Question about Dell 2300MP Multimedia Projector
Works for 20 to 30 minutes then it just cuts off
Works fine when you turn it on then after 20 to 30 minutes it just goes to black as if it has turned off from getting to hot???
Whats the fix and who can fix it and how much do you estimate the fix will cost??
Bob Hall
Bhall68334@aol.com
Thanks!
All I can think of is check the fan and see if you hear the fan running.
Posted on May 17, 2008
Why when i cut my laptop on it turns on then screen goes dim then turns black after a few minutes
Had you recently charged your battery? how old is the computer and the battery? If you write again, please tell us the make and model of your laptop.
May 20, 2014 | Gateway NE56R41u Dual Core B960 4GB 500GB...
Screen and sound cuts out at times.
I would check the power board capacitors. Many people are losing the electrolytic caps on these boards. It is possible yours are failing only when they heat up.
Apr 13, 2013 | Televison & Video
I can turn on the tv and it's fine for about 20 min then the screen goes black with sound. I turn it off for a minute and it's fine for another 20 min. Like it's overheating.
It might also be a bad solder connection, short of checking voltages what I have done in this type of situation is with back off use a small fairly high speed fan - a hair dryer set to cool works, to cool areas of the boards inside to localize which board is causing this, with the set in failure, got it? it goes out cool it with a handheld hair dryer with air set to cool, when you find the spot where the problem is it will either instantly come back or try to.
Do it a few times to confirm which board is bad and locate a replacement board and swap it out.
Dec 15, 2012 | Proscan 47LB45H 47 in. LCD TV
Screen goes black on toshiba tv how to fix
I would check to see if any capacitors have gone bad or are going bad.
Oct 07, 2012 | Toshiba 32A60 32" TV
Latitude B130 screen works great then cuts out to complete black, works with external monitor
Are you sure that the display is not set for external monitor only? Also take bright flashlight and shine on the display. If you can see the images then the problem is with the back light and usually caused by a bad inverter. Some times you can get the back light or inverter bu most times it is easier and cheaper to replace the entire display.
Aug 20, 2012 | Dell LATITUDE Computers & Internet
TV works fine for about 3 minutes then the picture goes black and the red light on the front of the TV starts blinking. The sound works the entire time. If I shutdown the TV and wait a few minutes and...
The light is blinking a code. The code will be a series of blinks, a pause and the blinks again. Phone Sony service and give them this code. They will be able to advise you as to the problem.
Apr 03, 2010 | Sony KP-53HS30 53" Rear Projection...
TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Jun 15, 2008 | Mitsubishi WS-73713 73" Rear Projection...
LG LCD Tv picture goes black but the sound still works
Next time it goes dark do a flash light test to see if your inverter board is fubar.
May 03, 2017 | LG M4200C 42 in. HDTV-Ready LCD Television
Dell 2300MP Multimedia Projector Logo
118 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
