Question about Whirlpool Duet GHW9150P Front Load Washer
My washer is stuck on add a garment - Whirlpool Duet GHW9150P Front Load Washer
SOURCE: F01 and add a garment light on
Check the pump first but you most in likley have a bad circut board. On the front of the washer their is a kick panel. Remove the 3 screws on the bottom and remove it. Taped on the inside is a book of codes and some self diagnostics you can run. This is all your repairman will do and he will order the circut board and charge you more than the washer is worth.
Posted on Nov 04, 2008
  • 20 Answers
SOURCE: Pushed pause. Added garment. Washer will not start again.
possible you have not held "start" button down for the required 5 sedonds to restart cycle??
Posted on May 22, 2009
kapishtech
  • 2272 Answers
SOURCE: HE2 Kenmore Washer stuck on F01 error message and
The F01 error is a communication error and most likely the cause is a bad central control board. You tried to unplug the power and the machine still will not start so next I'd recommend trying to run a diagnostic cycle to verify the operation of the central control.In the image below are the instructions to enter and run the diagnostic routine. If the process is done successfully all of the LED light will come on for 5 seconds then display the last error. Push the same button until the error code ends and all the lights come on again for 5 seconds then the test will start.
If the test runs through okay then the central control unit is most likely okay. If it fails to enter diagnostic then the control has failed and needs to be replaced.
The last thing to try is to check the connections on the control. A loose connector might cause this problem
To see how the control unit  looks please check out this link.
http://media.fotki.com/1_p,wkdgrwgdsbqrsbbxgtqsskgwtqkq,vi/gfbtbqbdfxgdwrwktgr/1/1303472/5961857/image59835img-or.jpg
Resolution: Error code F-01 can be caused by a power surge or other electrical anomaly,attempt to return the washer to operation by following the Hard Reset procedure below.
To clear and restart the control follow the below listed steps:
  1. Unplug or turn the circuit breaker off for 30 seconds.
  2. Reconnect the unit to the power source by turning the breaker back on or plugging the unit into the wall outlet.
  3. Wait for another 30 seconds to allow the control to recognize all components.
  4. Press the Pause, Cancel or Stop button twice to clear the display.
  5. To test operation of the washer,select Drain & Spin cycle, then press and hold the start button until the machine starts.
If the cycle does not start, there may be an internal component failure that requires service by a professional technician.
Note: General information for resolution is based on information provided in question. Please contact a repair technician if problem persist. Call Sears Repair Service 1-800-469-4663
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Aug 30, 2010
  • 84 Answers
SOURCE: HIT PAUSE CANCEL BUTTON TO ADD A GARMENT AND IT IS
unplug the machine wait 5 minutes and plug back in the board should go back to normal adding a garnment should be done on the washing not on the rince
Posted on Sep 12, 2010
blueextc3221
  • 15935 Answers
SOURCE: add garment light stays on after garments are added
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
Washer making a clicking sound, the tub isnt draining, and the add a garment stays on
Door switch isn't making. .if door isn't closed the washer won't run and will have the add garment light will stay on.
Oct 04, 2014 | Kenmore HE2 Plus Front Load Washer
Why is Whirlpool Duet washer stuck on add a garment
is the door lock light on?if not the lock switch may be bad, or the board may not be sending power to the switch.a volt-ohm meter must be used to test the system.
Jul 27, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer is stuck on lock mode add a garment
Hello, j2sonke. We're sorry to hear about the difficulty with your washer. Below are links to our Use & Care guides, Parts Diagrams, Troubleshooting information and the Service are of our website. We hope this helps! http://bit.ly/112Lu7q
Jul 03, 2014 | Kenmore 42822 Front Load Washer
Whirlpool washer duet is flashing after adding garmet. Will not return to washing
April 8 2002 DIV 26 SOURCE 110 KENMORE ELITE HE3 & HET WASHERS "ADD-A-GARMENT" INDICATOR LIGHT ON DOOR WON'T UNLOCK WHEN PAUSE/CANCEL BUTTON IS DEPRESSED.
MODELS: See additional page for Kenmore model numbers
COMPLAINT: Due to a Microcomputer Machine Control software error , the ADD-A-GARMENT feature becomes inoperative.
CORRECTION: The Microcomputer Machine Control must be replaced with a service part that has been reprogrammed to prevent ADD-A-GARMENT feature loss.
PARTS: Order electronic control listed on this service flash by model from Division 26 , Source 110 following normal ordering procedure.
MERCHANDISE CODES: WASHER Service Flash - Model Nurnbers for: Kenmore Elite HE3 & HE3t Washers: "ADD-A-GARMENT" indicator light on door won't unlock when Pause/Cancel button is depressed. Kenmore models with serial Numbers beginning with CSL23 through CSM04 11042822200 11042824200 11042826200 11042832200 11042834200 11042836200 11042922200 11042924200 11042926200 11042932200 11042934200 11042936200 Electronic conrrol p/n 8181900 Electronic control p/n 8181899
Jul 29, 2010 | Whirlpool GHW9300 Duet Washer
Kenmore h2 error code
Jan 11, 2010 | Kenmore 46462 Front Load Washer
I have a whirlpool ghw9100lw the light is flashing but it will not start
Aug 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
May 16, 2009 | Kenmore Elite 45986 Front Load Washer
Control Lock
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
201 people viewed this question
Dan Webster
Dan Webster
Sal De
