Question about Logitech Cordless Mouse
When I left click it will double click - Logitech Cordless Mouse
  • 435 Answers
There is a possibility that on the windows operating system (control panel/ mouse) the option to double click with a single touch is turned on. I doubt that it is a problem related to the wireless system itself.
Posted on Sep 16, 2010
How can get driver for Wind XP
There are no drivers user loaded, the instruction is in the cd / dvd disk drive already from the factory, but when you load the OS, it has some included... these have been known to become corrupt or filtered...
In case windows no longer recognizes the cd dvd disk drive, as if the disk drive driver were erased...
left click start in the lower left hand of the screen
left click run
type regedit
left click OK
Now the registry editor will come up
double left click on HKEY_LOCAL_MACHINE
double left click on SYSTEM
double left click on CurrentControlSet
double left click on Control
double left click on Class
double left click on {4D36E965-E325-11CE-BFC1-08002BE10318}
look on the right side of the window for upper filters
right click on upper filters
left click delete
windows will then ask you to confirm deletion
click yes
look on the right side of the window for lower filters
if you do not see lower filters, you may be out of luck on this one.
right click on lower filters
left click on delete
windows will then ask to confirm deletion
click yes
Close all the windows that are open
restart the computer
In many cases that solution worked, in some cases setting the system back to a previous time, using system restore, was able to reset the system to the time before the system stopped recognizing the drive.
Jun 04, 2013 | Computers & Internet
I deleated by accident my built in crystal web cam beause i have got parkinson decease my hands fingers shake but i cannot get it back no so i need help thank you.
Hi rodneygarret...
Double left click on "My Computer">double left click on your main drive (normally C:)>double left click on "Programs">look in the programs folder and find the folder that has your cam folder in it...after you find it then click on the reinstall icon...normally it will be the largest file of the folder.
Please take time to rate me
Jul 28, 2011 | Acer Aspire 3610 Notebook
The left mouse button doesnt work every 4th press...
I believe the switch inside the left mouse button has worn out or broken that made you think after pressing 4 times you were able to trigger the switch and make the mouse to work. You may open your mouse carefully to see if this is the case. If not please follow the below steps as you might need to configure the mouse double click speed.
Open control panel>Double click on the mouse icon>Button Tab>Double Click section>Adjust your double click speed.
Jul 19, 2011 | Computers & Internet
COMPUTER CRASHED I NEED TO RELOAD CD BUT I DONT HAVE ACCESS CODE
There are now several versions of the basic Futura software and AutoPunch available on the market. The most current is version 1.0.0.2. To determine what version of either software you have, you will find this information around the inside rim of the CD at approximately 4 o'clock. Before loading any of the Options into your computer, check the version and then follow the steps below. The following steps will update your software so that you will now have the latest 1.0.0.2 version of the basic program and all options.
To load base software 1.0.0.0 with AutoPunch 1.0.0.0 or base software 1.0.0.1 with Autopunch 1.0.0.1
  • You must use bobbin part number 085128. This bobbin is specifically designed for the Futura CE-100 and CE-200.
