Question about Lexmark X9575 InkJet Printer
Prints a black thick line down the middle of the page when faxing
  • 4 Answers
SOURCE: Black lines through printed page
Hi, Defective cartridge I think
Posted on Mar 06, 2007
SteveLXK
  • 109 Answers
SOURCE: thick black line through page when copying or scanning
Sounds like part of your scanner is not functioning and reading black all the time. Probably best to return it for a replacement.
Steve
Posted on Feb 25, 2009
POCBM
  • 121 Answers
SOURCE: Faint grey lines Every 1/3rd of a printed page
This is the test to determine toner or fuser issue.
Print a test page
When you hear the paper feed into the machine open the top to stop the machine
Remove the toner cart.
You should be able to see the page with printing on it. (This is before the page hits the fuser)
If you can see the smudge or marks on the page the problem is most likely the cartridge or cleaning roller but NOT the fuser.
If the page is clean the problem is most likely the fuser.
Posted on Mar 14, 2009
SOURCE: Printing with lines primarily in the middle of page
30 pages please read manual...
Posted on Jul 07, 2009
  • 788 Answers
SOURCE: BLACK LINE RUNNING DOWN THE MIDDLE OF PRINTED
Try removing the print head and cleaning the surface with a worm/damp cloth or tissue.
Re-install and give it a try.
If you see any inprovement, you are on the wright track..
Posted on Sep 24, 2009
I am getting a thick black line in the middle of my printed document when I use my mfc 8220
I am going on the presumption that you are getting this thick black line when printing from your computer. It can be a couple of things but firstly remove the toner/drum unit from the printer.
Check that the blue tag at the end of the top end of the drum unit ( used for cleaning the corona wire or drum unit & slides from 1 side to the other. ), is in the correct left correct position. If it is in the middle then that is what is causing this mark. It should be on the side of the drum unit where the arrows match.
If the blue slider is not in the middle then have a look at the drum & see if there is a black mark around it. If there is then you will need to replace the drum unit.
If you are only getting this mark when photocopying or faxing then there is a mark on the small piece of glass at the left hand side under thye document feeder.
Jul 17, 2011 | Brother MFC-8220 Fax
I'M GETTING A THICK BLACK LINE DOWN THE MIDDLE OF MY. PHOTO AND UPLOAD. TRIED RE CALIBRATING WITH WHITE PAPER. DIDN'T WORK HELP
What printer do you have? Is the black line appearing on the paper when you print or when you fax/copy something?
If it is the latter, then there will be a mark on the optics glass that needs to be cleaned. Usually people using whiteout when wet causes this.
You will need to lift the cover where the paper goes through and check the glass
May 20, 2011 | Office Equipment & Supplies
When I copy or fax with my 4215 it leaves a thick black stripe down the middle of the page, but not when I print off the computer.
There should be somewhere for you to open the printer to see the area that reads the document (might be a small strip of glass), there could be something stuck on this area (tiny spec the width of your line), thus causing the lines on the scan and not the prints. I am not too familiar with that model, so that is the best I have for you. Hope it helps.
Aug 24, 2010 | HP OfficeJet 4215 All-In-One InkJet...
Faxes are printed with a line running down the
If the line is on the back you need a shop to replace the ink absorber and put in a mylar shield to keep the ink from coming back up on the rollers.
Sep 29, 2009 | Canon PIXMA MP530 All-In-One InkJet...
When copying or printing a fax, a vertical black line 2-3 mm line
try cleaning the rollers with water in the feeder at the top check the glass too too see if it's dirty
Jun 27, 2009 | HP Officejet 6310 All-In-One InkJet...
PANASONIC FAX MACHINE PRINTING BLACK THICK LINE
Open the front of the fax machine. Then pull down the the tray that has the down arrow imprinted on it. Locate the glass strip towards the back, just behind the center roller. Use a cloth and rubbing alcohol to clean the glass and that should remove the black line.
Apr 22, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Black line going down the middle of the page
lift the auto feeder and clean the scanner glass that your pages scan across -it is dirty. You can make a copy afterward and this will tell you if you have solved the problem.
Mar 05, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
Brother fax
The drum cleaning blade is worn out. You must replace the Drum Unit.
Apr 18, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Thick Black Line in Middle of Printed Document!
Your question might best be answered at the website below
http://www.canon.co.uk/Support/index.asp
They have technical support plus drivers and other odds and ends concerning your equipment
Feb 22, 2008 | Computers & Internet
Thick Black Line on my copies and faxes
Can't image it being anything but scan glass, if prints are fine, are you sure you cleaning scan glass(inside of where originals are fed)?
If so then scanner lamp faulty, but I've never come across it myself on this model.
Oct 26, 2007 | Brother MFC 8500 All-In-One Laser Printer
Lexmark X9575 InkJet Printer Logo
42 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
