Question about Whirlpool WGD5700S Dryer
Dryer runs but does not heat up?? The actual model number is WGD5500S
  • Whirlpool Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Sep 16, 2010
The dry wont run on high heat cycle but will run on the low heat cycle
Could be the Hi Limit Thermostat causing problems. There are over 350 Roper Dryers. Not much can be diagnosed without knowing the actual model number of your dryer. Please drop a comment with full model number. You can view the parts by selecting the correct model from this site.
RoperDryer Parts
Sep 02, 2014 | Roper Dryers
No heat in dryer
Check your exhaust leading from your dryer because kinks and lint blockage are the leading cause for exhaust high temperature thermal fuse to burn out causing it to run with no heat. The thermal fuse for a front loading 110.88752791 is part number=> 3399849 Thermal Fuse
You may view the location number 15 HERE. The location 5 in that photo is the=> 3398128 Cycling Thermostat
How to check these parts can be found on the same above pages, If rhe model I listed is not your model let me know and I will send you links to other models with the same model number as 110.88752791, Thank You Sea Breeze
279843 Heating Element Assembly
Nov 07, 2012 | Dryers
I don't seem to be getting any heat
Hello & Welcome to FixYa
If you have already tried cleaning the vent then the problem is with the Thermal fuse. When the thermal fuse goes bad it cannot be reset and replacing it is recommended repair. It is located on the blower wheel housing inside the rear panel to the exhaust duct. Please get back to me if you have any other questions.
Kevin
Feb 13, 2011 | Whirlpool WGD5500S Dryer
Dryer won't dry
Well lets talk about it a minute. The ignitor is ok because it does glow. The flame sensor is ok because the ignitor is working. The only other thing in the circuit is the solenoids. So what goes wrong? Those coils get hot and quit with age.7ecd66c.jpg Replace them and the dryer will come back to life.5dc4e80.jpg
Jun 28, 2010 | Whirlpool WGD5500S Dryer
Dyer will heat for a short time then blow lukewarm air and then cool air.
All dryers made within the last decade have a noister sensor that senses the heat flow. If the exhaust vent is clogged up with any lint the sensor will shut the burner completely off. Check the vents thoroughly from the dryer to the outlet oat the wall. If clogged ajnd cleaned it will operate correctly again. If not the sensor is at fault
May 17, 2010 | Whirlpool WGD5500S Dryer
Kitckenaid dyer KGYe6778WH1 Dyer won't heat
This is most likely due to the coils on the gas valve, they can become unstable and cause the symptoms you are describing. The coil kit is part number 279834 and runs about $20.00. It is replaceable from the front and not too hard to do.
Side note: the '8' in your model number is actually a 'B'
Apr 22, 2010 | KitchenAid KGYS850LT Gas Dryer
Have to run dryer cycle 3 or 4 times to get clothes dry
If your dryer is STILL heating, but you are experiencing longer dry times and/or poor drying efficiency, the following link can give you some items to check before you assume there is a malfunction with your dryer:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
The number one cause of dryer heat related problems is poor exhaust ventilation. If not vented properly, a dryer will not dry efficiently, will take longer than required to dry, and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter as the heating circuits begin to overheat. This is also the source of many fire hazards if not resolved. Read through the link provided and review some of the potential causes.
If you have any questions, please post back and let me know. Please include your MODEL NUMBER, so I can determine how your dryer is configured. I hope you find this information is helpful.
Jan 14, 2010 | Dryers
My Kenmoor dryer will not start. When pushing the
send model number, an even heat board would cause this,or you can unplug dryer and open console on top and see if the even heat board is in there,check it for burn marks,there should be a tech sheet in the console that will help you out but put it back,if you have to call someone in to work on your dryer and the tech sheet is gone they might not be able to help you, there is a relay part 3405281 could be in there,there are actually two of them,there is a heat relay and a motor relay,you can change them out as they are the same part and see if motor stays running,if so change out the motor relay, but i need model number to look up your dryer
Dec 10, 2009 | Kenmore Dryers
Will not start light comes on in the drum put nothing happens when you push the start button
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Oct 26, 2009 | Whirlpool WGD5500S Dryer
Dryer not heatting
the model number you provided is actually the serial number. Most elements are in the rear if the lintr filter is on the top. If the lint filter is in the door the element is on the bottom.
Apr 08, 2009 | Dryers
Whirlpool WGD5700S Dryer Logo
46 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
