Wont spin,or drain,noise from pump area already replaced control panel and cleaned filter
  • rwjohn1961 Sep 17, 2010
    yep an allen wrench made its way there to pump
    an allen wrench made it's way thru the strainer and into the pump. That fixed it
  • 2,272 Answers
If there is noise noticed from pump area,then remove the pump and check if any blockages.If not then check the hose connected to the pump.In many cases this hoses are blocked and this causes the problem.If the pump is too old then it can be faulty causing the noise.But if pump and hose both checked ok then check if the motor is running or not.If not then motor can be faulty causing the noise.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Sep 16, 2010
Samsung big wash noise when in use no error message or leaks
Drain Pump
To check the drain pump first see if you hear it when it is agitating if it is it is unlikely to be the drain pump. If you hear it in spin or drain cycle check the filter.Some have a small cover in the lower front put a screwdriver in the hole and turn counterclockwise to remove. There will be a cover to remove, water will come out so be prepared with a towel or wet vac. Clean this out. Other Machines will need to access the drain pump to get to the filter. This can be done by removing the back panel on some washers. On others you will need to remove the lower panel or complete front panel depending on model. The filter is located inside the large hose from the tub to the pump. Remove the hose and clean the filter. If you hear the pump making noises you will need to remove the drain pump and check for obstructions, broken impeller, or not spinning freely. Remove obstructions if it does not spin freely replace the drain pump. If you hear it hum replace the pump.
Struts/ Shocks
The struts can cause squeaking noise or vibrations. You will need to remove the back panel , top panel, or lower front panel then run machine to check if the noise is coming from the struts. If it is replace the struts
Motor
If the motor hums, rattles,or squeals replace the motor. This is easy to do. Remove the back panel then run machine to check for noises.
Belt
Check the belt for making noises by removing the rear panel and then running the machine, if it is making any noise replace the belt
Rear Bearing
To check the rear bearing remove the back panel and listen for noises or any water leakage around the bearing. If any noise is heard replace the rear bearing. Check with service manual all bearings are not repairable. The outer drum may get damaged trying to replace this bearing on some models.
Proceed according and fix it. God bless you
Jun 09, 2013 | Washing Machines
WASHER IS NOT DRAINING
see this causes and fix it. God bless you
Drain Pump Filter
This is the most common problem. Some have a small cover in the lower front put a screwdriver in the hole and turn counterclockwise to remove. There will be a cover to remove, water will come out so be prepared with a towel or wet vac. Clean this out. Other Machines will need to access the drain pump to get to the filter. This can be done by removing the back panel on some washers. On others you will need to remove the lower panel or complete front panel depending on model. The filter is located inside the large hose from the tub to the pump. Remove the hose and clean filter.
Drain Pump
The drain pump may have failed. If you hear it making noises you will need to remove the drain pump and check for obstructions, broken impeller, or not spinning freely. Remove obstructions if it does not spin freely replace the drain pump. If you hear it hum replace the pump if nothing is found inside. If no noise is heard check the pump for power. To do this remove the wire connectors and connect a voltmeter turn to a drain cycle, refer to tech sheet or service manual for proper voltage reading, usually any voltage would probally indicate a faulty pump. If no voltage to the pump replace the main control board.
Hoses
Check the hoses from the pump by disconnecting them and make sure there are no obstructions. Check your hoes drain, if it is a slow drain this can cause your washer to not properly drain.
Oct 11, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Water wont drain
Drain Pump Filter
Drain Pump
Hoses
Oct 11, 2012 | LG WM0642H Front Load
Water not flowing
SEE this causes and fix it. God bless you
Drain Pump Filter
Drain Pump
Hoses
Sep 25, 2012 | LG WM-2277HW Front Load Washer
Not washing or draining
see the causes and fix it. use the common sense. God bless you
Drain Pump Filter
Drain Pump
Hoses
Sep 22, 2012 | Zanussi ZWF1630 Front Load Washer
Indesit iwc6145 washing machine all lights flashed now not spinning or draining??
see the causes and fix it. God bless you
Drain Pump Filter
Drain Pump
Hoses
Sep 22, 2012 | Washing Machines
Whirlpool Washing Machine won't drain after pump is cleaned and there are no blockages
see the causes and remedies:God bless you
Drain Pump Filter
Drain Pump
Hoses
Jul 18, 2012 | Whirlpool Washing Machines
My HE2 front load wouldn't drain & spin and was making noises below. i called Affordable Repair and they said the control panel had to be replaced for $200 + labor. i said the noise is coming from u
Hi.
The noise coming from underneath is symptom of a problem with drain pump or drain line.
The standard procedure consists in accessing the drain filter to check if it is blocked, then testing drain pump. Most of the time the noise is caused by blockage at drain filter. In some case the pump is gone.
The control panel gets replaced only after checking drain filter, testing drain pump and also after testing the water pressure switch that determines when to start or stop the pump.
Bye.
G.
Dec 08, 2011 | Kenmore HE2 Plus Front Load Washer
Suds, F02, clicking sound from drain pump/motor
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Nov 24, 2011 | Kenmore Elite 45986 Front Load Washer
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
