Question about Indesit 18 in. D41 Slim-Line Free-standing Dishwasher
My dishwasher doeosn´t heat the water - Indesit 18 in. D41 Slim-Line Free-standing Dishwasher
  • Indesit Master
  • 43,501 Answers
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Posted on Sep 16, 2010
Hobart AM15 dishwasher is not getting to 180' on the sanitizing cycle. How can I increase the temperature? Presently, centers around 177' when it is sanitizng
Try running the hot water into the sink immediately before you turn on your dishwasher. That will get hot water from your heater to dishwasher faster & help with the sanitizing cycle heat
Sep 06, 2017 | Hobart Dishwashers
Hobart lx18h Booster does not heat up. machine powers up and will wash thouugh all cycles but the booster does not heat up water.
There are one or two hi-limit relays on the booster. One is on the front and if there is a second one, it is on the right hand side as you face the front of the unit. They are both manully have to be reset if tripped. Check them and also the booster's contacter
Oct 03, 2016 | Hobart Dishwashers
I have just bought a second hand dishwasher, touch dry sb915. The water is not getting hot and they are wet at the end of cycle. I have read previous q&answers, one said to tilt and there will be
Hello Cathy I have fixed many appliances by using the
RepairClinic web site. Normally the hot water is boosted to 180 F
to sanitize the dishes. The incoming hot water supply could be around 120 F. Perhaps the heating element needs replacing. Have you looked at the Westinghouse web site ?
Ken
Jan 03, 2015 | Dishwashers
I have a LXiC Hobart dishmachine I do not want to use Sanitizer because my hot water is very hot. How do you disable the sanitizer pump and alarm? H.
Do you realize that to sanitize with hot water alone requires 180 degree F water? I am a hobart technician and I've never seen any business or residence with hot water anywhere near that. Residential hot water is generally approx. 120, Commercial locations generally use approx. 140, but never near 180 (tap water that hot would be a severe safety problem). Hobart LXIH machines use a built in booster heater to boost the temperature of the incoming hot water up to the required 180 deg.
Jul 01, 2011 | Hobart 24 in. LXIC-5 Built-in Dishwasher
Do all Hobart dishwashers have a element in them for wash water and rinse water
All Hobart dishwashers will have a wash tank heating element, but the rinse water is not heated by the dishwasher, unless it has a built-in booster heater. Usually a separate booster heater is used to heat rinse water to 180-190 deg. F for hot water sanitation.
Aug 07, 2010 | Hobart AM14C-155 Dishwasher
My indesit dishwasher just 10 months old has broken down threetimes in the last 2 weeks its overheating and could have went on fire indesit have refused to give me a replacement i will never buy anything...
probably the thermostat on the water heating element is bad.
it is made so the water heats up to 180 degrees F and turns off.
it will kick on and off to maintain the temp constant.
if it is stuck on all the time the water will over heat.
the heating unit i replaced here in naples italy because mine was broke and would never start up.
after taking mine apart i learned a lot.
the heating unit cost me 28 euro or about $40 .
if you have a 1 year warranty they have to repair or replace the unit.
if you have all the receipts call the home office and complain.
the eater heating unit looks like a peace of exhaust pipe 2 inches in diam and 8 inches long.
it has the heating element wrapped around and the thermostat on top.
hope this helps.
ralph
Jul 03, 2009 | Indesit Dishwashers
Dishwasher stuck´s in program
Well to Reset the error message as follows: To cancel the error message, turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs. Then switch the appliance off and then back on again.
If resetting not work then you can check that the stopcock is opened fully or whether the water inlet hose is kinked. Check that the water inlet filter is not clogged and clean it, if necessary, as described in the operating instructions. Check that the drain pump is not clogged.
Good Luck!!
Jun 21, 2009 | Dishwashers
I will be hooking up this dishwasher.
I'm a hobart tech.If the dishwasher is going to be a cold machine you need 140 degrees,if its a hot machine you need 180 which you need a booster.A hatco c-36 will supply the dishwasher with180-190 degrees.Any ? let me know.
Jan 15, 2009 | Hobart 29 in. AM15-1 Free-Standing...
Rinse not hot enough
145 degree is just your hot water temp and that your dishwasher hot water booster is not working assuming that this machine has worked in the past to produce final rinse water above 180 degrees. Remove the bottom panel and to the right you will see the booster tank, look for a nickel size component with a small red button on it. Try pushing on it to reset it. If that does not work, check for voltage at your heating element on your booster tank. (the thicker wires) If voltage is present then your heating elements need replacing.
Nov 13, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart dishwasher lx 30 h
Did the clean light indicator blinking over n over? check the element wire harness connector. If disconnected fix it and run your dishwasher again.
Also you may check the continuity of your heating element.
Jul 23, 2008 | Hobart 24 in. LXIC-5 Built-in Dishwasher
Indesit 18 in. D41 Slim-Line Free-standing Dishwasher Logo
87 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Level 1 Expert
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
