THE TV COMES ON AND STAYS ON.HOWEVER,THERE IS A SINGLE LINE,SOMETIMES PARABOLIC IN SHAPE,IN THER CENTRE OF THE SCREEN.WHAT CAN BE THE POSSIBLE IN THE VERTICAL SECTION? THANKS.
  • Televison & ... Master
  • 17,130 Answers
The fault can be relative to the horizontal/vertical sections. Most possible as you mentioned inthe verrtical section if this is the retrace showing back.
Try to check the electroltic capacitors in this section , if vertical height is good and even check for small values around the vertical IC. Loop with a similar valve parallel to confirm than to remove and replace as it becomes a tiring job but make sure that the capacitor is discharged after connecting to the earlier one.
If there is no change in the line or shape check if there is the same issues around the vertical/horzonatal signal path.
The noise can also originate from the Y process sections or in the defflection coils , analysing the vert/horz signals could be good .
Posted on Sep 16, 2010
Relisys tv model no rp4207b ru black line down centre
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Feb 25, 2015 | Relisys Televison & Video
The tv comes on blue light, stays on but do not see anything on screen
It's time to find the nearest "authorized repair centre" for RCA, and get a professional to check the motherboard.
Mar 13, 2014 | RCA 42PA30RQ 42 Class Plasma TV - 1024 x...
Have a black line coming straight down centre of tv
Bad tab bond. try twisting the tv by holding the top corners and lightly twist to see if it comes and goes
Aug 08, 2012 | Hitachi 42HDS69 42 in. Plasma Television
Horizontal line across screen
HELLO
This is called "Field Collapse". Line collapse is different (a single vertical line) in the centre of the screen.
But field collapse is usually a fault in the field circuit (possibly a field output IC has gone short circuit) or electrolytic capacitors have dried out. The same can happen in a CRT TV - looks as if LCD panels are the same way! I think you will have to take this to a service centre.
GOOD LUCK! (:-)
Sep 12, 2009 | Memorex Televison & Video
Red line down right side of screen
I would have a tech come out and look at it. Sometimes the ribbon connectors from the upper or lower buffer boards have poor or corroded contacts. Should'nt be a major deal since it comes and goes.
Apr 21, 2009 | Vizio P4 46 in. HD-Ready Plasma Television
Plasma HD TV Picture blue color static
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Aug 02, 2017 | Televison & Video
Tv Problem
check the circuit board for possible loose connection,try to resolder the horizontal circuit and the crt board.
Jul 23, 2008 | Mitsubishi WD-52525 52" Rear Projection...
JVC 27" CRT TV AV-27BP3 display shows single horizontal line
I have a similar problem on my CRT computer monitor (AcerView 76c). It is an old screen and I think it is just at the end of its life, much like your TV. Having some background in physics, I would be pretty sure that the problem is with the cathode ray tube's vertical deflection system. The horizontal deflection electrodes are working while the vertical one is not. This results in a display of a single horizontal line (or in my case, a few superimposed) in the centre of the screen. Where both X and Y (horizontal and vertical) deflectors fail then the electron gun firing would result in a single bright spot in the dead-centre of the screen.
So really, we have no choice but to move on and buy a new set as repair is probably just as, if not more, expensive than replacement with a new device. Seeing as your post was in 2007, I hope you managed to solve the problem.
Best wishes,
SZ (Sydney, AUS)
Dec 24, 2007 | Televison & Video
Giant close caption like screen takes over wphl and sometimes espn
go into the menu with the original remote and turn off ther closed caption.. if your going to tell me you dont have the original remote. Your outa luck then. now miricle cure. Your going to have to spring for the remote. or borrow one from a friend or local store may let you borrow one. Sorry but it is what it is. .. Push comes to shove , go to 1-800-remotes or http://www.remotes.com and buy one. Good Luck
Aug 21, 2006 | Sanyo DS27800 27" TV
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
