SOURCE: Owner's/Instruction Manual
Hi SDGirl - This is a slightly older model and there's not much out there. You won't find one at Tandy or Radio Shack Sites. I'll give you a link where you can find it ( sort of) in sections. I believe it will tell you everything you need to know. If I were you I'd probably copy and paste each section into Word or something so you'll have it all in one place. This is about the best out there. If this solves your problem PLEASE rate this as fixed. ( I looked alot for you). If you need more help just add a comment and I'll be happy to assist you further. If this doesn't solve your problem let me know before you rate and I'll try for something better. Thanks.
http://support.radioshack.com/support_electronics/36547.htm
Jeff
SOURCE: i need an owners manual for my radio shack pro-50
You can find an online owners manual by using the link below!
http://support.radioshack.com/support_electronics/6905.htm
SOURCE: Looking for owners Manual for Echo HC 1500 Hedge
Go to this web site http://www.echo-usa.com/ and on the right hand side of the page click "TECHNICAL DOCUMENTS"
Then when the next page comes up type "HC-1500" and click search.
Now this is important: You have to keep track of your serial number, your model number and
your engine type.
Even when your looking for parts such as the ignition coil keep track of your serial number.
When you pull the side bar down you'll find the different manuals you can copy. I hope this helped.
SOURCE: Need a Owner's Manual for Radio Shack TAD-3822 (Cat. #433822)
here is a link to the page where you can get your owners manual
http://support.radioshack.com/productinfo/DocumentResults.asp?sku_id=43-3822&Name=Search%20Results&Reuse=N
SOURCE: looking for an owners manual or a user manual for
Look all over, could not find the manual, but here is the specs on it:
http://support.radioshack.com/support_meters/doc48/48753.htm
and here is a detailed parts list:
http://support.radioshack.com/support_meters/doc21/21640.htm
Best of luck finding the manual!
Testimonial: "EXTREMELY GREAT AND BEYOND MY EXPETATIONS REAL GOOD RESPONSE THANKS SO VERY MUCH"
