Question about Refrigerators
Don't know how to replace the filter. Light is red. having trouble removing filter fro refridg
  • 17,970 Answers
Send us the brand and model to know what info excalty you need.
Posted on Sep 16, 2010
DSC LCD5511 System troulbe nr. 1
system trouble can mean that you might have a faulty expander somewhere. an expander is used to extend the zones on your current system. if not you might have a faulty pacife connected to the system go around all the pacifes and check if the red light comes on. if not replace it.
Jul 08, 2013 | DSC LCD5511 Sixtyfour Zone Fixed Message...
Poulan Pro leaf blower does not get fuel to the carburator. It isn't very old. The filter was off and on the bottom of the fuel tank. I replaced the fuel ines. I have switched the lines and tried
If the fuel filter has fallen off the fuel hose, then the internal carb screen will be blocked, you need the remove the carb, remove the cover on the carb held with a single central screw ( pump side ) here you will find the screen ( fine filter ) clean or replace this, if you can acsess the cover without removing the carb all the better.
Dec 26, 2012 | Poulan Garden
Hitachi split ac ace cutout how to go to standby mode
Its very simple to remove that red light glowing on the AC, just switch-off your AC with your remote, but don't turn off the switch that resides with in the plug, remove filters wash gently and dry under shade and place them again in the AC, now keep it without turning-off the switch for 30-60minutes this is called stand by mode. Now take the remote open the panel and press the button that is situated in 4th row and 3rd column. By doing this the red light will be turned off and enjoy your AC.
Apr 17, 2012 | Heating & Cooling
Very low oil pressure on the 4.3 2000 GMC jimmy reads 20 and check gagues ligh flickers on and off. Loud tappet noise fro m engine.
Low oil....? Clogged oil filter?..........Overheated it lately?.......If so replace oil and filter......Really bad things are: Spun a bearing or two? Clogged oil sump or bad pump.....broken block or webs. don-ohio
Sep 10, 2011 | GMC Jimmy Cars & Trucks
"Check Filter" light is on.
If you look thru the front panel just behind it you will see a spong filter. you will need to access it either by removing the front cover or removing the whole front of the unit . wash it in warm soapy water and replace it . let me know
Jul 21, 2011 | Frigidaire FAA065M7A Air Conditioner
I have a side by side refrigerator & the water filter light is red & the filter needs to be changed. The refrigerator was manufactured 11/04 model # ED26HEXNQ00. I don't know what kind of...
The light will just come on based on time not on if the filter is really need to be changed, you can push and hold the button to reset it, and another six months or so it will light up again. I do not have the same model as you, but mine is in side the ref. top right side, others are on the water line in back.
I have two filters before the refrigerator on mine still go's off I just reset it. If the filter is really needing to be replaced your water would slow to a trickle.
Jun 30, 2011 | Whirlpool Refrigerators
Check engine light came on and car has trouble starting then when it starts and i take off it keeps jerking like it doesnt want to change gears
This could be as simple as replacing the fuel filter, when last time had service? Not oil change, slot of times if you don't make sure on oil change , places will only replace oil filter. I would change fuel filter and possibly air filter. Let me know, and bynthe way, fuel filter is cheap, there under 15 bucks most likely at napa, schucks , etc... Dealer a lot more $$ let me know, glad to help more if that does not solve issue, mike
Jun 08, 2011 | 2004 Dodge Neon
After cleaning red cell light wont go off
This red light goes on when air purifier needs to be cleaned, also check out whether fan is running or fan is stopped if fan is not running and red light is on then the problem is of filter got wet inside.let the filter get dry then check out.if still the same problem the filter needs replacement. to remove the filter for cleaning or replacement Remove the ESP cell by taking hold of the handles and lifting upwards. and then Remove the Oxygen Plus filter from the unit.by lifting it up slightly. its the filter problem either its wet and needs to be dried out or the filter is got clogged by dust and needs replacement.contact the local service center for air purifier and get the replacement filter.------ This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Nov 24, 2009 | Oreck Super Air 7 Air Purifier
LIGHT SWITCH ON MY REFRIDG. DOOR
Just pry gently with a flat blade screwdriver.
May 04, 2009 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
