Question about LG 32LC7D Television
Funny colors on componenet input and the uper page on the screen setting does not work
  • monaya45 Sep 16, 2010
    that is te only solution or we can do a reset before changing the t-con?
  • LG Master
  • 11,800 Answers
If the funny colors appear only on Component AV entry then it can't be the T-Con board - it would cause image problem on all entries.
You need to check the other entries to be sure. Especially you must test the tv by using a HDMI source.
If you can determine that it only happens when you use the Component then the fault is either in
- the source of the signal (or the cable) - check that by using another source (as in another dvd player) and with another cable.
or
- the analog entry module on the mainboard - since it can't be replaced on its own you will have to replace the entire mainboard.
Posted on Sep 16, 2010
  • LG Master
  • 5,138 Answers
T-Con Board can cause this, Encompass Parts might have it in stock 1-800-638-3328
The colour on the screen and the colour of the prints is not the same. Do you know what the problem is and how to fix it?
mlatham990,
First I would make sure that you have not run out of one color of ink, which will make the colors look funny. This is the most likely problem and can be solved by replacing the cartridge. If you print a test page it should be obvious if a color is missing.
If you are absolutely sure that there is not a color missing then the following information may be helpful.
There is no adjustment for the relationship of the colors at the printer. Depending on the monitor you have you may be able to go into the menu and adjust the tint, which is the relationship of the three colors, but generally monitors use an RGB signal and you cannot adjust the relationship.
If you can adjust the color tint I would print out a test page, or something with the color which is wrong, and then compare the colors on the page to the color on the screen while adjusting the tint to make the two match.
Thanks for using FixYa and for the great rating.
hardrocko
Dec 26, 2010 | Epson Stylus Photo R340 InkJet Printer
The picture seems to be 3d and pulled toward the uper left, and it smells like something is burning.
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 08, 2010 | Samsung HC-P4752W 47" Rear Projection...
Ok i have a 47in samsung hd tv today it started acting funny the picture and colors arent right like there a blue red and green colors its like the main picture is being copied 3x times once by each color...
this issue is caused by a failure in the convergence ic's and possibly a bad resistor and fuse in the circuit if you need instrution on how to change I may be able to help though it is kinda tech heavy
Jan 25, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Just bought a lcd3202a I dont have a cable connection yet but would like to use my dvd can i do that
yes you can, most dvd players have either a composite connection or component connection.
composite connection is red yellow and white.
yellow is video feed
red and white is left and right audio
component connection is usually 5 colors
red blue green for video
red and white for audio,
look at the back of the dvd player, if you have red, blue, green, red and white, then you got componenet connection.
just match the colors on the back of of the player to the back of hte tv.
on the back of the tv is when you see video one or input one, just connect one of them
and use the remote to change inputs or video. on most remotes it's usually "input" or "source"
if you have any more questions, let me know, i'll be more than happy to answer more to make it more clear.
Oct 17, 2009 | Curtis Televison & Video
JVC LT 42x688 no picture just sound
Sorry, this has no easy fix. The good news is you do not need an LCD Panel. The bad news is the Video Processor has a problem.
This TV has x3 Boards. The one you should replace first is the one in the middle. If this doesn't fix it, try the one on the right. The Part #s are on the Boards if you wanna try ebay.
Dec 22, 2008 | JVC LT-40X776 40 in. LCD HDTV
Screen showing funny lines and colors.
That would be the screen itself that needs replaced, if you needed the inverter board you screen would be dark and hardly visable
Nov 12, 2008 | Acer Aspire 3100-1405 Notebook
COLOR SHADOW
that is called a magnet effect it means u have a strong current some were do u have a cd player or speakers to close surround sound to close if so move them away till it fades
Jul 05, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Uper Duplex not holding card in place
early model sp75s have that type of problem. It can normally be fixed by replacing the clutch and duplex board. Very easy to replace. Be sure to be aware of the clutch spring when removing the duplex tray. Use the lower duplex assembly as a guide.
Jul 02, 2008 | Datacard Group SP75 Color Card Printer
Insignia LCD tv 32".....
It's either the VGA cable you are using has a bad pin or the RGB/Color Scheme is set wrong. So try another VGA cable or try the LCDTV on another PC.
Feb 22, 2008 | Insignia LCDTV26 26 in. Television
LG 32LC7D Television Logo
24 people viewed this question
Computer Repairing
Computer Repairing
