Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
I would like to know how to adjust the stove so that it sits level ?
    Problem Solver:
  • 4 Answers
Most stoves of this type have both wheels and screw adjusted levellers (generally in the front only).
The lower drawer opens to reveal these in the corners or a loose clip-on front panel needs to be removed by gentle pulling. The knurled wheel like knobs are generally turned anti-clockwise (Right to Left as you face the stove) to screw out and thereby lift the stove front up to suit your requirements. Good Luck.
Posted on Sep 16, 2010
How do I turn the temp down after oven has been on for a while. 'Loc on' message is showing and will not allow me to turn oven on.
Can you provide some additional details to help me help you? What kind of stove (make/model) and does it have any kind of self clean mode?
Without knowing the above details generally speaking of the oven is already preheated, to change the temperature you would hit the bake/preheat button to then adjust temp up or down with a digital stove. The dial stove from is self explainatory!
That loc on message may be because you have a stove lock lever or feature that prevents the stove from being opened when enabled, or when the stove is self cleaning. This may prohibit the adjust meant of temperature when the lock is on, or the stove is running through the self clean..
Again all just a general thought without knowing the above information... if you can post back or let me know is this was helpful in anyway to you! Thanks!!
Feb 13, 2017 | Ovens
Frigidaire oven won't stay lit
sounds like you have to much propane coming out at one to ignight and flooding it can u adjust the level,of propane that will help unlell u ignighter is a slack one getting old
Sep 14, 2008 | Ovens
My Frigidaire 30" gas stove is not leveled from
If you remove the bottom of the range, where the pan storage drawer is, you will see the leveling legs there, and you can use those to level the machine. Don't use pliers if you can avoid it, find an adjustable wrench or an open end wrench, the ones on mine are 7/16th. You can use a measuring cup filled to a line level, and place it on the stove as you move the legs, then you can better adjust them. Do so until the water levels off at the line you filled to. A final test will be to place a flat pan and only drop a couple drops onto it, and see if this runs to one side or the other.
Hope this helps, Please rate and comment, Thank You
Joe
Sep 17, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Need to set clock on oven
Instructions
    • 1
      Check the oven to ensure that it is off and that the timer isn't running. The buttons used to set the clock are the same buttons that adjust the oven, and you may end up making unintended adjustments to the oven.
    • 2
      Press the "Clock" button to enter the clock setting mode. The LCD will show the current time set on the oven.
    • 3
      Use the "Set Temp/Time +" or "Set Temp/Time -" buttons to adjust the clock to the current time. Depending on your model of stove you may need to use the "Hour," "Min" or the "Temp/Hour" up and down arrow buttons to set the time.
    • 4
      Save the new clock setting by pressing the "Start" button. Depending on your stove model, you may need to press the "Clock" button a second time if the "Start" button does not work.
Read more: How to Set the Clock on a Whirl Pool Stove ' eHow.com http://www.ehow.com/how_5692616_set-clock-whirl-pool-stove.html#ixzz1H3Wfexf6
Mar 19, 2011 | Ovens
My Dimplex coal effect black stove won't work. The problem started quickly. One time it worked, next it didn't. I have changed the fuse so that isn't the problem. Although the stove is about 12...
My Dimplex coal effect black Problem with the Dimplex Compact Electric Flame Stove Heater My Dimplex coal effect black stove won\'t work. The problem started quickly. One time it worked, next it didn\'t. I have changed the fuse so that isn\'t the problem.Although the stove is about 2yaer old, I have only used it about five times as it is in my drawing room that I sit in rather infrequently.I do hope you will be able to advise me the source of the problem.Thank you. salvador -
Oct 31, 2010 | Ovens
My stoves oven is burning my kitchen cupboards
If you could provide some more information, then I may be able to help. What part of the oven is causing the problem, i.e. top or bottom door. If the doors don't shut properly then this may cause the hot air to escape. If it is one of the doors, is it sitting square in the frame?
Feb 20, 2010 | Stoves 720EF Electric Double Oven
My propane stove oven pilot light works but main burner will not come on. It is a marine Kenyon Homestrand.
how do I adjust flame on the top of a new whirlpool stove. It is electric lite,propane stove
Nov 20, 2009 | Ovens
Kenmore gas stove Model 790
It could be that the sensor wire that controls the main gas valve is out of position. It should sit in the pilot light flame.
Look, and adjust if needed.
If it's ok, then you need a replacement main gas safety valve.
This should only be fitted by qualified personnel.
They do give up eventually after years of heating, and fail safe.
Dec 31, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Oven door stays slightly open
The unit may be out of plumb ( square to the floor ). I suggest you get a level and make sure the stove/oven is level and if it's not, there are some levelers ( where legs would be on the bottom ) that can be adjusted with needle nose pliers or a cresent wrench. If this doesn'e work, you may have some hinges sprung and need to replace them. Good Luck
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Whirlpool GBD307PDS Electric Double Oven
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
126 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
