Question about Kenmore 15879 Built-in Dishwasher
My dishwasher won't drain. It starts a cycle but doesn't finish draining the water. I checked the outlet hose and it's clear. I was able to siphon off the water and start a new cycle but the water still won't drain. Time to replace the pump?
  • Kenmore Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Sep 18, 2010
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Sep 28, 2012 | Dishwashers
The dishwasher won't drain completely. Leaves a little water when finished.
If the heater element in your dishwasher is working correctly, and there is still water left in your dishwasher when the cycle completes, you may have a clogged drain pump (located beneath the dishwasher). You will need to remove the dishwasher and disconnect the drain pump hose to check for clogs. You may also need to remove the drain pump and check it for clogs or correct operation. If the drain pump is found to be bad, replace it, else clear the clog and try again. If you drain hose is going to a garbage disposal unit, check the hose connection and check inside the garbage disposal unit for a clog. You may also want to check the hoses for a clog under the sink if your dishwasher is connected this way.
Jul 02, 2011 | Dishwashers
Slow or no drain of water. cleaned out sump covers and ran drain cleaner thru cycle. looking for possible secondary filter.
Hi, if the water doesn't drain from your dishwasher, check the drain line and pump..
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Hope it helps...
Jun 27, 2011 | Hotpoint Dishwashers
Kenmore dishwasher won't drain. Can hear motor trying to cycle but it sounds like it's locked.
Hope it helps...
Jun 23, 2011 | Dishwashers
What would cause my dishwasher not to drain?
not sure if you have posted the model number of your dishwasher.
There are several reasons for dishwasher not to drain.
1. faulty drain pump
2. clogged kitchen sink drain
3. drain cycle is not reached due to faulty dishwasher controller
4. clogged drain hose
5. the wash cycle is not completed due to heater not heating water - (try rinse cycle to confirm)
Happy to help if you can provide some details on when the drain cycle is not working. do you get any alarms on dishwasher..etc.
Feb 25, 2011 | GE Nautilus 24" Built-in Dishwasher
Cycle finishes but water is not draining
Sounds like too much water leftover.
Give me a make and model number of the dishwasher.
Check that the drain hose isn't kinked, and that where the drain connects at the garbage disposal at the sink isn't partially clogged. And, is the garbage disposal clean/clear of food stuff's.
I had a similar thing happen to me a few weeks ago, and it turned out the kitchen sink drain line was clogged.
Dec 16, 2009 | Cars & Trucks
Water drains out during wash cycle
it's being sucked out by siphoning through your sewer pipe .Probably a siphon problem . Check your drain hose to make sure hose is not stuffed too far down drain and air can get between the hose and the drain pipe . If you have tapped the hose to the drain to keep water from coming out the drain pipe , go to home depot or an appliance parts house , and get a siphon break . When a washer fills , but water level doesn't rise in the machine ,
Aug 17, 2009 | Whirlpool 24 in. DU930PWP Built-in...
Water runs into tub but does not fill?
be sure the drain hose is not lower than the wash tub this will caust the water to run out, 2nd be sure the drain hose is not pushed to far into the house stand pipe and the there is rome for air to go inbetween the drain hose and stand pipe eather of these will cause the machine to siphon mostly on rince cycle or on the 2nd and third loads you do. last your house drain could be starting to back up fill the washer with water and listen to it drain if you hear a gurggling sound in the house pipe you may need a plumber to cleanthis out for you.
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Bosch dishwasher
Good news is, this is unlikely to be expensive.
Need to sort out where it's coming from first.
Find a stopvalve you can use to shut off the water supply to the machine - there's probably one where the dishwasher is connected to the domestic plumbing. If turning this off stops the water coming in, you probably need a new inlet valve. The ones on dishwashers are generally pretty cheap to replace.
If shutting the water off doesn't stop the inflow, then the only place it can be coming from is siphoning back in from the drain. There's supposed to be either an air gap or an anti-siphon valve where the dishwasher's drain hose goes into the domestic drain. If this gets blocked/stuck, then it can cause dirty water to siphon back into the machine. Check and clear as necessary, then run the machine through on the hottest, longest cycle it's got (in the expectation that not all the water that was sucked in from the drain necessarily started out in the dishwasher).
A.
Apr 02, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
ASKO 1475 Does not not pump out and drain at end of cycle.
If dishwasher drains ok into bucket then fault is with the house plumbing
Jan 19, 2008 | Asko 24 in. D3250 Built-in Dishwasher
Kenmore 15879 Built-in Dishwasher Logo
125 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
