Question about ViewSonic PJ458D Multimedia Projector
Source not found
Our projector was working but this time when we went to use it the source could not be found. We checked the cables and all is well there. Any idea's?
  • 563 Answers
Hi clwhittaker
Try holding in the Fn ( function ) button and pressing the key in the F-row of buttons that's got one or two screens on it. This pushes the signal to the Projector.
Posted on May 19, 2008
  • Christine Decatus Sep 24, 2013
    English teacher from low-income high school sends her exuberant gratitude!!! Saved my lesson.
I have the same trouble and ant of the F5 solutions works with me... any other idea?
Posted on Nov 08, 2009
2 Suggested Answers
SOURCE: ipaq mp3800 projector--no source found check signal cable
compaq pesario c700 audio drver for this link
Posted on Jan 06, 2009
Cannot get image on screen from xbox 360 to mp3800 using hdmi to dvi cables
mp3800 can not got the HDMI source,even if you use the "HDMI TO DVI" cable
any questions, feel free to ask me
have a nice day!
Jerry Lampdeng Limited
Feb 12, 2014 | Compaq iPAQ MP3800 Multimedia Projector
I have an optoma tx1080p projector and Yamaha receiver. Recently we started getting the problem where the projector keeps saying that the source is not found. When I connect the hdmi cable directly to the...
This is most likely a problem with what's called "HDMI handshake." It's a silly protection scheme called HDCP that is meant to keep people from copying content. The best thing to do is unplug everything, then turn on things in this order: receiver>projector>sources (directv, Bluray). If that does not work, check for firmware updates for the receiver or projector.
Oct 29, 2013 | Audio Players & Recorders
No source found - please check signal cable
Well...first check the cable and replace it if you have one. If you can try a different input. Make sure the proper input is selected on the projector.(if you are plugged into input 1 make sure that input is selected for viewing).
Jan 09, 2013 | Office Equipment & Supplies
"No source found"
Have you tried another laptop? You might also try hdmi if you can. Many times this is the mother board of the laptop. In windows 7 use the windows and P button?
Dec 06, 2012 | Optoma EP1691 DLP Projector
Casting a blue tint
This could be for a variety of reasons.
First, check all your connections to make sure everything is connected properly and undamaged. If you are using a VGA cable/computer cable, make sure the pins are not bent.
Next, check the cables themselves. I do this by flexing the cable back and forth, starting at one end and working my way to the other. Go slowly and make sure to do this every few inches. If there is a damaged wire, this will cause the image on the screen to flicker or change color. Any damaged cables found should be replaced.
If this does not work, try removing individual cables and using a different one. Do this one cable at a time in order to try and identify where the problem might be. This is assuming you have spare cabling.
If everything is connected properly and nothing appears to be damaged, go into the projector menu and check all your color settings. You'll see you have a variety of options. If these are set to default and you still have discoloration, the problem is most likely internal and may require a technician.
One additional option is to check the data source to make sure all the settings on that are correct as well.
Apr 04, 2011 | Hitachi CP-X328 Multimedia Projector
After switching on the projector displays message 'searching for source' then 'no source found'. Computer is connected to Optima EP7155 using vga cable.
1 check VGA cable for damage (try other cable)
2 check connections
3 make sure you have resolution on PC is faling in projectors resolution range
4 if it is laptop, make sure you have it in external monitor mode (usually Fn + F8 keys)
Mar 01, 2011 | Optoma EP7155 Projector
I can't get a picture when I hook my projector up to my laptop.
HELLO,
If your LCD or DLP projector displays no image, this could be a variety of problems. First, check that the projector has power. On the top of the LCD or DLP projector should be some lights. With power, those lights will be on. If it has power, check to make sure that the projector lamp is firing. If so, go to the source. Make sure that it is connected with a VGA cable or USB cable to your computer, or with an RGB cable, S-Video cable or DVI connection to your VCR/DVD Player. From a laptop computer, the VGA cable should be connected to the VGA out connection, and into the VGA in connection on the projector. Are both ends tight?
If everything has checked out so far, the solution probably lies with the external monitor port. Check this by holding the Fn key on the keyboard, then press the F7 key. (On some computers, the key might be F5 or F3. Try these if F7 doesn't work) Each time you press the Fn / F7 combination, you will cycle your display through the following settings:
* Press Fn / F7 once: The laptop screen only
* Press Fn / F7 twice: The projector port only
* Press Fn / F7 three times: Both the laptop and projector port
* Wait a few seconds after each time you press the key combination to let the LCD or DLP projector refresh. Nine times out of ten this will result in seeing your projected image.
Hope this helpout....
Jun 17, 2010 | HP Digital Projector Vp6110 Multimedia...
Blue screen appearing
not matching resolution. reset the settings to factory default. if it still has the problem, then swap cables. there may be a short or a break in the cable or connector.
Nov 02, 2009 | InFocus In2102 Projector
Projector signal goes bad after 25 minutes
It appears the projector was over heating. Why it affected the DVD signal and not the computer signal, I do not know. The other confusing thing was the projector was hanging off the ceiling and should have had plenty of circulation. When I climbed up to check for excessive dust, I found that the lens cap had been placed over the intake vent. I blew off the dust and removed the cap. After running the projector for an hour, it appears that the problem has been solved.
Sep 22, 2008 | Dell 4100MP Multimedia Projector
ViewSonic PJ458D Multimedia Projector Logo
660 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
