Question about KitchenAid KBFA25ER Bottom Freezer French Door Refrigerator
My refrigerator is making a crackling sound on and off. I cannot determine where it is coming from, why or when it will start or stop.
Crackling subs
After crackling sound they stop and the light on overoald
Dec 29, 2013 | Legacy 12 500 watt l series woofers,...
I have a frt18drh fridg. every time it comes on I get a loud whistling sound.what can I do to stop this ?
Good Afternoon frnk, thank you for allowing me to assist you!
Your new high-efficiency refrigerator may make unfamiliar sounds. These are all normal sounds and soon will become common to you. This also indicates your refrigerator is operating as designed. Hard surfaces, such as vinyl or wood floors, walls, and kitchen cabinets may make sounds more noticeable. If the noise, however, become louder or more pronounced, then you may want to connect with a local appliance technician to determine if anything else may be the cause.
Oct 16, 2013 | Frigidaire FRT21H8 Top Freezer...
Sanyo dp42841 is making a crackling noise
determine first if with sound off you have the problem---if not it is audio related and if with sound off it is still there it is inside the set....
Mar 29, 2012 | Sanyo Televison & Video
Microsoft lifechat lx-3000 headset crackle noises
Go to Control Panel>Large Icon View>Sound>Playback Tab>Right Click The Headset Icon>Properties>Advanced Tab>Change the Default format from CD quality to DVD quality and voila. :D
Feb 01, 2012 | Microsoft LifeChatâ„¢ LX-3000 Headset
First of all, sorry for the mix up on model the model #. I was viewing a problem regarding LG LCD TVs and found your link. My problem is with an LG 42LGX LCD HDTV. It has worked fine without any issues...
welcome to fixya and thank you choosing my service..
OK,that is the most and common problem of all LCD TV...
Usually dim and totally have no back-light is cause of bad inverter board.One of the inverter board is shorted that cause dim light and crackling sounds..
This are the sample images of inverter board.
to make sure that the problem is on the inverter board kindly try to disconnect/unplug it from your TV and power ON then observe if the crackling sounds remain or not..If the crackling sounds gone replaced the inverter board..Also I need to how many inverter board you have? if 2 or more disconnect it one by one to determine if where is the specific faulty inverter board..
Example:
I disconnect #1 inverter still have crackling sounds..next disconnect #2 inverter and reconnect the #1 inverter until you found the faulty one..Note when you doing this make it sure you power off the TV before you unplug or disconnect inverter board because its high voltage..
I need the picture your TV screen..just send it to chesterpendilton@yahoo.com
Regards.
Chester
Jan 20, 2012 | LG 42LC2D 42 in. LCD HDTV
Cd plays when bike is on ,but when you start the motor it doesn't play . and when your riding down the rode the speakers crackle , but doesn't do it when your standing still . whats wrong .the speakers are...
When starting the bike, the starter relay pulls in to divert power to the starter solenoid. To insure that the solenoid gets all the power it needs, the accessories on the bike are turned off momentarily. Once the bike is running, they come back on. The "crackle" sounds like it might be interference from something on the bike, nothing wrong with the speakers or it would make the sound all the time. It's probably pickiing up the impulses generated by the speedometer or something when when the bike is moving but is not doing anything when you're standing still. A dealer may can find it or you can disconnect various accessories and take a ride down the road to see if the interference stops. Once you determine what is causeing the interference, then you'll have to figure out how to stop the interference from affecting your speakers.
Good Luck
Steve
Aug 11, 2010 | 2000 Harley Davidson FLHTCUI Electra Glide...
My side-by-side refrigerator freezer, the coils in freezer ice up, and the refrigerator section get's warm. What is the problem?
OK'Lets start with the defrost timer located below refrigerator and front kick plate. Turn timer until it cklick into a position that stops fans and compressor. Leave like this for about 30 minutes. Listen inside the freezer for sounds od sizzling or crackling sounds the sounds of defrost. If timer does not automactically come ou of defrost turns gently again clockwise until the compressor starts. Let me know what you find, Sea Breeze
Feb 21, 2010 | Refrigerators
I have a powered sub for my surround sound and every now and then its starts crackling and popping. i can make it stop by playing with the volume knob or even tapping it sometimes. my old sub did the same...
Does the crackling and popping sound comes only from the sub, or from the other speakers too? Try switching of to check. I think that it is problem on volume control potentiometer. In that case all the speakers must sound crackling and popping. If the problem is only in the sub you have to check its connections.
Stelios.
Feb 20, 2010 | Audio Players & Recorders
Channel 2 crackles
Make sure your speaker wiring does not come close to the 12v power cable running for your amplifier. If your amplifier's 12v power cable runs on the drivers side of the vehicle, run your speaker cables on the passengers side and make sure your tweeters have a high pass filter to stop any pickup of engine sound (When you are driving you *WILL* notice it at high RPM. a HPF (High Pass Filter) will also stop those nasty hissing sounds on S's.
Feb 11, 2009 | Alpine PDX-4.100 Car Audio Amplifier
Crackling Speakers
That because maybe due to your itunes player which the installation got error..please try another player other than Itune or play it in windows media player or some other player which you think good player.
Or try reinstall your player or update it.
if this not resolve the issue, then verify the connection of your sound card maybe got grounded to other components making the sound crackle..Or you may try attached a grounding wire from your stuff directed to the ground or attached in any metal that is connected to the ground to eliminate noise.
please tell me what ever result for further analysis
melnavz
Feb 10, 2009 | HP Computers & Internet
KitchenAid KBFA25ER Bottom Freezer French Door Refrigerator Logo
325 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
