Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
16 hp briggs ohv v twin - one cyl compression = 120 the other is 60ish and blowing raw gas out the carb. Obviously an intake valve is stuck, what is your recommendation?
  • 395 Answers
You could first try resetting the valve clearances. The B & S Website should provide the settings as well as a manual.
Posted on Sep 17, 2010
18hp v twin brigs when it runs oil comes out of carb
you will see a tube coming from engine block to carb, pull it loose at carb just under the air intake or right behind breather filter. start engine and if oil blows out then its a blown head gasket.
Jun 21, 2014 | Briggs & Stratton Briggs Stratton Intek V...
Oil blowing out of carb. gas in oil ohv engine
carb needle valve stuck open clean carb possible bad float dont run with gas in oil
Jun 23, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Carb shooting air and fuel out top instead of taking in air
Get an air filter made from foam or paper. The ion ones don't work well.
Also sounds like an intake valve is stuck open. When piston comes up it pushes air/fuel back out through the carb. Do a compression test on both cylinder to confirm this.
May 06, 2012 | Briggs & Stratton Briggs Stratton Intek V...
I have a b/s intec ohv 13 hp oil has gas in it ,oil would fly out the exhaust. I drained the oil out and much gas is evident. Engine has good compression. Oil was squeaking out in late summer and i...
If you have that much gas in your oil it's usually because the float valve in the carburator is stuck open. This allows gas to overfill the carb, it then goes to the cylinder and is thin enough to get by the rings and into the crankcase. It could be because there is something in the valve seat keeping it from closing or the float could be damaged.
Jan 06, 2011 | Briggs & Stratton Briggs Stratton Intek V...
2004 v twin 16 hp 500hours on it runs but spits fuel throught carb when giving gas runs like its missing on one cylinder replaced carb, plugs, fuel filter, it has 120 lbs of compression in each cylinder...
You should take one of the heads off and look at the valves. You may have deposits building up no the valves.
120 pounds compression sounds pretty good for a six year old engine with 500 hours on it. It probably started life at 9 to 1 and now is around 8 to 1.
May 05, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Engine pumps raw gas out of the carb under power
NEED TO KNOW WHAT KIND OF ENGINE. DOES IT HAVE A PUMP? IS IT GRAVITY FEED? IS THE CARB AND GAS TANK ONE PIECE? IT SOUNDS LIKE FLOAT IS STUCK OR FLOAT BOWL GASKET BAD. COULD BE ALOT OF THINGS. NEED ENGINE MODEL OR NAME ON COVER.
Jul 12, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Briggs and Stratton 16 hp v twin..replaced con rod and piston
Needle and seat not functioning ... float stuck or trash in needle and seat of carb.
Jul 08, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and Stratton OHV V-Twin 24hp repetitive valve adjustment
Try pulling out the choke a little, if it stops backfiring the mixture is too lean, check the intake
pipes at the cyl head and also the plastic runners to the carb for leaks.
Dennis in Chicago
May 07, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
785 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