  • Load Base software (have machine set-up for embroidery with USB connected to both machine and computer - machine turned OFF)
  • Turn on Futura machine and double left click on Futura icon to open program
  • Close program and turn off the machine
  • Install Autopunch and leave the CD in the tray
  • Download appropriate update for Windows Version from the Futura-Support.com updates and save to desktop
  • Double left click on the desktop download icon to install update
  • Type in the Access code from Autopunch jewel case and then left click on the check mark to open program
To load base software 1.0.0.0 with AutoPunch 1.0.0.1 or base software 1.0.0.1 with Autopunch 1.0.0.0
To load base software 1.0.0.0 or 1.0.0.1 with Autopunch 1.0.0.2
  • Load Base software (have machine set-up for embroidery with USB connected to both machine and computer- machine turned OFF)
  • Close software and turn off machine
  • Install Autopunch using Installation Wizard - leave CD in tray
  • Turn on Futura machine and double left click to open program
  • Type in Access Code from Autopunch jewel case and then left click on check mark to open program
To load base software 1.0.0.2 with Autopunch 1.0.0.0 or 1.0.0.1
  • Close program and turn off machine
  • Place Autopunch CD in tray but CANCEL Installation Wizard
  • Turn on Futura Machine and double left click to open the program
To load base software 1.0.0.1 with Autopunch 1.0.0.1 with Hyperfont 1.0.0.2 or Photo Stitch 1.0.0.2
  • Load Base software (have the machine set-up for embroidery with USB connected to both machine and computer - machine turned OFF)
  • Close program and then turn off the machine
  • Install the Autopunch program and leave the CD in the tray
  • Type in the Access code from Autopunch jewel case and then left click on the check mark to open program*
  • Download appropriate update for Windows version from the Futura-Support.com updates and save to desktop
  • Double left click on the desktop icon to install update
  • Install HyperFont program - leave CD in tray
  • Type in Access Code from HyperFont jewel case and then left click on check mark to open program*
  • Install PhotoStitch program - leave CD in tray
  • Type in Access Code from PhotoStitch jewel case and then left click on check mark to open program*
* Must open the program after installing each Option with CD in tray and type in Access Code before installing next Option.
To load base software 1.0.0.2 and adding all Options - Hyperfont 1.0.0.2, PhotoStitch 1.0.0.2, Autopunch 1.0.0.2 and Cross Stitch 1.0.0.1
  • Install Base software (have machine set-up for embroidery with USB connected to both the machine and computer- machine turned OFF)
  • Close program and then turn off machine
  • Install Autopunch program and leave the CD in the tray
  • Type in Access Code from AutoPunch jewel case and then left click on check mark*
  • Install Hyperfont program and leave the CD in the tray
  • Type in Access Code from HyperFont jewel case and then click on check mark*
  • Close Program and turn off machine
  • Install Photo Stitch program and leave the CD in the tray
  • Type in Access Code from PhotoStitch jewel case and then left click on check mark*
  • Close program and turn off machine.
  • Install Auto Cross Stitch program and leave CD in tray
  • Download appropriate update for Windows version from the Futura-Support.com updates (Fut_sp2_Options.exe) and save to desktop
  • Type in Access Code from Auto Cross Stitch jewel case and then left click on check mark*
Dec 11, 2010 | Singer CE-200 Quantum Futura Computerized...
When ever i click the left button it double clicks
You can alter the double click setting by going to Control Panel - Mouse and move the slider for the Double click setting to the left to slow down the click response.
Dec 24, 2009 | Targus AMW15US Mouse
Double click on single clicking the left mouse
Try changing the "Double-Click speed.
2. Check for the Folder option.
Good Luck!!!!!!!!!!!!
Oct 20, 2009 | Computers & Internet
The left button fails to function when I double
On Mouse Property, try faster on 'Double click speed'
Oct 18, 2009 | Microsoft Wireless Laser Mouse 5000
Left Mouse Down Doesn't Maintain Selection
Check the CCORNELL posting for the solution. Your mouse is double clicking when it should be only single clicking.
Dec 06, 2008 | Logitech Cordless Mouse
Have got a printer HP Destjet F 2100series F4100series cannot get the disk to work it is a new one the book tells me to click my computer double-click the cd-rom icon but i cannot find this can you help...
Left click "START" button
Left click "My Computer"
Double left click the CDROM icon (Picture of a CD)
This will open your CDROM disk, look for setup.exe and double left click it.
If you can't find a setup.exe, look for the autorun file double left click it and in that file should be the startup file and location.
May 09, 2008 | Office Equipment & Supplies
I need to set day and date display on my computer
I assume you mean date/time right click with the mouse on the time at bottom right hand corner a list will appear left click with mouse on adjust date\time a screen will appear and you can adjust time and date on that screen.
Another way to access this control is left click start button highlight control panel double left click with mouse and double left click on date/time option
Apr 27, 2008 | Computers & Internet
Logitech Cordless Mouse Logo
94 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
