Question about Samsung SyncMaster 740N 17" LCD Monitor
How do you open it up to service? (replace caps)
  • 11,361 Answers
Remove all the mounting screws, stand first, then using thin flat blade screw driver to separate the front from the back starting at the bottom edge and work your way around, be careful on the cable attached to the front bezel. Also look at YOUTUBE on how to open most LCD monitor cases.
Here are the service manuals: http://elektrotanya.com/?q=showresult&megnev=samsung&megnev2=740n&kategoria=&kat2=all
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Sep 16, 2010
My emergency lights keeps coming on their own and the fuel caps opens itself. What could be the problem?
If the fuel cap opens, some autos have a sensor that will see there's no pressure on the fuel system and you'll get a service engine or other light. You probably need to replace the gas cap.
Nov 03, 2015 | Cars & Trucks
Computer code 455
Possible causes - Missing or loose fuel cap
- Incorrect fuel filler cap used
- Fuel filler cap remains open or fails to close
- Foreign matter caught in fuel filler cap
- EVAP canister or fuel tank leaks
- EVAP system hose leaking
- Fuel tank leaking The P0455 it's a very common code, because the code is set if the gas cap is loose or missing. Start by tighten the gas cap and clearing the code. In most cases the code can be clear by disconnecting the car battery for about 30 minutes.
When is the code detected? EVAP control system has a very large leak such as fuel filler cap fell off, EVAP control system does not operate properly. Possible symptoms - Engine Light ON (or Service Engine Soon Warning Light)
- Possible a noticeable fuel odor caused by the release of fuel vapors P0455 Buick Description This diagnosis detects leaks in the Evaporative Emission System (EVAP) purge line using engine intake manifold vacuum. If pressure does not increase, the Engine Control Module (ECM) will check for leaks in the line between the fuel tank and EVAP canister purge volume control solenoid valve under the following vacuum test condition. The vacuum cut valve bypass valve is opened to clear the line between the fuel tank and the EVAP canister purge volume control solenoid valve. The EVAP canister vent control valve will then be closed to shut the EVAP purge line off. The EVAP canister purge volume control solenoid valve is opened to depressurize the EVAP purge line using intake manifold vacuum. After this depressurization is implemented, the EVAP canister purge volume control solenoid valve will be closed.
if tightening the cap or replacing the cap does not help take your car to a shop to have it diagnosed as it requires special tools/equipment to test this and get an accurate results to find what needs replacing.
Oct 10, 2014 | 2004 Buick LeSabre
High pitched whine not from a fan or hard drive
It is possible that you have a bad component on the motherboard.
Sometimes you can hear a noise like this when a Capacitor (CAP) is malfunctioning.
If you are able to open your computers case; you can look inside at the motherboard, you can see if a CAP is malfunctioning by looking at the top of the CAP (there are many). If the top of the CAP is not flat or has brown marks (not silver/original in colour) then it could be bulging or leaking and needs to be replaced.
There are CAP's in the Power Supply as well but these are not user serviceable... just replace the power supply. If you are handy and feel like you can fix it anyways, just remember that CAP's store a lot of juice and you could be seriously injured!
Jan 17, 2014 | HP SmartBuy ProLiant ML150 G2 Xeon...
How to bleed clutch 2007 compass
GRAVITY BLEEDING CLUTCH HYDRAULIC CIRCUIT
1. Verify fluid level in brake master cylinder. Top off with DOT 3 brake fluid as necessary. Leave cap off.
2. Raise vehicle on hoist.
3. Remove bleed port protective cap and install suitable size and length of clear hose (4) to monitor and divert fluid into suitable container.
4. Open up the bleed circuit by turning the thumb screw (3) counter clockwise this will start the air purge and fluid fill process.
5. Lower vehicle, but only enough to gain access to and fill the brake master cylinder. NOTE: Do not allow clutch master cylinder to run dry while fluid exits bleed port.
6. Top off brake master cylinder fluid level while air is purged and fluid drains from bleed port. Continue this until no air bubbles are seen and a solid column of fluid exists.
7. Close hydraulic bleed circuit, remove drain hose and replace dust cap on bleed port.
8. From driver's seat, actuate clutch pedal 60-100 times.
9. Apply parking brake. Start engine and verify clutch operation and pedal feel. If pedal feels fine and clutch operates as designed, stop here. If pedal still feels spongy or clutch does not fully disengage, excessive air is still trapped within the system, most likely at the master cylinder.
10. Top off brake master cylinder fluid level with DOT 3 brake fluid as necessary.
POWER BLEEDING CLUTCH HYDRAULIC CIRCUIT
1. Remove reservoir cap and connect bleeder cap to reservoir. NOTE: Use Bleeder Cap/Modified reservoir cap adapter Snap-on #901-059 or equivalent.
