Question about Samsung Televison & Video
Samsung model LNT4053 H. Turn on power, get the bleep & blue light at bottom comes on. Picture comes in with no sound. Turn off & repeat & then it works. Also at times, get bleep, no sound & no picture. Turn off & repeat until picture & sound come on. This can sometimes take several atttempts. What is the problem & where do I go for service? Purchased at Future Shop in Surrey/Langley & they do not have a service department. Thanks
  • glvillen Sep 16, 2010
    Thank you ladywinn. Will get our techie son to check this out
  • Samsung Master
  • 19,396 Answers
Re:Turn on power, get the bleep & blue light at bottom comes on. Picture comes in with no sound. Turn off & repeat & then it works
Problem is a faulty component. There are on board components, like capacitors, whose role is storing and absorbing charge when the circuits are "warming up". A tini part with this function is not working, for this reason the audio works only after restart.
The fault can be located in audio circuit, internal tuner or main controller board.
The repair involves testing at component level and replacing faulty part. If TV is still in warranty repair will be covered.
To have it repaired contact Samsung or future shop, they will send you a qualified technician.
Here contacts:
Future Shop: Contact us
Samsung: Contact Us
Support pages:
Samsung Support
Customer Support(Future Shop)
Parts:
Samsung TV Parts ' ShopJimmy
Replacement Parts
Posted on Sep 16, 2010
  • Samsung Master
  • 5,138 Answers
Poor solder connections and Bad Capacitors can cause this,Bad Caps will be domed on Top.1000uf 16v 2200uf 10v 3300uf 10v
On my Samsung tv model LN46C630K1FXZA the picture does not turn on but the sound does.
Sounds like back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Oct 18, 2016 | Samsung Televison & Video
Picture and sound turn on and off
I believe that model has a logic board in it and that is what it sounds like to me. That is just off top of my head, but I believe if you will notice the standby light it will be blinking so many blinks and stop and then blink again. If so this is a code that you can look up on the Samsung web site and plug in your model and it should tell you what just say ~ 4 blinks means. I worked on so many and it has been a while but I believe the last one I had was a Samsung and I put a logic board in it. If I can be of any further assistance please let me know.
Mar 12, 2014 | Samsung HL-R5078W 50" HDTV
I have a SAMSUNG model HL-T5076S flat screen TV. A blue light stays on at the bottom of the set after I turn the TV off
Acording to the user manual there is an indicator light that Blinks and turns off when the power is on and lights up
in stand-by mode.
This information can be found on Pages 6 & 7 of the Owner's Instructions wich can be found here:
Sep 16, 2010 | Samsung HP-R5072 50 in. Plasma HDTV
Will not power on or off with remote or on console. no picture. Bottom right corner red light light blinking
This model have a common problem, it on and off cycles, and you can hear the turn on sound repeat. It is the main board failure, you can replace it, the part # you can see a sticker on the board, the format is like BN99-99999C. cost approx $120.
May 10, 2010 | Samsung LN40A550 LCD TV
Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
Apr 08, 2010 | Samsung HLN617W 61" Rear Projection HDTV
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Brand new Samsung A550 52 LCD Unit has power, no picture or sound
usually a pcb came loose during transit or you have a bad power unit requiring professional repair..
Mar 07, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
No picture, won't turn off
Som-one,
the noise you hear after the melody would you describe it as like a buzz or a small chainsaw? If so you have a bad color wheel assembly. If the noise is intermittent than your issue could be the ballast that controls the lamp. If you've already changed the lamp the next step should be the ballast.
Dec 03, 2007 | Samsung HLN5065W 50" Rear Projection...
Televison & Video Logo
140 people viewed this question
Henry  Thomas
Henry Thomas
