Question about Kenmore 20.3 cu. ft. / 575 liter Upright Freezer 23024
New freezer not freezing
I just bought a new freezer and it has been plugged in for over six hours and the temperature is not going down. What can I do?
  • Anonymous Mar 30, 2014
    just bought it and came home placed and plugged in and 24 hours later it still is not freezing.
  • 828 Answers
If it is a new freezer and it is plugged in and the control is turned on the power light should also be lit. After six hour of operation it should be cooled down. Call the place you purchased it from and tell them the problem. It is possible that you got a defective unit.
Posted on May 17, 2008
Freezer losing temperature
Hi Julie. I'm Roger. It sounds like the operating thermostat is not working When not in the fast freeze mode. Can you here a click sound from the thermostat when turning the temperature up and down short of fast freeze? We normally charge them to operate at -10 to -20 degrees. The inside temperature will normally only reach a temperature around 18 degrees warmer. The operating thermostat should allow you to regulate its temperature any where from that capability up to where you want it. See if your thermostat makes a clicking sound when adjusted. The warning light comes on because it knows the box temperature is higher than it is set for and is warning you of that. If it uses a printed circuit (PC) board, the click will dot be very loud. listen closely. Let us know how this turns out for you. We have very good refrigeration techs. here. Someone else here may have an idea too.
Jan 23, 2014 | AEG Freezers
My freezer has a different code number;ZFT710FW.I put quite a lot of food into the freezer yesterday and the alarm now keeps sounding,I have put the temperature up but the red light is still flashing...
Red Alarm Indicator Light
Under normal operating conditions, the internal temperature of the freezer will ensure the long-term conservation of the stored food. When such temperature rises above a certain level (-12 °C), the appliance will trigger an acoustic and light alarm. The light alarm is a blink red light (Red Alarm Indicator Light), while the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing the Acoustic Signal Stop Switch once.
When switching on the freezer for the first time, the Red Alarm Indicator Light will blink until the internal temperature has reached a level required for the safe conservation of frozen food.
Fast Freeze function
If more than 3-4 kg of food is to be frozen:
1. Press the Fast Freeze Switch for 2-3 seconds to activate the fast-freeze function 6-24 hours before placing the fresh food in the freezer, the Yellow Fast Freeze Indicator Light will illuminate. The compressor will now run continuously, to ensure that the fresh food is frozen as quickly as possible.
2. It is possible to deactivate the function at any time by pressing the Fast Freeze Switch for 2-3 seconds.
3. Place the foods in the freezing compartments (indicated with graphics).
4. Once the food is completely frozen (it may take up to 24 hours) you can manually switch off the fastfreeze function by pressing the Fast Freeze Switch for 2- 3 seconds and the Yellow Fast Freeze Indicator light will also go out.
5. Move frozen food from the freezing compartments into the other compartments (storing compartments) to make room for another freezing.
If the Fast Freeze Switch is accidentally left on, the fast-freeze function will be automatically switched off 48 hours later. The Yellow Fast Freeze Indicator light will also go out.
I believe that you all understand. If you intend to freeze larger amount of food then certainly a few hours before some shopping switch on the fast freeze function.
Dado
Apr 26, 2013 | Zanussi ZFT710W Freezer
New 5 cu ft chest freezer cycles on every 30 min. Grumbly sound. 1 notch from 'coldest it only reaches 5 degrees. Freezer 3/4 full.
look in your onwers manuel and it should tell you what your temperature for the freezer should range from.if it was not giving to you when you bought the freezer then it should be behind the pannel down where the compresser is taped to the side.but as you know any thing below 32 degrees is freezing so 5 degrees is pretty cold.i dont under stand about the noise but if you think your freezer is not working right and if it is new then call place where you got it and tell them your concerns and then they should send a technician out
Feb 18, 2013 | Freezers
Why is my freezer not freezing
I had this happen to my freezer and I had to install a fan in the freezer by a repair man and then it worked like brand new.
Jul 18, 2012 | Bush BAF55143W Freezer
I have a Rank Arena BF260 freezer I got from my dad. There is a switch on the front, if it is to the left, there is no icon on it, if it's to the right it has a snowflake icon show. Dad didn't even realise...
It is the fast freeze switch. It keeps the freezer full on even if it gets down to its operating temperature. You will see the yellow or orange light come on. You do this if you want to add some new item in the upper fast freeze compartment. Make sure you turn it off after about 2 hours.
Oct 17, 2010 | Freezers
We have bought a new american style fridge/freezer and it was delivered yesterday. We have left it on for 24 hours and the temperature is not going down the fridge wont go below 12 degrees and the freezer...
ambient temp 10/35 degrees C.not in direct sunlight,
did you use a level to make sure that it is level in all planes,just to make sure all the door seals are tight,
(look along the seals to make sure)the unit should be left on for at least 24 hours in its chosen position with the doors shut,then check temp,it could take another 12 hours to settle down once loaded.Also make sure that its not touching the wall cuts down on vibration.
once checked,if still not right call samsung..they are good.
Apr 04, 2010 | Freezers
I just set up my Frigidaire upright Freezer, only
Rule of thumb, if you lay a frig/freezer on side let sit upright at new location for 24 hours before plugging it in.
Mar 07, 2010 | Freezers
Would a bad thermostat cause my danby to not completely freeze?
Should operate 24 hours before putting anything in that is not already frozen. Check it again after it has run for 24 hours. Anytime you adjust the thermostat go one click at a time and wait 24 hours for it to stabilize.
eric
Jun 30, 2009 | Danby 3.6 cu. ft. / 102 liter Chest...
My brand new freezer wont freeze
I would plug it into a different plug in - not one that is on the same circuit that it is plugged into now. If the plug in is working for other things, it still may be bad and not able to handle the load of the freezer. If your freezer will not work on a completely different circuit, then there could be something wrong with the freezer, but it is not likely since two of them should not be bad. Seems to me more like an electrical problem in your location. Hope this helps you, Rick
Apr 28, 2009 | GE Freezer  14.8 Cu. Ft. Manual...
Changing Freezers
If your products are already in the frozen state the answer is yes, you can make an immediate transfer. Normally a couple of hours run to allow the temperatures to stabilize is sufficient. The cool down run time also insures the the unit is functioning properly. If you plug it in and transfer the products right away make frequent checks to insure proper operation.
Aug 16, 2008 | Nor-Lake Freezer Norlake Refrigeration 6'...
Kenmore 20.3 cu. ft. / 575 liter Upright Freezer 23024 Logo
151 people viewed this question
Top Kenmore Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
