Question about Hunter 20761 52'' The Stratford II Brushed Nickel Ceiling Fan
Fan chain pulled out from Fan Body. How do you fix that
  • 8,404 Answers
Rmove the cover ... you will find the loose end inside. Get a chain at your local hardware or electric supply store.
Posted on Sep 16, 2010
Pull chain on Hunter ceiling fan pulled completely ot of fan by cleaning crew. Can it be repaired? And if so is it worth the cost? Thanks
You can get another chain with a hook at the end if there is any of the chain at all left on the fan to fix it.
May 15, 2017 | Hunter Dryers
HOW DO I FIX A LIGHTING CHAIN THAT BROKE INSIDE THE HOUSING OF THE FAN?
You have to buy a new pull chain, usually two wire. Take light off fan and put new pull chain on as you take the old one off.
Sep 12, 2014 | Dryers
Harbor breeze fan remote
If the fan has a pull chain then push the Hi button and then pull the chain until it's on high. Then don't pull the chain! If that's not your problem then check the capacitor in the fan.
Jul 15, 2013 | Dryers
Hampton Bay cieling fan. Fan will not operate without light being on. Is there a wiring problem or a fix for this
Isn't there a pull chain to shut off the light? If you only had a light there before and it was controlled by a single switch, that switch will now turn on the fan and light and you have to pull the chain to shut the light off and pull a different chain to turn the fan on and select speed.
Gary
Apr 20, 2011 | Dryers
Hampton bay ceiling fan works, but can not change speed or stop fan. Model 46006 52" Huntington III. Is there an easy fix?
your pull chain for the fan is bad u can go to home depo & buy a new pull chain but when u replace it on the back ot the switch their is A 1,2,3,4, make sure the wires go to the correct #'s
Oct 05, 2009 | Hampton Bay 54 In. Flemish Pewter Ceiling...
Ceiling Fan Chain Broken Off
You have to kill all power to the fan and start taking it apart till you get to the switch. There's usually just a bottom plate to remove. Sometimes lights. Replace switch and reassemble. If some chain is still connected to the switch you can add chain to it and won't have to replace switch.
Oct 04, 2009 | Dryers
Pull chain for fan difficult to operate
All Hunter ceiling fans are "remote control" adaptable. Consider a remote control for it.
There are Nylon pull strings fitted with a ball clasps on the ends. Consider that, too.
Both at Lowe's or Home Depot...
Oct 01, 2009 | Hunter 22451 The Brookline Brushed Nickel...
Pulled chain to slow down fan speed. Chain came out of the housing. Yikes. What should I do? Perfetually have the fan running or can I take it apart and fix it?
Turn the fan off at the breaker. Is there any chain still hanging out? If yes, buy new section of chain at hardware store. If no, buy new pull chain switch at hardware and replace.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 27, 2009 | Dryers
Wire diagram for pull chain on ceiling fan hunter original
if you indeed have a 23852 hunter original...
Black goes to L, High is Red, Gray is medium and yellow is low. Make sure you have the right switch.
Mar 21, 2009 | Hunter 23852 Classic Original Ceiling Fan
Hunter 20761 52'' The Stratford II Brushed Nickel Ceiling Fan Logo
129 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
