Question about LG LFX25960ST Stainless Steel French Door Refrigerator
Freezing my veggies why? - LG LFX25960ST Stainless Steel French Door Refrigerator
  • LG Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 16, 2010
Model SJF750SP. Refrigerator temperature 6 degrees Celsius. Why does everything freeze, even veggies in the veggie bin?
First try adjusting the thermostat inside the refrigerator to a lower number. If this does not work, you have lost some refrigerant from the system, due to a leak. The system would then need more refrigerant installed to correct the freezing problem and repair the leak.
Oct 19, 2015 | Sharp Refrigerators
Whirlpool freezer on bottom refridgerator is freezing up
What does this mean? Liquid is freezing in the refer section? Food (like veggies or leafy items) What model do you have? How old is this unit? Who is requesting this information? I need your help in this too. Thanks.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 25, 2014 | Refrigerators
Our vegetables are freezing in the bottom of the veggie drawer
Try moving the veggies to a different drawer or lowering the cooling setting for the Refrigerator
Jun 21, 2011 | Refrigerators
My refig keeps freezing items in the veggie bins and even above that
Lower the settings to 1 or 2. If you have veggie bins with the sliding adjusting air vent (door thingy) check them and make sure the settings are cold and not colder. it brings more air to the bottom. Cold air drop to the bottom because it is heavier than warm air.
Mar 30, 2010 | Refrigerators
Water leaking out of refrigerator and veggies freezing in fridge
Is it a water/ice dispensing refrigerator? If so, be sure that all water hoses and lines are properly connected and tightened. If not, Check your condensate drain to see if it's clogged. There may be a panel covering it so you may have to take it a part a bit. If it is clogged, unclog it. If it's frozen up then your defrost timer and/or defrost element isn't working properly and should be looked at by someone familiar with electrical wiring.
Mar 13, 2010 | Amana AFD2535DES French Door Refrigerator
Not freezing but fridge is cool (veggie drawers are at 44 not 34)
your compressor is probably not running. if you see no ice build up in the freezer compartment, then the problem is most likely the compressor relay. although it could be a myriad of things, the relay is the most common.
Oct 27, 2009 | Maytag Refrigerators
Crisper and veggie bins are freezing the produce
I have dealt with bosch and thermador quit a bit and they usually don't have to much of a recommendation for these settings because they are more of a commercial type appliance producer and all situations are different. Here is a tip for the sliders though. Remember that leafy produce needs more airflow to hold its texture and taste and anything with a skin requires less airflow. As far as the temp settings I believe the most nominal settings are going to be in between 5 & 7 to keep from freezing the produce. You will have to play around with it a little though to get it to keep the ref good and cold but keep from freezing the vegies. Hope this helps. Good luck.
Jun 05, 2009 | Bosch KGU6655
Veggies freeze up in the compartment meant for them
1 is the warmest setting, 7 is the coldest.
No answer for your veggies freezing.
Jan 09, 2009 | Amana ABB1927DE Bottom Freezer...
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
90 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
