Question about Whirlpool GEW9250P Electric Dryer
Whilpool duet model # gew 9250pw0 does not power up replace main controll board checked themall overload fuse checks ok do I have to replace interface board that connects with main controll board
  • 347 Answers
Only after checking the door switch and the belt switch,these are two other items that can cause your problem...
Posted on Sep 16, 2010
I have duet dryer GEW 9250PW0 with no heat. I have changed Thermister, Thermal cut off, high limit thermostat, heating element, and main board. I've check pwer cord and oulet and they check fine
You didn't mention checking the "cycling thermostat".
The two large terminals will be closed, and the two small ones should ohm out around 250 ohms. You also need to check and make sure you have 240 volts coming to the dryer. You could have one of the two breakers thrown. Here is the cycling thermostat in case you find it bad.
Keep me posted on your findings.
Oct 22, 2012 | Whirlpool GEW9250 Electric Dryer
MIne Whirlpool duet is having probloms please help me with it!
see this causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 05, 2012 | Indesit W 123 Front Load Washer
MY PS3 WONT TURN BACK ON
Either power supply problem or blown surface mount fuse on the main board. First check all SMD fuses on the main board, and the fuse on the power supply board. If the power supply board fuse has blown replace it and try again, if it blows again you need to replace the power supply. If the power supply seems OK check all SMD fuses on the main board. There are 7 on the V3 and about a dozen on the V4 / V5 / V6.
Good luck...
May 30, 2010 | Sony Playstation 3 (PS3) Console
We push the start button and the power shuts off and unit won't start
There are some possible cause of the problem. It could be the fuse, loose wire, switch or the main control board.
You may take off the cover sheet and check if there are any loose wire connections. Next is to find the fuse and capacitor (usually has a marking of 10uF). If the fuse is blown or if the capacitor is pregnant, replace it and the washer should work again.
But if everything appeared to be okay, contact a local repair tech to take a look at your washer because you could have a bad control board. Defective control board should be replaced with a new one.
Thank you!
Feb 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Our display panel light went out on our model w30400p jenn-air single wall oven.
Make sure there's power getting to your range, oven or cook-top. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. I would also advise to inspect the junction point on the backside of the unit for a possible separation of the power cord as well. If all checks out ok, The main control board will be the culprit.
NOTE_ If your unit is equipped with a relay board, this will be the likely culprit, if all checks out ok. If there is no relay board present inside the unit, replace the main control board.
Jan 02, 2010 | Jenn-Air Ovens
Indesit WIA 101 Machine wont start.No power
first check the fuse,if this is ok,you will require a main control board,this will require programing for you model and comercial code
Jul 25, 2009 | Indesit W 123 Front Load Washer
Control locked is on, how do i unlock it ?
I think you're on line. Okay, power shd be on, see that button 'end of cycle' on the right side of your panel? Hold it down for 3 seconds. You'll be ok. Dont forget to rate, its a way of saying thk u!
Mar 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GEW9250P Electric Dryer Logo
122 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
