Question about Kodak EasyShare Printer Dock Series 3
How do we get the old toner cart out in order to replace it?
  • Kodak Master
  • 5,165 Answers
Check that the Paper light is not lit (from a paper error). Clear this error first by removing any paper jams, refilling the paper tray or other needed step followed by pressing the Print button.
To remove the color cartridge, open the cartridge door on the side of the unit. Push up on the green level and slide the cartridge out.
Take the new cartridge, make sure that the ribbon has no slack in it. If there is slack, push in on the cartridge spool and rotate it clockwise. (Do not turn this more than you absolutely must to take up the slack. It could reduce your number of prints.) With the label up and the arrow facing the printer dock, push the new cartridge until it clicks into place. Then press the Print button to clear the error and resume printing.
You can get your manual from Kodak as a PDF or a web page: http://www.kodak.com/global/en/service/publications/index.jhtml?pq-path=1398#printerDocks . Look for the line Printer Dock Series 3 .
I hope this helps.
Posted on Sep 16, 2010
When page prints out it has blotches of black ink on the paper
It is probably the toner cartridge, not the drum. I suggest swapping in old toner cartridges and drums to nail down the problem. I keep at least one old toner and one old drum for that purpose. By the way I just bought a toner cart from monoprice.com. It will not last as long as a Brother cart, but costs very little.
Jul 12, 2014 | Brother HL-5240 Laser Printer
Just replaced toner K and now says empty
You replaced the Cartridge with a OEM product or third party or a refill. if the last the electronic chip on the toner cart is still telling the machine the cartridge is old so refilling will never work replace the cart with OEM cart,
Apr 27, 2014 | Konica Minolta Magicolor 4690MF...
RESET TONER COUNTER
why????????? which color???? did you refill a cartridge????? most cart have electronic chips on them once done tells copier i am done so you if replace the toner inside the old cart to the copier the cart is still old
Feb 20, 2014 | Konica Minolta magicolor 4750EN Laser...
I have a Brother MFC9420 laser printer and the lcd is reading toner incompatible and I have tried all of the suggestions from this site is there anything else I can do. Help please.
You can check online for toner reset chips at a toner seller, when the chip is bad on the toner cart. you can either replace the chip or the toner cart. The chip from your old cartridge may work on your new one, for a while, otherwise order one...
Sep 15, 2009 | Brother Multi-Function Center MFC-240C...
I have a canon image runner 1370 f.
Are you trying to replace the old toner or is this the first time -- new out of box? There is a pattern / order you have to follow to replace the cart. To make it easier, have the right cover open while doing this ( replacing the carts). Also make sure that you have the protective covers and tape off of the cart. Use the light colored area on the cart. to hold and DO NOT TOUCH THE DRUM !!!
Dec 30, 2008 | Canon imageRUNNER 1023N Black and White...
Noises when printing copies
Take the new cart. out and reinstall the old cart. Does the noise disappear? I would tap and shake the toner cart. BUT BE CAREFULL, the cart is ready to spill toner. On the box and in the instructions it tells you, or should, that you must shake and tap the outside of the cart. This is due to settling and the toner maybe packed. By tapping and shaking it will feel the toner. If the toner is packed it will put undue pressure on the augers inside the toner cart. and cause a grinding noise. If after tapping and shaking, reinstall the new cart. and check. If everything is ok -- great. If the noise remains contact the company your purchased the cart. from and ask for a replacement. These cart. are mass produced and mostly reused ( refurbed). Parts wear now and they do not replace the inside parts, they just repack with toner and seal.
Dec 25, 2008 | Sharp AL 1631 Copier
Hp 4600 color laser leaking yellow toner. The carts are actual Hp carts. Any ideas? Had problem with reman carts in April changed to origianl - now happened again. Any suggestions
How to fix toner (Magenta) leak in HP4600...
I have read and tried everyone methods (dc controller, replacing toner, & adjust paper sheet type) of resolving toner leak. The answer to everyone's problem, is to " check & replace the the two black alienation plates (1.5" wide by 10" long, strips are vertical position, held by 2 phillips screws)" located on the back wall after removing all 4 toner cartridges. I found that the plate had cracked and didn't allow the toner to close properly. I temporary superglued the part back and order a new kit (Q3668-67925 $19.99 + s/h). Problem solved.
Sep 24, 2008 | HP Office Equipment & Supplies
Please help with diagnosis of following error for Dell 5110CN CRUM ID -093-693
crum has happened to me when using the wrong toner cart or using a non-Dell cart. If that is the case, replace the chip from the old Dell cart into the new non-Dell - easy to do by prying the small circular top off. You'll probably need to switch to non-Dell toner on the printer - go through menu to find it and your toner usage software will be disabled - that's life.
I also had this happen with real Dell toner cart and I did the same thing to rectify.
Mar 16, 2008 | Dell 5110cn Laser Printer
Replace Toner Message Will Not Clear
Are you sure that it is not asking for one of the colour toners?
Was it a genuine cart?
Did you replace it before machine instructed Replace Toner ie no message or Order Toner/Toner Low was displayed?
Nov 21, 2007 | Brother MFC-9420CN All-In-One Laser...
Kodak EasyShare Printer Dock Series 3 Logo
111 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
