Question about Nokia 5310 Cellular Phone
My phone keeps turning off two or three seconds after I just barely turned it back on.
  • 358 Answers
Hello,why the phone is still shutting down is because the cell of the battery is weak and can power on the phone for to long, that's why it shots down so quick,
You will need to replace battery with a new one for longer talk hours.
Make sure you charge battery for 6hours before use.
If not battery, in think you will have to flash the phone memory for it to come back to life.
The other thing to check is if the phone memory is weak and may need to be restored
back the phone memory.
will need to be flashed.
if too weak to power up the phone all application you downloaded on the phone has VIRUS and has affected the phone memory.
You can use the link below to know about how to flash the phone.
hubpages.com/hub/How-to-Flash-your-cell-phone
and
(unlocktotalk.com/UnlockCodeInstructions.htm),
Take care.
Posted on Sep 16, 2010
My 2001 ford focus keeps locking. The power locks automatically lock as soon as I unlock them, barely enough time to open door.
Your Focus may be equipped with the autolock feature. Try this:
To deactivate/reactivate the autolock feature using the power door unlock control
You must complete steps 1-7 within 30 seconds or the procedure will have to be repeated. If the procedure needs to be repeated, you must wait 30 seconds.
1. Turn the ignition key to ON.
2. Press the power door unlock control three times.
3. Turn the ignition key from ON to OFF.
4. Press the power door unlock control three times.
5. Turn the ignition back to ON. The horn will chirp.
6. Press the unlock control, then press the lock control.
The horn will chirp once if autolock was deactivated or twice (one short and one long chirp) if autolock was activated.
7. Turn the ignition to OFF. The horn will chirp once to confirm the procedure is complete.
Feb 18, 2015 | 2001 Ford Focus
Clock did not spring ahead to correct time
Try the following in order:
Step One: Check in your phone settings and see if there's a setting for turning Daylight Savings Time on/off. If so, make sure DST is turned on. If your phone's clock is still wrong...
Step Two: Put your phone in airplane mode (if it has one) for about 60 seconds, then turn airplane mode off. If it's still wrong...
Step Three: Power down your phone for 30 seconds, then turn it back on. When your phone is done turning on, check the clock. If it's STILL wrong...
Step Four: Pull the battery out of the phone for 30 seconds, then put the battery back in. Sad to say, but if it's still not working at this point, there's most likely something wrong with the phone, so you should consult any warranty or service plan options you have, or purchase a new phone if you have no warranty/SP options.
Hope this helps!
Mar 14, 2014 | straighttalk.com
I replacsed th wiper transmission and now the wiper fuse keeps blowing I did not work on any thing but that
Does the fuse blow when the wipers are off or when you turn the wipers on? A fuse blowing means either a short circuit or an overload. Lets say that your wiper transmission is new and working properly, then an overload is probably blowing the fuse which is caused by the circuit pulling to much current because something is not aligned correctly and moving freely when the wiper motor is turned on. Before you connect the arms to the transmission, move the arm assembly manually with your hand to make sure the wipers go across and back on the windshield. This will verify that the arm assembly is moving freely and not jamming. Then turn the wiper transmission without connecting the wiper arms and see if the transmission is working properly and not blowing the fuse. This will verify that your wiper transmission is not defective. Check the wiring going to the wiper transmission for any bare spots or nicks on the wire insulation. If you have a bare spot or nick that is touching metal, the fuse will blow (this is called a short circuit). If you find a bare spot or nick on the wire use electrician tape to insulate the bare spot or nick. Usually three wraps of electrician tape around the bare spotor nick will do the job. Oh, make sure to replace the fuse with the correct amp fuse. Your car dealer auto parts can provide the information (over the phone) on the correct amp size. You can purchase the fuse at any auto parts. FYI: Too small an amp on the fuse will blow when the wiper is turned on. Too large of a fuse will cause the wiring to burn if your wipers should stop shifting and jam. Good Luck. Hope this helps.
Mar 07, 2014 | Chevrolet Cars & Trucks
Abs lights flash back and forth. They don't turn off. Right turn signal won't flash, bulb tests ok. Right rear turn signal flashes very fast. Left turn signals all normal.
Hi, you could try re-setting the abs. To do this you will need a length of 2amp cable about 500mm long, fix a small crocodile clip to one end, remove seat and search for a three pin blank connector, when you have located this put key in ignition but do not switch on at this point. Bare the end of the wire and insert in CENTRE hole of socket, put croc clip onto a good earth, then press abs button at the same time turn on ignition, count for 30 seconds, let go of abs button, switch off ignition, remove cable, put seat back on. This should reset abs. Sit back and have a beer. Cheers.
Aug 12, 2010 | 1993 BMW K 1100 RS
I dropped it in a toilet for no more than three seconds. I immediately removed the battery and sim card and soaked the phone and battery in rice for a few hours. The water damage sticker is white but the...
the first step is to take the battery of the phone and place both the the phone and the battery in a zip lock bag with rice and leave it for three day and then put it back together and the phone should turn on
May 18, 2010 | Cell Phones
The camera keeps on changing back and forth to main and secondary camera. It also automatically goes of in a few seconds after it is turned on.
try formatting the phone by folloeing this step
just format the phone by swtiching off the phone first wait 30 seconds now hold the three buttons toghther that is calling key ,numeric pad no. 3 key and * key and swtich on the phone wait for it to show formatting and you can unlock your phone easily but your data in the phone memory will get erased but the sim memory and memory card will not erased
if even though its not working better take to ssrvice center they will be able to fix it.....
Nov 03, 2009 | Nokia N70 Cellular Phone
External buttons not working and battery acting up
Same with me! My OK and # buttons constantly stop working X-X I just have to hold them down, keep hitting them, or hit them with another button. But usually Ill have to open the phone.
May 29, 2009 | Verizon Communications enV2 Cellular Phone
My Motorola Battery Refuses to Charge!!
you may have a damaged battery contact, my suggestion is to get it serviced
May 07, 2008 | Motorola Mobility RAZR V3
Mi phone wont turn on properly
BDEATH HERE. I KNOW THE SOLUTION TO YOUR PROBLEM.. TAKE OFF THE BATTERY AND PUT IT BACK AGAIN. THEN <<<>>> AND THE TURN ON BUTTON >>>> EXPERT FINGERS TO DO THAT :) KEEP HOLDING THESE THREE BUTTONS AND THE TURN ON BUTTON AND THE DEVICE WILL DISPLAY ''FORMATING'' THEN LEAVE THE BUTTONS AND LET IT FINISH.. TATTAA FINISH AND IS GOOD AS NEW!! THATS ALL!! AND SOMETHING else if you have some seconds before gets crazy try dial *#7370#. it might reset your phone to the factory form which is good!!!!
Sep 03, 2007 | Nokia 6280 Cellular Phone
Nokia 5310 Cellular Phone Logo
143 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
