Question about GE JVM1850 1000 Watts Microwave Oven
GEJE2160 Stop Working
My microwave stopped working. I was heating some food up turned around and nothing was lit. checked circuit breaker and power to microwave all was fine. The microwave is only 1 year old.
Pat
  • 1 more comment
  • scmurf Feb 20, 2009
    GE Microwave stopped all functions without any signs of breakdown. Just quit working.
  • waltergatlin May 10, 2009
    was heating food and the microwave just shut down, it sat for a short time and it reset itself, it has done this about 4 or 5 times
    russ
  • Anonymous Mar 28, 2014
    turns on fine, no heat
    Problem Solver:
  • 17 Answers
It probably blew the main power fuse in side the oven. This may have happen because of a failure in the microwave or a line voltage surge or what ever. Repalce the fuse and see if it work. be sure to unplug it before doing this, If this does not fix it then you have a failure in the oven some were.
good luck
Posted on May 17, 2008
No power, no lights, no clock. Nothing works on my Samsung over the range microwave model SMH17138
Your microwave may be plugged into a regular receptacle which is on a circuit breaker often in a cupboard above the range.Check around to see if anything else is not working. Check your circuit breaker box for a breaker that needs resetting. If you see one out of line with the others turn it off and then back on. Good luck..
Dec 09, 2016 | Samsung Microwave Ovens
MY DAEWOO MICROWAVE KOR 1B4 H JUST STOPPED WORKING.
Maybe time for a new one. But just in case check the power outlet still has power and the circuit breaker is not tripped.
Dec 01, 2015 | Daewoo KOR-1B4H Microwave Oven
I have a Sharp Carousel model R-1874-T. It suddenly stopped working. No lights are on. I checked the outlet and there is power coming there. Is there a way to reset the microwave?
Steve,
You probably have a blown fuse.
Unplug your microwave and turn it around and remove the screws holding cover on and then remove the cover. Look for where the power cord goes into the back of the unit and follow the black wire from the cord to where it ends. It should stop an either a circuit board or a fuse holder. Make sure that you replace the fuse with the same amperage fuse as what you take out. You will find the amp rating stamped on one of the silver collars on each end of the fuse. Good luck!
Mar 27, 2015 | Sharp Microwave Ovens
New microwave stopped working after 15 seconds
Possibly the fuse / breaker is tripped, usually all outlets in one room share same breaker. Check breakers (or fuses) or try outlet in differnt room. If the outlet has power, (plugin a lamp to check) and the microwave still does not work, take it back to store for replacement or refund.
May 11, 2013 | Oster OGG61403 1.4 Cubic-foot Digital...
Not heating
Hello
Power Supply
Check whether there is a proper power supply. Look to see whether the cord is connected to a grounded 3-prong outlet and the cord is fully plugged in. If the electrical system is built-in and no power cord is visible, replace or reset the household fuse or circuit breaker.
Microwave Functions
Some basic microwave operational steps may affect whether the microwave is heating. Open and close the microwave door, as the unit will not function with the door open, and push "Stop/Clear" to cancel any previous settings, such as the timer, which do not heat the microwave oven.
Setting the Microwave
Once the power to the microwave has been reset, or verified as working, and the microwave is ready to run, select a new cook cycle and press "Start" to see if the microwave begins to run and cook food as expected. Allow the food to cook for the alloted time and then open the microwave door and check to see if the food has cooked or heated. Choose a longer cooking time and restart the microwave if food is heating but is cooking slowly.
Repair
If all efforts to troubleshoot the function and power to the microwave still do not get the appliance heating food as expected, there may be a repair issue that needs to be addressed. Contact professional technician for advice.
Oct 05, 2011 | Sanyo Microwave Ovens
Will not heat food
HELLO.
The solution to make your microwave oven to be able to heat food is detailed given below.
1 Make sure the door is closed. If the door is not closed tight, the microwave will not function.Sometimes food will get stuck in the door and prevent the latch from working. Use the paper towel to get the food out, then close the door carefully and listen for the latch to click.
2 Check the power sources. First, make sure the microwave is plugged in; the plug may have shifted or slipped partway out of the socket. If it is plugged in and still does not work, voltage test the outlet the microwave is plugged into. If you are not getting a reading, the breaker is probably blown. Reset the breaker for that outlet in your home's circuit breaker box.
3 Reset the microwave breaker. Take the back cover of the microwave off with a screwdriver. Inside you will find a motor. Most microwave motors have a small red reset button on them. Hit that button. Your microwave should work again if the breaker was the issue.
Thanks
Sep 20, 2011 | Frigidaire Microwave Ovens
My sharp microwave just stopped working. It
IT IS POSIBLE TO HAVE A BURNED FUSE ON THEI Main boARD OF THE OVEN
Feb 14, 2010 | Sharp R-1480 Microwave Oven
Stop working
IS IT POWER UP.
please rmoove the cover and check the fuse also.
is it work?????
nuwan
Jan 11, 2009 | Panasonic NN-S540BF Microwave Oven
GE JVM1850 1000 Watts Microwave Oven Logo
318 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
