Question about HP Computers & Internet
My hp psc 1200 printer will not cancel a print job, so is holding up the queue. I have tried several different things to no avail. The item that will not cancel was something I tried to print off a web site.
Need help email me drummernick2002@aol.com live help thx nick
Posted on Jun 08, 2008
Cannot delete a print job
restart the computer
while the computer shows the BIOS message, turn it off, wait 2 minutes. Turn on again
Apr 01, 2010 | HP PSC 1315 All-In-One InkJet Printer
Can't cancel a HP PSC 750 Printer print job.
Right click on MyComputer and click Manage. Then go to Services and Applications and then Services. Find the Print Spooler services in the list and right click to stop it. When it is stopped try to cancel the document again. Then start the print spooler service again.
Regards,
nicolasiac
Feb 12, 2010 | HP PSC 750 All-In-One InkJet Printer
I have HP 1200 psc I have a document that will not delete therefore I cannot print anything at all I have tried switching off everything - no luck - can you help?
From Printers and Faxes window
1. Right click the printer icon for your HP 1200 PSC then select "Set Printer Offline".
2. Right click again the printer icon then select "Cancel All" print jobs.
3. Once it's cleared, right click the printer icon again and then "Set Printer Online".
Or, restart the computer and the printer.
Oct 23, 2009 | HP PSC 1315 All-In-One InkJet Printer
Item won't cancel out of print queue. How do I
I have run in to this more times then I would care to count. Unfortunately, what worked one time did not necessarily work on a different computer and sometimes even on the same one. If, after several reboots, the problem still exists, disconnect the printer from the computer. Try again and reboot one more time and try.
If that fails, make sure you have the cd with the drivers or go to HP's website and make sure they are available.
Delete the printer! Reboot 2 times.
At this point, the queue should be gone. Reinstall the printer, reattaching it when asked.
Aug 03, 2009 | HP Deskjet D1341 InkJet Printer
Ihave a deskjet d1341 hp printer but I have jobs on that i want to cancel so i don't waste my ink, how do i do this
Look for a printer icon in the lower right toolbar, near the clock, on your monitor. Right click it. Open the print queue. Right click the print jobs you want to cancel or delete. These are general directions, your model OS may be a little different.
Feb 26, 2009 | HP PSC 2410 All-In-One InkJet Printer
Unable to cancel a job
Sounds like the printer spool is frozen.
Assuming you're using WinXP and logged in as an administrator (or with admin permissions)
START
Control Panel
Administrative Tools
Services
Locate the "Print Spooler"
Right click on this and choose "restart"
This will restart the print queue and will probably try to print the job again or delete it properly. If it tries to restart, just right click on the printer job and choose cancel again..
You may need to repeat but that should at least get you back up and running with other print jobs again.
Jan 25, 2009 | HP PSC 1350 All-In-One Thermal Printer
Printer will not cancel print job
START
Control Panel
Services
Jan 25, 2009 | HP PSC 1410v All-in-One Printer
How do I get a alingment test
HP PSC 1200 and 1300 series:
  1. Turn on the HP PSC 1200 or 1300 series product.
  2. Disconnect the USB cable from the all-in-one.
  3. Press the sequence of front panel buttons below to start the print cartridge alignment process. The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds.
    1. Press and hold Cancel .
    2. While holding Cancel , press On .
    3. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons.
    4. Press Cancel again.
    5. Press Copies .
    6. Press Paper Type .
    7. Press Color Start Copy . The alignment page will begin printing. If the alignment page does not print, repeat the button-press sequence in this step.
  4. When the alignment page has printed, place the page face down on the scanner glass and press Scan . The alignment is complete when the On light stops blinking.
  5. Reconnect the USB cable.
Jan 14, 2009 | HP PSC 1210 All-In-One InkJet Printer
Can not clear the print que
Follow these steps to resolve the issue. Step one: Delete the print queue Open Print Setup Utility located in the Application/Utilities folder. Double-click your printer in the printer list to open the print queue. Click the Stop Jobs icon. Click to select the document, and then click the Delete icon. Repeat the steps for all the jobs in the print queue. When the print queue is empty, click the Start Jobs icon. A message appears: No Jobs Printing . This indicates that the queue is clear. When you have cleared the queue, retry your print job. If the procedure has not resolved the issue, repeat steps 3 and 4. If the issue still persists, continue to the next step. Step two: Remove the printer from the list Open Print Setup Utility , located in the Application/Utilities folder. Click to select the Photosmart icon. Click the red X to delete the printer from your system. Close all open windows, and restart your computer. Step three: Add the printer to the list Open Print Setup Utility located in the Application/Utilities folder. Click Add . Select the printer that you want to add, and click the Add button. After a few seconds, your printer appears in the printer list, and your printer is ready to print.
Sep 13, 2007 | HP PSC 1410v All-in-One Printer
Computers & Internet Logo
88 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
