drum and developer need to be replace if not those then the DEVELOPER CARTRIDGE NEED TO BE REPLACE when was the last time that was replaced? Every four drums the developer cartridge needs to be replaced. When the developer was replace was a F8 run from service mode?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 16, 2014 | Minolta Office Equipment & Supplies
PROCEDURE CHANGE DEVELOPER KONICA BIZHUB 600
First clear the developer counter in service mode.
then remove the drum cart. remove developing unit. remove old developer. then run Auto max density. If you don't and make a copy or print you will have to replace the developer again
. recommend cleaning all toner around the drum and drum sensors requires removing drum be careful a nick on the drum will show up on all copies/prints
Apr 24, 2014 | Konica Minolta Developer 02xk Dv710 for...
How do you reset drum and developer counters
Press the Utility/Counter button then meter count then details then stop 00 stop01 to access service mode then clear drum and developer do not exit out all the way once counters are cleared touch end then power off the main PWR ON/OFF switch located on the left hand side of the machine in the rear then remove the Drum Cart and replace drum and Developer then reinstall drum cart. Enter service mode again Run Function F-8. Do no print or copy before doing this. So disconnect FAX line and Network cable.
Apr 08, 2014 | Minolta bizhub 350 Black and White Copier
Minolta di183 cof32 code
Man!!!!!!!!!!!!!!
Start first bye buying a new drum, cleaning blade and developer. Hope fully you did not destroy the sensor on the bottom of the developer unit it has a ribbon cable. You need to clear the counter for developer drum first in service mode. Then replace the developer and drum and cleaning blade together as one!!!!!!
Then run the required F-8 procedure in service mode.
Sep 08, 2017 | Konica Minolta Office Equipment & Supplies
Need to replace the drum on a minolta bizhub 350 copier
First get into service mode. Utility/Counter then meter count then check details. Then Stop 00 stop 01. Counters. Clear Drum and Developer. Then touch end do not exit all the way out of service mode. Turn off the machine using the main on/off rear of machine left hand side. Then remove the image cart. and replace the drum and developer. then turn machine on reenter service mode. Run F-8 found under Function. Do not print copy or allow fax to print before this is done. Or you will have to replace the developer again. So remove network cable and fax line if machine is as printer and FAX. after powering off
Jan 15, 2014 | Minolta bizhub 350 Black and White Copier
How to replace drum
Enter service mode and clear counter for drum, then power off the machine remove drum cart. then remove drum and replace with new one recommended that developer also be replace at the same time clear that counter first along with drum counter. once drum and developer replaced run F8 in service mode before making any copies or prints or will have to do it all over again.
Jan 12, 2014 | Minolta bizhub 250 Black and White Copier
The machine i have is KONICA MINOLTA DI251OF.The light for the drum unit is on even after the drum been change.How can i get the light to turnoff
Was the developer also changed? Because who ever change the drum did it wrong. The first thing you do before you remove the old drum is cleared the drum counter, seems that was not done now the copier thinks the new drum is old and is applying the required voltages for a old drum even though the drum is new will have image problems and codes soon. Recommend you get a new drum, cleaning blade, and developer and replace them all their are normally done at the same time, because in a few week the developer will the go and so drum unit will show up a again. make sure you clear the counters first then install the parts and make sure you run the required F8 in service mode. Utility/Counter, Details then. stop00 stop01 for service mode. Under Function for F8 and counter for clearing developer drum image section which should be done after every forth drum the developer unit that hoses the drum and developer.
Sep 20, 2011 | Minolta DiALTA DI2510F All-In-One Laser...
On my bizhub 250 copier, there is a message stating " Please change PC Drum" My question is, How do I change PC Drum?
This is a service technician performed function. The PC Drum unit is changed by removing the whole imaging unit and then removing the drum section and changing it out. At the same time the developer needs to be cleaned from the developing unit and replaced with fresh developer. The drum counter is then reset using the service mode and then the new developer must be calibrated using the F8 mode. So in this machine's case, this is just not a pull out the old unit and plug in a new one.
If you find the "right" service guy, he can come in and reset the drum counter and do the f8 without changing either the drum or the developer. This can sometimes get twice the life out of the unit. Copy quality can degrade a bit towards the end of the second cycle.
If you just reset it your looking at around $100. If you do everything that is called for then the cost is more like $350.
Good Luck and Thank You for using Fixya.
WheatlandServices
Jan 20, 2011 | Minolta bizhub 250 Black and White Copier
Our bizhub-250 receives a C2557, need help with service mode
Utility/Counter -> Details -> [STOP][0][0][STOP][0][1]
Go to counter and clear the life of the developer and drums and then run F8 from functions.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Jan 11, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
43 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