2. Connect service filling machine to bleeder cap. NOTE: Use Service Filling Machine/Brake power bleeder Brake power bleeder or equivalent.
3. Service filling machine should be pressurized to at least 2.5 bar (36 PSI).
4. Remove dust cap from bleeder valve and connect the transparent bleeder hose to bleeder valve.
5. Place the other end of hose in the bleeder container to capture the used fluid. The end of the hose MUST be submerged in the DOT 3 brake fluid.
NOTE: Use Bleeder Container To capture hydraulic fluid and Transparent Bleeder Hose To route fluid to container.
6. Turn on the service filling machine.
7. Crack open the bleeder valve (3).
8. Allow fluid to flow out of bleed port until no more air bubbles can be seen in the transparent bleeder hose.
9. Once fluid is free of air bubbles; make 15 quick actuations between clutch pedal stop positions.
10. Close the bleeder valve and disconnect the service filling machine.
11. To remove remaining air, actuate pedal 10 times slowly between pedal stop positions.
12. Check clutch pedal to see if vehicle is properly bled.
13. If vehicle is not properly bled, repeat procedure.
14. Remove bleeder cap from reservoir and replace reservoir cap.
15. Disconnect transparent bleeder hose from bleeder valve and replace dust cap.
Oct 15, 2013 | 2007 Jeep Compass Limited
How do I remove small cap on steamer valve, to replace washer?
Simply use a small flathead screwdriver to press one side of the dial insert to remove the dial cap. Under it you have a flathead screw. Remove this to remove the cap. Then use a 20mm socket or open ended wrench to remove the nut. Unscrew the union valve then you will see a seat gasket in the front, and an o-ring on the valve on the back - this is what you are looking to replace. You can contact me if you have any further questions.
My experience is working over 10 years at Pasquini as a master technician running the home repair sales and service center.
I stock all Pasquini parts for any service of your Pasquini espresso machines and grinders. Contact us for any of your Pasquini sales and service needs.
Dec 13, 2009 | Pasquini Livia 90 Espresso Machine
High side schrader valve leaking
its possible but if you install a good service cap with known good o-ring inside...this might take care of it...for your info ,that cap is the primary seal of the port and open schraders can leak on a good day ...in order to replace that schrader ...a/c must be discharged..evacuated and recharged after replacement...put a good cap on it and save the big fix
Jun 28, 2009 | 1995 Chevrolet Silverado 2500
1994 Chevy Silverado Gas Cap Unavailable?
Autozone or oreily just any gas cap just about will do. To force open use a flat head screw driver, hammer and pliers. Drive the FLAT tip screw driver into the gas cap and use the pliers to turn. These vehicles did not come factory with locking gas cap so some one has replaced it once before. Don't worry the worst you can do is ruin the gas cap which is no good to you any way.
Apr 29, 2009 | 1994 Chevrolet Silverado 2500
Where is the high pressure connection for the air conditioner
hi! there,
usually located on high side or discharge presure of the compresor, the discharge service valve fitting equiped w/ cup and pin auto valve ,loosen and remove service cap of service valve fitting,.as you remove the service cap no leak should take place due to it has a pin to locked the pressure on the sysrem . the guage manifold has a host and service port at the end of the host,the sevice port has a tip ball inside port when you connect your pressure guage manifold to test the discharge pressure the tip ball of port will push the pin valve service fitting and opening occued on discharge service valve and the pressure gauge activated and you can the operating discharge pressure.
in your case opening of cap then leakage appear maybe the pin valve was mis aligned or distorted,the service valve was repairable it can repair,but you have to evacuate all freon inside the
system.freon leakage is bad for our environment
use evacuating pump and service tank,after the freon evacuated repair service valve there is pin remover to pull out pin valve sometime cup has pin remover or ask on car air service center.the pin valve has screw type spring attachment replace pin valve and recharge the system you can use the previuos freon on service tank evacuated.
Apr 10, 2009 | 1989 Chevrolet Corvette
Toshiba 50H82 hyperboard caps
Service manual won't help much in the hyper board and that's likely the problem.. Simply remove the hyper board and open the can. Inside you'll see a number of smd caps. There are 11 10mf/16v that need to be replaced...
Bill
Jul 26, 2008 | Toshiba 57H82 57" Rear Projection...
Mitsubishi projection tv vs60va2 picture rolls
This unit has chroin bad caps on the 5v, 9v and 12v regulators. If you know circuitry you can check thos caps and replace the weak or open electrolytic caps. If you call on a tech that services mitsu. this is faily common repair for them and should not cost over 150.00 to 200.00 depending on your area.
Apr 07, 2008 | Televison & Video
Samsung SyncMaster 740N 17" LCD Monitor Logo
357 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
