Question about Linksys WRT54G2 Wireless Router
Following CD perfectly 5 times and getting Error 322. I have internet through my cable company and not a phone line.....is that the problem????
  • 550 Answers
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Posted on Sep 16, 2010
Cant play wont let me on line
The problem can be your Internet service provider, or setting on the computer. The exact error message would help. Contact your
Internet service provider (cable company, phone company, whoever you pay) for help. If you are not paying, you will not get Internet, unless you use free Internet at a restaurant or something.
Nov 01, 2013 | Computers & Internet
Printer laserjet 3055 give fax problem problem is fax comm.error 322
Good day.
A fax comm.error 322 usually means:
Telephone line conditions were too poor to send a fax.
Solution:
1. Reattempt the fax transmission at a different time when telephone line conditions have improved.
2. If the session fails after transmitting several pages of a large document, retransmit the document as several smaller documents.
You can also try disabling the ECM feature:
Reconfigure the local fax machine to use different configuration settings, toggle the ECM state and/or select a slower reception speed.
To Disable ECM, perform the following steps:
1. Press the or > button until the front display reads "Fax Setup".
2. Press the ENTER/MENU button.
3. Press the or > button until the front display reads "All Faxes".
4. Press the ENTER/MENU button.
5. Press the or > button until the front display reads "Error Correction".
6. Press the ENTER/MENU button.
7. Press the button until the font display reads "Off" and then press the ENTER/MENU button to save the setting. (Off disables ECM and On enables ECM).
TIP: It would also be helpful to check physical conditions of your phone cord and telephone filters if you are using one.
Jun 26, 2011 | HP LaserJet 3055 All-In-One Printer
Good Morning! I work for a small business that has 5 of the GE 2-9451 4 line phones with intercom. We were actually running two businesses out of the same office originally. Line 1 would ring in to...
Since you said line 3 was working for #2 company, i will suggest you put the line 3 back from where you removed it from. From the look of things the line might be the only line connected to be functioning. When ever you want to switch line since it is with intercom you will need to switch both side from where it is connected to where it is connected to, so that network connection can be achieved.
And on the other hand, the other line might not be working properly, that is why it was not connected or used.
Take care.
Apr 08, 2010 | GE RCA 4-Line Speakerphone
Have dsl line get dialtone send fax fax comes up communication error-322
probably the line is not good, call the experts of the phone company
unaasp192
Apr 08, 2010 | HP Officejet 4315v All-In-One InkJet...
When I send a fax, I get error code 322. I can't receive faxes either.
The error depends on the fax model that you are using. Error 322 on Canon Fax and other machine may significate that the Fuser is not heating (Usually Bad Fuser Module).
A different thing is Comm error 322 on computer, that means that there is no communication, and can be caused by bad phone cable, software problems and hardware problems.
In that case ensure that you are using a fax cable with two poles. If the problem started recently do a system restore to a date before the problem started.
If you get the 322 on display, even when computer is not connected, you usually need to replace the fuser unit.
Regards.
Mar 06, 2010 | Computers & Internet
Hi I cant configure my router D-link DIR-300
Hi! I will be more than glad to assist u in this concern..Please dont use the setup cd or setup wizard. you can access the setup page of the router by typing at the url:192.168.0.1 then it will ask for the user name and password, by default the username is admin and the password, leave it blank.. here are the things u need to check before u setup u router.. .. if you are using a cable modem from ur cable company provider- u need to do a mac clone on the router u have to clone the mac address of ur computer. normaly the mac of ur computer is the one register to your cable company and on the setup page of the router just selct on the internet setup, dhcp after clonning the mac address of your computer. u need to connect ur computer directly to the router and then after doing the process connect the router to the modem. if u are using a username and password, u have to use the pppoe settings on the router, if ur isp set a static ip , set it up to the router, to check the ip setting of your isp.. connect the computer directly to the modem and check if u have internet.. then click on start, run and type cmd,it will give u a dos prompt and from there type ipconfig/all and it will show u the ip address, subnetmask, default gateway, dns server.. I hope this will solve ur concern..
Jul 29, 2009 | D-Link DIR-300 Wireless Router
After logging in to the dial-up after about 5 minutes it kicks of line.the dial-up company says shows we are online
If you can get cable internet service, it will fix that problem. Your modem transfers 54bps over a phone line that transfers other info over that same line so from the service side of that deal you get the drops time from the internet. It's called (timeout from the internet protocal).
Apr 25, 2009 | Compaq Presario SR1111NX (PC146A) PC...
Router not hooked up properly
Router setup
If you are using the cd that comes with the router, that is the problem. You do not have to use the cd. Go to the control panel and un-install the program that the cd installed.
then:
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jan 01, 2009 | Linksys Wireless-G WRT54G Router
Wireless router not communicating with computer
Dont run the CD. Connect the Wildblue to your router via the INTERNET PORT then your computer to ports 1 2 3 or 4. Turn off the router wait 10 seconds then turn it back on and restart your computer. you should be online. you dont need to install the router using the CD.
Dec 26, 2008 | Linksys Wireless-G WRT54G Router
Brother MFC 3360C
Try turning off ECM (error correction mode or overseas mode). Try calling the fax # from a regular phone line - If you hear the fax shrill tones you know you've got the right #) I it does not go through, you should get an error code #. let me know what it is
May 02, 2007 | Brother MFC-3340CN All-In-One InkJet...
Linksys WRT54G2 Wireless Router Logo
108 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
