Question about Maytag MAT12CSD Top-Load Coin Operated Washer
CHANGING THE MONEY AMOUNT ON A DIGITAL COIN OP MAYTAG WASHER MODEL# MAT12PDBAW
I JUST HAD THE SAME QUESTION FOR A CUSTOMER REQUEST, I TALKED TO THE TECH SUPPORT AT MAYTAG AND THEY EXPLAINED THAT ALL YOU DO IS UNPLUG THE CONNECTOR CC FROM THE PRINTED CIRCUIT BOARD THEN SCROLL WITH THE CENTER BOTTOM BUTTON, TILL YOU SEE 600 DISPLAYED. (600 IS ZERO COINS, 604 IS 4 COINS, 608 IS 8 COINS, ETC.) THEN RECONNECT THE CC CONNECTOR AND PUT IT TOGETHER, SOUNDS SIMPLE ENOUGH. IM GONNA GO TRY IT
Posted on Oct 15, 2010
WHy won't my washer finish its cycle?
check lid switch first, this is most common.(machine thinks lid is open), carefully lift and lower lid an you should here a faint click. otherwise i hit some timer issues but not so common. there is no reset, the model you gave comes back as electro-mechanical and not electronic
May 10, 2014 | Maytag MAT12PD Top Load Washer
Coin completely jammed in vertical coin drop mechanism
unplug the machine,open the top of the coin op i use a stubby 5/16 nut driver,you have to remove the rod and it's a 5/16 inch rod,turn it counter clockwise to remove,this rod holds the unit in place,when you have the rod out then you can grab the front where you put the money in and lift it up and out,it sits in a couple of slotted holes
Nov 11, 2017 | Maytag MAT12CS Top Load Washer
Program computer-Maytag commercial washer mat12pdbaw
Try going to this website and scrolling down to find your Maytag Model number. Click on the model number and the programming steps should come up for you.
Anonymous
Apr 14, 2009 | Washing Machines
Coin-op dryer: changing the length of the cycle
that is correct, there a re multiple "cams"/discs that will increase/decrease times, they should be inside the lock box atop the machine, they come with the unit when delivered and that s the likely storage spot for them
Mar 25, 2009 | Whirlpool ET8CHEXSQ Dryer
Lost coin op washer keys
you need a locksmith.  Because of the key design
Mar 11, 2009 | Maytag MAT12CS Top Load Washer
Maytag coin-op top load wont spin, motor runs, belt burns.
it not a belt, there is a $20 plastic and rubber coupling between the motor and the transmission that has broken.  It needs replacing.
Dec 25, 2008 | Maytag MAT12CS Top Load Washer
Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Sep 07, 2007 | Maytag MAT13MN Top Load Washer
Whirlpool coin operated washer and dryer
you need to take the coin slot out by using a socket wrench. then you need to flip the slot over and take the screws off. there is going to be two more screws to unscrew. take off that piece and also the claw like coin catcher. form here on out you should be able to remove as many slots as you need to.
Sep 06, 2007 | Washing Machines
Maytag MAT12CSD Top-Load Coin Operated Washer Logo
1,265 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
