Question about GE Dishwashers
My dishes are coming out with a white chalkyness on them. I use Cascade Complete and Jet Dry. We do have hard water but also have a Water Softener. Could I have a filter problem with my dishwasher.
  • GE Master
  • 43,501 Answers
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Posted on Sep 16, 2010
Keep getting a white film on all my dishes, not cleaning properly.
Check the temperature of the water. Should be 120 deg. Also are you using powder or liquid? Liquid dissolved a lot quicker that powder. So liquid is actually better to use. Try running the hot water at the sink until it gets hot before running the dishwasher. Also you may want to try mixing half cascade liquid and half lemon shine.
Nov 14, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
When I wash the dishes whether it is liquid or powder cascade soap the dishes come out woth a white filmy substance. What causes that?
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle. Make sure that your soap dispenser drawer is opening and closing fine.
Hope this helps... Please post back if more information is required.
Daniel
Mar 25, 2011 | Maytag Dishwashers
Dishes aren't clean when they come out of the dishwasher. There is this whitish film on them. We use Cascade and Jetdry everytime.
Hi
Daniel
Feb 20, 2011 | Maytag 24 in. MDBH950AWS Built-in...
My dishes come out with a powdery coating on them and cutlery is not always clean. I use cascade and jet dry but this still does not help. Whyis this happening?
Hi
Daniel
Feb 20, 2011 | Frigidaire 24 in. FDB1050RE Built-in...
I have a heavy white film on dishes after the cycle. It is mostly on the dishes on the top rack. I've had this dw for 3 years and it just started happening. i use cascade powder and i don't even fill...
Hi
Daniel
Jan 26, 2011 | Kenmore 15639 Built-in Dishwasher
My GE dishwasher is 2 months old. The dishes are coming out with a film on them and the stainless steel inside has a white residue on it. I am using the recommended cascade products.
Do you know if you have hard water. It sounds like a hard water film. 1) purchase several applications of dishwasher cleaner from your local grocery store. Use them all back to back. 2) The only detergent I have found effective with hard water is called Somat. You may try your local appliance parts retailer for this. 3) The best solution is a water softener for your house.
To confirm if this is hard water, soak an affected glass or dish in the sink with 1/2 white vinegar and 1/2 water for a couple minutes. Then simply dry, if the film is gone its hard water.
Jan 14, 2011 | GE Dishwashers
White powder residue left on dishes after washing. I run hot water before running dishwasher, use Cascade powder (fill dispenser less than 1/2 full per installer and do not use prewash detergent...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Nov 10, 2010 | Whirlpool DU805DWG Dishwasher
I have a GE profile dishwasher. I am getting a white dull film on all of my dishes. I have tried running vinager with no dishes then washing as usual with Cascade. I still can't clear up the problem. What...
The inlet washer should be lime free water ( not hard water ). If the inlet water is hard use water softener cartridge and attach to the inlet water of the machine. If rinse aid liquid is not used, fill the respective compartment and try. If two in one detergent tablet is available in the super market store try that option also.
But the water quality needs checking.
Oct 04, 2010 | GE Dishwashers
The dishes don't come out clean and there is a whitish film on all the dishes. I'm using the heavy cycle and only dry cascade detergent as suggested.
it's either:
  • too much detergent used, try using less
  • too much or too little rinse aid liquid used. Adjust, test, repeat ;)
  • problem with water softener if you have one. get it serviced.
  • water is too hard and you don't have a water softener, check water hardness and install water softener if necessary
Hope this helps,
Vlad
First Choice Appliance
Sep 14, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Hi, We have a new whirlpool dishwasher type no. 575-0. GU2275X TVQO. We have not been able to get clean dishes since purchase. Water is hot, everything seems to be operating smoothly. Use the...
I think I can help. We have the same dishwasher and we have very hard water. The dry powder detergents don't work well. We have found Cascade All in One Gel detergent works best and we use only a little; don't go beyond the first mark in the detergent dispenser, regardless what the instructions say. We have found using more of any detergent makes white film. Don't fill up the pre-wash side either. The Cascade All in One Gel does both at one time, so no need to put some in the pre-wash side. Also keep Jet Dry in the rinse dispenser and make sure it is set up higher, turn the arrow to 4. Try that and move up if needed. Next, we put half a cup of white vinegar in the dishwasher, just pour it in the bottom each time, right before we wash the dishes. This works GREAT! We used the white vinegar in on our former dishwasher of 9 years and never had any trouble with any film buildup. The vinegar cuts all the film and makes glasses look terrific.
If you are still are having trouble, cut out the Heated Dry at then end. The heat can cake hard water on your dishes. It may not dry the dishes as well, but it seems to stop any buildup. Using the vinegar though, we use the Heated Dry and still have no film buildup. So for us, we use a small amount of Cascade All in One Gel detergent (buy this basic gel, no added anything), 1/2 cup white vinegar poured in the bottom and Jet Dry in the rinse dispenser. We always have sparkling clean dishes with no hard water buildup. If you don't have real hard water, but just a little hard water, you might try decreasing the white vinegar to 1/4 cup and increase it if you start seeing the white film build back up. Also don't overload the dishwasher. Make sure there is space in-between each dish and have all plates face toward the center.
Make sure you turn your sink faucet on to as hot as you can get it and run the water until it is hot, then turn off the faucet and turn on the dishwasher. This helps to keep the dishwasher from running longer, which would mean more hard water swishing around longer if you don't heat the water, and you know what that means, plus the heating element has to work harder to get the temp up and that makes it burn out quicker. Once a month check your jet sprays, that turn around in your dishwasher, because the little holes can stop up with hard water gunk and this will cause film on your dishes to build up. Take a toothpick and crush the gunk in any holes and make it go out of the holes. Hope this helps you!
Apr 27, 2009 | Dishwashers
Dishwashers Logo
79 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
