Question about Symbol SPT 1550
Symbol SPT 1550, screen does not respond to stylus
Where an i find the pmr600 ta32 driver
hey we sell all the driver and software for many of the msr readers and writers such as msr206 and pmr600 ( the old TA32 reader )
Diij Electronics
Jul 14, 2011 | Unitech MSR 206-33 (msr206-33) Magnetic...
Does not respond to stylus
Try recalibrating the touch screen. Devices with touch screens need to be recalibrated in order to respond properly. The greater the use, the more often recalibration is necessary. I recalibrate my phone once a week. I hope this helps.
May 22, 2009 | Palm Treo 755p Smartphone
Hi... I have a leapster which we purchased on march, 2008.Recently, the screen doesnot seem to respond for the stylus. but the button works well. what can we do to fix it? [i live in indonesia]
If your Leapster2 does not respond to the stylus pen, it needs to be calibrated. Calibrating the Leapster2 is easy:
1) Ensure that a cartridge is not inserted 2) Hold down the Hint button while turning the unit on 3) When the LEAPSTER menu screen appears, press the A button 4) Touch each of the crosshairs that appear with the stylus 5) Restart unit
Jan 23, 2009 | Leapster Learning System
My MC70 work symbol wont respond to my touch screen pen
Does it respond to keyboard entry? If not, check to see if the "lock" icon on the screen is in the locked position. It's real easy to accidentially lock the device. If it is, just click on the lock and confirm that you want to unlock.
The next few can be a problem if the screen is not responding, so you'll need to figure out the keyboard equivalent:
You may also want to check the system settings. I believe there is a setting that will enable you to "turn off" the touch screen function.
Finally, try a touchscreen alignment in the system settings.
Jan 17, 2009 | Symbol MC70
Spt 1800 trg screen out of line
I Repair the Symbol handhelds. If you wand I can put new screens on them.
Jan 02, 2009 | Symbol Batch Barcode Scanner SPT1800 Palm...
Spt 1800 hand held - fatal exception error message
It needs internal hardware repair. I have done thousands. Send your number, if you think you would like to have them repaired. Thanks
Dec 11, 2008 | Symbol SPT 1800 Handheld
Treo600 Touchscreen doesn't respond.....
Try running a piece of paper around the edge of the screen. There may be was something stuck in there, pressing the screen slightly and causing it to not respond to the stylus
Jan 14, 2008 | Palm Treo 600 Handheld
Screen not responding to stylus
SOLUTION:
KEEP PRESING CALENDAR+MAIL+POWER BUTTON
AND INSERT STYLUS IN RESET BUTTON
Nov 26, 2007 | HP iPAQ H1940 Pocket PC
Touch screen is not responding with the stylus
Try do a hard reset to your device to the deafult vendor definitions, then re-initilize the screen and this should help.
Nov 12, 2006 | Toshiba e330 Pocket PC
Symbol SPT 1550 Logo
110 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
