Question about Zoom H4 Handy Recorder
Zoom H4 recorder ver 1.30 says no card although card is inserted?
Hi. Not sure you still are in need of a solution but since my machine was doing the same thing last night, and I was able to solve it, I thought I'd post anyway.
For my machine, which has a more current OS than yours (mine is 2.20 I believe), I was receiving the same message after transferring material onto the computer. What needed to happen was to reformat the card. If you press "menu", the click on "file" you should have an option to reformat the card. It worked for me and it now works.
Hope that helps!
Posted on Oct 15, 2010
  • Keith Brown
    Keith Brown Mar 24, 2011
    if you reformat your card, you will lose the music you recorded, if you can pull the SD card out, plug it in to your computer (if you have a card slot) if you don't you can buy one farily cheaply and it will download the files to your computer more quckly than with the device.
I've bought a SDHC card 32 GB but Handy Recorder H4 do not recognize the card. I've tried to format it at the pc, but no way, the message is "no card"
Verify the device and card reader support SDHC. Try a 2g card and see if that works, typically anything 4g or larger is SDHC, older devices can not read such cards. It is quite possible that the card is bad.
Oct 14, 2011 | Zoom H4 Handy Recorder
My Zoom h4 has been struggling for a couple months now. Most of the time I get either an error message concerning the card or saying the card is full. Even when the card has been reformatted both on my pc...
Make sure the batteries are good... some people try to use re-chargeable batteries and because of their lower voltage they cause problems. First thing is to try new batteries.
Feb 12, 2011 | Zoom H4 Handy Recorder
When I turn on my Zoom H4n, it says "no card" even though I have a card in it. Why is this? How can I fix this problem?
My zoom h4 will not turn on at all....not with new batteries or the AC adapter.....any suggestions? Worked fine last time used.
Feb 13, 2010 | Zoom H4 Handy Recorder
I have a h4 recorder and when i turn it on i get a no card reading .changed card still same message
Are you using the type of card recommended in the manual? There's also an update here that you might like to have:http://www.zoom.co.jp/english/download/software/h4.php
Sep 11, 2009 | Zoom H4 Handy Recorder
Is there any way to reset the H4 back to factory settings? I adjusted levels and everythings out of whack now.
Hello.
Do you havce the manual to the H4? If not, I will provide you with a link to the PDF manual online. In thoroughly scanning thfe manual, there is no general reset function (in the manual, that is). It would be advised to call Zoom (who are very easy to work with) and ask them if there is a factory reset procedure which is not in the manual.
The manual for the H4 is very comprehensive, and there are default settings for many areas of the recorder. You could use this manual to reset your adjustments manually.
Here is the link to the manual:
http://www.samsontech.com/products/relatedDocs/H4_manual.pdf
Thanks for using FixYa
Aug 15, 2009 | Zoom H4 Handy Recorder
H4 zoom battery operation
try resoldering the circuit board where the power socket is ... as there is a switch on the socket that disconnects the batterys
Jul 02, 2009 | Zoom H4 Handy Recorder
Zoom H4 recorded data disappearing
I have a H4 but not that problem. Have you tried recording when the H4 is charged? My guess is when low on battery, the H4 doesn't record.
Sep 02, 2017 | Zoom H4 Handy Recorder
Can't connect the h4 handy recorder to a mac
If you are using a Mac running Leopard (Sys 10.5), you need to upgrade the H4  firmware from Zoom website
You will need an external SD card reader.
Good Luck
Nov 18, 2008 | Zoom H4 Handy Recorder
Zoom H4 Handy Recorder Logo
547 people viewed this question
Top Zoom Music Experts
Michial Gueffroy
Barry Webster
Level 1 Expert
Are you a Zoom Music Expert? Answer questions, earn points and help others
