Question about Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet. It will not turn on. There is power to the machine and power to the control panel. Does this mean the control panel is fried or is there another possibility?
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
On Whirlpool duet steam front loading DRYER...What does the error code F70 mean?Do you have to have a certified whirlpool appliance service professional to repair?
F70 code says...
Replace the machine control electronics. You should first unplug the machine and then remove and plug back in all connectors on the front panel model as well as the electronic control module.
If that doesn't take care of the problem then it may be time to consider replacing the rear board. The FSP # 8183259
The control board is part # 14 in the link below.
Sears parts direct /Whirlpool-Parts/Model-WFW9400VE01
Mar 13, 2015 | Whirlpool Washing Machines
Whirlpool Duet washer stuck in "control locked"
Press and hold the end of cycle button for 15 seconds this should clear it.
Control locked
Nov 26, 2010 | Whirlpool Washing Machines
Is there a fuse box on the Whirlpool duet steam washer? I can not get the control panel to turn on. I've checked the circuit breaker.
If you have a control panel and it wont switch on, it normally means your board is faulty. Gain access to the board and look for the live(brown) wire and the blue(neutral) wire. Place a tester on the 2 wires and see if you have the required voltage. If so, your board is defective. Normally, there are no fuses in the front loaders.
May 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control locked light is on my Whirlpool duet ht washing machine. What can cause it?
The Control Lock is a safety feature that allows the consumer to lock the control panel to prevent small children from manipulating the controls. It can inadvertently be set following a power outage, or by leaning against the control panel. The following link explains how to turn the feature on/off:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
If this does not correct your problem, then you may have a more serious problem than a simple operator control issue. If you need further assistance, please let me know. I hope this corrects the problem for you.
Nov 11, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
What does control lock mean?
This means that the machine will not respond to any controls and will have to finish its current programme completely before it will respond to any operator controls again. It is very useful to stop anyone changing the programme mid cycle. It also means that if the power is cut or you have a brown out that the machine will just carryon where it left off and finish the programme.
To unlock the Control Locked feature:
Press and hold the End Of Cycle Signal button for 3 seconds to turn this feature off.
When the machine is running and Control Locked light is on, the machine can be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
Oct 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Need to reset a whirlpool duet washer
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Oct 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet accidentally put into "control lock". How do you reset it?
The following link explains how to correct the control panel lock issue on a Whirlpool Duet:
The control panel lock is actually a designed safety feature that allows you to lock the control panel to keep small children from manipulating the controls. It can be inadvertently set by leaning against the control panel buttons, or following a power outage.
If you have questions, please let me know. I hope this helps you.
Oct 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
What id a F28 code on a whirlpool duet washer
Can be the machine control or the motor control here is a link to the Repair manual....
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/6545d78b3f479480852571650061b1ba/$FILE/8178558.pdf
Sep 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WHAT IS 'CONTROL LOCK' ON THE WHIRLPOOL DUET
Control Lock is a designed safety feature that allows you to lock/unlock the control panel to prevent small children from manipulating the controls. To lock or unlock the control panel, click on the following link:
If this does not fix your problem, please let me know. I hope this helps you.
Jul 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
19 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
