Question about Linksys Wireless-G Broadband Router
I have a wrt54624 linksys my moms fiends set up on our computer took the CD and the password. Right now I want to turn the WiFi on but i don't know how to
  • Linksys Master
  • 8,404 Answers
Get the software at www.linksys.com/support Default password is 'Admin'
Posted on Sep 15, 2010
How to fix error code: 10060?
Call Linksys & they will walk you thru it
Think there in Toronto,but like most calls could be
anywhere
Jul 23, 2014 | Linksys Wireless-G WRT54G Router
How can i change password on my wifi so nobody else can use it anymore
Most wifi units have an IP address you can use with your web browser to change the wifi password and various other settings.
Look online for a manual for your specific router. Get the IP address for it and put it in the address bar and turn on password and even make your own password.
Jul 01, 2014 | Computers & Internet
Just installed my wrt120n linsys router, it succesfully was installed in my desk computer,but I accidentally skiped the "Learn about connecting other computers" step, and now only this computer...
Did you set a username and password for the router. If you did go to your computer and make sure your wifi is turned on. If they are turned on then go to the name of the router that said linksys and try to connect to the router using the username and password. If you didn't set a username and password then it should just connect. If you don't remember your username and password then on the back of the router there will be a reset button hold down for 1 min to be safe and start from the beginning but your wifi signal should be working without a password
Jun 24, 2011 | Linksys WRT120N Router
I need to reset my wifi network password but don't know how
The router's password can be changed by running the routers setup cd. If you do not have the cd:
1.Open your browser
2.In the address bar type in 192.168.1.1 this will bring you to your router configuration.
3.put in your username/password "If you forgot your username and password you can always reset your router, if that is the case your router will go to back to default settings,In order to reset the router look in the back of the router and you will see a reset button, press and hold the reset button for 30 seconds, the reset button is located next to the Internet port on the router.
4. When your linksys router configuration is up, go to Administration.
5. change password that's it!! hope this helped. Good Luck
Sep 29, 2010 | Linksys Wireless-N WRT150N Router
I have linksys wireless-G Broadband Router WRT54G,BUT HOW TO SET UP TO LINK TO OTHER 3 LAPTOPS,I HAVE LOST THE CD SET-UP DISC.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi . Let me know if you need further assistance. Thanks for using FixYa.
Sep 23, 2010 | Linksys Computers & Internet
Hi I dont have the installation cd for my Linksys WRT54G Router and I need to install it on another pc. also the WLAN light is not lit.
You can configure your router with below method without disk. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi . Let me know if you need further assistance. Thanks for using FixYa.
Sep 21, 2010 | Linksys : WRT54GS Wireless-G Router W/...
How do i lock my linksys router so no one can connect to my wifi.
To lock it, you need to password protect it.
On a computer connected to the linksys now.
Click the link below
192.168.1.1
On the page that comes up, it will ask for a username and password.
type in admin for the password, leave the username blank
You are inside the router..
Click on wireless, then right under it click on wireless security.
Where it says authentication, click it and change it to wpa2 psk
Where it says, PSK / Passphrase / Or Network key .. There is a text box to the right
In that text box is where You will have to type in a new password, and click apply / save settings.
Then.. The router will restart..
You have now set your wireless password.
Let me know how this worked out for you. If my solution helped you, please rate this solution!
It doesn't cost anything and only takes a second, but it is greatly appreciated.
KittyTech
Aug 25, 2010 | Linksys Wireless-G WRT54G Router
I recently moved in with my mother and she bought a LINKSYS RANGEPLUS for her computer. I have a Ralink USB to give my computer the ability to log into WIFI. It shows the network my mom set up but says...
you need to log into the router and you can change the settings there. For most linksys products in Internet Explorer open and in the Address Bar type in: 192.168.1.1
Then you will be prompted for a username and password usually: Username: linksys Password: admin
Once in the router click on Wireless Settings then Wireless Security.
Jun 29, 2010 | Linksys WRT160N Wireless Router
My mom gve me a Wireless-G access point Linksys
I suggest resetting the router to the factory defaults by holding in the reset button located on the back of the router for 30 seconds.
The router will reset to the ip address of 192.168.1.1 and you can log into it using either a blank username and the password admin or using the username admin and the password admin.
Please let us know if the above was helpful and if there is anything more we can do to resolve your issue. Thank you.
Sep 16, 2009 | Linksys Wireless-G Broadband Router
How to install linkys without the cd
You can manually install it even without a CD, if you dont know how to do that you can contact Linksys tech support so they can walk you through in configuring it manually , this is the number 800-3267114....
Hope that helps..........
Aug 25, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G Broadband Router Logo
136 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
