Question about Eddie Bauer Playard 05065
How do you get the ends of play yard to lock in place?
CAN'T CLOSE CARTER PLAY YARD
1. Take out mattress
2. Pull up from the center of the bottom (from inside)
3. Press buttons beneath fabric on playpen sides to disengage locks
4. Fold sides in to form rectangle shape
5. Place change parts on top
6. Fold mattress around everything, and secure with velco
7. Place in bag.
Instructions at this link: https://docs.google.com/viewer?a=v&q=cache:6nDv33smp4cJ:www.summerinfant.com/getattachment/9f4739f2-13ea-4342-833f-98fcdcd697a0/Carter-s%25C2%25AE-Bumble-Comfort-n--Care-Playard---Changer.aspx+&hl=en&gl=us&pid=bl&srcid=ADGEEShem_Qqk1mAetDfL0flJy-kUHyeo5y_9U2-H9ORsLfrJVBmfkuSbdi4U0aEZspq70zeZD8RJd-k2ABFHWwubl4RC0krcPK2V5vsOuu_KCWFnCwVYsN_LJXCoKNDS-9msppsRLda&sig=AHIEtbQbqIlqXbjMY84PvQ26usJHXF14wg
Hope that helps!
Jan 04, 2013 | Summer Infant Carters Bumble Comfort n...
Can you send me the directions for setting up the cosco playpen
Try this step by step instructions Hope it help you
Instructions
1. Unfasten the floorboard from the folded play yard frame by loosening the hook and loop tabs holding it in place.
2. Unfold the play yard and set it upright with its four legs on the floor. Pull out on opposite corners to spread the legs of the frame.
3. Pull up on the plastic handle in the center of the floor of the play yard to unlock it fully.
4. Pull up firmly on the center of each of the four side rails until they click into place, while continuing to pull up on the center handle.
5. Push the center lock down until it clicks all of the legs into place.
6. Place the padded floorboard into the play yard.
7. Locate the two hook and loop tabs located on the underside of the floorboard and pull them through the slots in the bottom of the play yard frame. Secure the tabs underneath the play yard.
Jul 02, 2011 | Cosco Juvenile Cosco Funsport Playard
Bought a Kolcraft travelin Tot and we can get the sides to lock. Help!Also tried to download the manual and it kept saying error on page
Pull the bottom up by the handle so its not flat. It will look like a teepee. Then straighten sides, they will lock into place. Then flatten the bottom.
May 27, 2011 | Kolcraft Travelin Tot 2 In 1 Playard
Side rails will not lock in place
I would suggest returning this item if possible or perhaps just purchasing a new one. This company has now had the best luck with the sides of their playards locking in place.There was a recall issued for similar models.
RECALL
One child died and three others were injured because the sides did not properly lock in to place.
Although your product is not specifically listed and this does not technically "solve" your issue I felt it worthy of note here.
May 05, 2011 | Baby Trend Playard with Bassinet, Nambia
Cant lock the end rails of the porta-cot, the two side ones lock in fine but the end ones just fold back down. Its a Jeep Sahara Limited XT playland.
Before you lock the bottom of the playard, you need to pull all the way up on the two side rails, they will form a slight arch, and the button will click into place. Then push down on the bottom rails.
Feb 06, 2011 | Kolcraft Jeep Sahara Limited Xt Playard
I cannnot get the gRECO PACK N play sides to stay up
I have the same one, its quite difficult.
It needs to click & lock in on both sides of the release buttons. Sometimes having somebody put their foot in the bottom of the play yard while you pull up on the release button will help lock it in.
You also need to have the shorter sides lock in first before trying to lock the longer sides in.
Oct 18, 2010 | Graco Pack 'N Play® Playard 9447mch
I purchased an Avalon play yard and it did not come with instructions. I cannot get the sides of the playpen to stay in the locked position. What am I doing wrong?
I have the same play yard and it is a funny one to figure out but I believe that you lock the sides first then push the bottom down to lock it in place hope this helps
Sep 03, 2010 | Toys
Play yard assembly COSCO Funsport L-3
for Model Cosco Funs Port Play Yard
Just pull the cord in the middle of the upward and straighten out
each poll one by one. If you have someone that can help you
open the play yard pull lightly up the four sides and while you're holding them up, pulled the middle strip that located inside pull it up it will lock all four sides at the same time.
I don't have childred, but it drove me crazy that I couldn't do this
until my wife said maybe this is how you do it, I tryed it and it worked. I hope this helps everyone. Regards,
Frankie.
Jul 11, 2008 | Cosco Beatrix Potter Playard Crib
Folding up Cosco play yard
you also need to hold one of the middle indicator tabs on the longer side..because if you don't do that it will not shut... and make sure the 2 legs go inside with the center of the play pen
Dec 03, 2007 | Cosco Beatrix Potter Playard Crib
Eddie Bauer Playard 05065 Logo
37 people viewed this question
Top Eddie Bauer Baby Gear Experts
Jennifer Rock
Jennifer Rock
woodzowl307
ray gallant
Are you an Eddie Bauer Baby Gear Expert? Answer questions, earn points and help others
