Question about Konica Z-up 120 VP 35mm Point and Shoot Camera
Lens doesn't open, display panel flashing then turns off on Konica Z-up 120 VP
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To start with try to blow compressed air around the lens cover so that if there is any dirt it cleans if off. You can also stick a thin strip of paper between the lens shutter and the outer support ring & move it in a way that it clears the debris that's stuck in there. If still the issue is not resolved then you'll have to replace the lens assembly & lens mechanism to fix this issue. It is recommended to be done by a professional. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 16, 2010
Vacmaster VP 320 is flashing F1 not working
I found this information related to a different model of the Vacmaster:
If you see F1 displayed on the LED screen and the machine will not function, make sure the lid is open and turn the power off. Turn the machine back on and it should return to working order.
Mar 26, 2014 | Vacmaster ARY VP 320C Chamber Tabletop...
I have a Maxxum 7000i 35mm camera and in the display there is the word Help flashing what does this mean This happend after i tried a differnt lens, the lens opened than closed The lens that i tried was a...
Konica lenses do not fit Minolta cameras. I think you messed something up.
Minolta MC and MD lenses worked on the older manual focus Minolta bodies. They will also work on the Phoenix and Seagull clones of the old Minolta bodies.
The Konica lens should only ever be mounted on a Konica camera.
Your 7000i is now a Minolta paperweight. You need to send your 7000i for repair or replace it.
You could also look on Ebay for another Maxxum body to use your lenses designed for the Minolta A mount. As a rule, camera lenses are not interchangeable. You can use any Maxxum lens on any Maxxum body as a rule, but Minolta changed their flash shoe after the original 7000 series. Flashes that work with your 7000i will work with any subsequent Maxxum.
lightspiritphotography.com
Oct 25, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Blurred side of projector
This is caused by misaligned lens and/or display panel (LCD or DLP). Recommend a trained tech to perform alignment.
Mar 08, 2009 | HP Digital Projector Vp6110 Multimedia...
Konica Minolta Zoom 160c won't turn on--lens stuck out and open
There is some kind of grit or something in the lens gearing mechanism, preventing its movement. Take it to a repair facility, or replace it.
Jul 26, 2017 | Konica Minolta Zoom 160C Date 35mm Point...
No display in record mode on Samsung VP-D31
Sounds like you may have a problem in the auto iris curcuit or the auto settings was switched to manual and the lens is closed. Check first to see that the lens is setup in auto mode. If it is then the auto iris as i said before is bad or stuck closed unless the small caps in that curcuit went bad as they always do after a few years. Good Luck
Apr 14, 2006 | Samsung VP-D31 Mini DV Digital Camcorder
Samung vp-d80 no display on v/finder or lcd display
Its probably not the chips that is defective Jim.. these camcorders use those really small pana caps there called and they leak and go bad and sometimes NO NO most of the time cause the PCB to oxide and melts the pcb traces. If when you try to unsolder these surface mounted caps your gonna get a really acid type smaell thats bad smelling and bad for you too. if thats the case its bad. Good luck and please report back if you want more info.
Apr 01, 2006 | Samsung VP-D80 Mini DV Digital Camcorder
Batteries last
The battery performance depends on the brand of battery. Alkaline batteries last approximately 120 images with the LCD monitor display on, and 140 images with the LCD monitor display off, according to our test result. Minolta's standard test method is as below: Standard image quality, full image size, using flash for 50% of exposures.
Sep 19, 2005 | Konica Minolta DiMAGE E201 Digital Camera
Konica Z-up 120 VP 35mm Point and Shoot Camera Logo
74 people viewed this question
Top Konica Cameras Experts
Robert A. Watson
Robert A. Watson
Tony Parsons
Tony Parsons
Are you a Konica Camera Expert? Answer questions, earn points and help others
