Question about Cuisinart CWC1600 Wine Cooler
I have a Cuisinart Wine Cooler, and the temperature display always read "- - -" When I try to set the temperature by pressing the up or down button, it briefly, (less than two seconds), shows a temperature then reverts to "- - - ". Also, the bottom LED in the right number displlay array is out. Either it is not receiving a signal, or there is discontinuity in the circuit, such as a split in a foil or a bad solder connection. Any help would be greatly appreciated.
bobotfel
  • 236 Answers
SOURCE: Wine cooler gets too cold (freezes)
Check your thermostat setting, if the setting is ok then something wrong with your thermostat control.
Posted on Jan 21, 2008
  • 171 Answers
SOURCE: Haier Wine Cooler
Hi LinnieMcAdam,
I'm Harvey the Master Plumber.
Your question is: Where can you find a 10 Watt replacement light bulb for your Haier Wine Cooler?
I usually have success at the hardware store. Start there. Then you can try the store where you bought it or call Haier.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 14, 2008
SOURCE: Cuisinart Wine Cooler
If you call (Cuisinart’s service center (800) 726-0190), they will send you a brand new unit for $10.00.
Happy Holidays,
AC Freeborn
Posted on Dec 02, 2008
  • 286 Answers
SOURCE: uline wine cooler 2075wc doesnt work, light goes on ????
If nothing runs but the light is on then change the thermostat. #2767-1 and you can find a part from a distributor. To find one visit www.u-line.com and under customer service you will see parts locator
Posted on Jun 15, 2009
  • 28 Answers
SOURCE: sub zero wine cooler showing 78 and76 and says
Clean the condenser located under the unit. This may help. However, more serious problems involve refrigeration leaks shorted thermistors and non running fan motors. All are common. I recommend an authorized Subzero tech for this unit if cleaning the condenser does not help.
Posted on Sep 27, 2009
My wine cooler will not run at all. The compressor is Ok. The cooler uses relay 41006036 rev E. I do get continuity on both the pot and the thermistor. What is the correct resistance for the thermistor...
Hi
Please check this link to read detailed information related to wine cooler as per your query:-
http://www.winecoolerexpert.com/wine-cooler-faq.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
May 05, 2011 | Marvel (6SBARBSG) Wine Cooler
Cuisinart wine cooler temperature display 2 dashes
Check Owner's manual troubleshooting. Or usually MFG customer service will help if you are nice about your question.
Apr 28, 2011 | Cuisinart CWC1600 Wine Cooler
Wine cooler displays temperature setting but does not run or cool wine.
It's 1 of 3 things...
A. The fans are not turning. Remove the back, and see if the fans are getting 12 volts, and spinning freely. Remove them and clean off the dust from the heat sink.
B. The Peltier Chip is shot. If the fans run, check for 12 volts on the power connector that's on thelower left of the curcuit board. If there's power, but no cooling, the Peltier is shot. These are available from E-bay for ~$13, but it's a major dissassembly to get it out.
C. If you don't get 12 volts to the fans or the Peltier chip, replace the circuit board.
Dec 15, 2010 | Cuisinart Private Reserve CWC-600 Wine...
Viking Wine Cellar Temperature Near-Freezing
Viking wine coolers are made by Marvel.They all had issues with freezing the contents. If you replace the electronic cold control system it will be fine.If you don't, it will freeze the wine popping the corks and leaking in the unit.If you get the parts from Marvell they are much cheaper.
Jun 01, 2010 | Viking VUWC141 Wine Cooler
Chamber wc902 wine cooler which wont set temp
I have the same issue especially when there is a power outage. To reset it, press the preset until "1" appears, then adjust the temperature as low as it will go by repeatedly pressing the temperature "-" button. Usually works.
Oct 08, 2009 | Tower Chambrer WC601B 7 Bottle (6+1)...
Can't change temperature
You press set button and then + and -, if that does not work, the stat is faulty.
Mar 09, 2009 | Haier BC112G Wine Cooler
Cuisinart CWC1600 Wine Cooler Logo
87 people viewed this question
Top Cuisinart Refrigerators Experts
Darrell
richie46
Are you a Cuisinart Refrigerator Expert? Answer questions, earn points and help others
