We have a Noritz N-063 tankless heater that has been installed a running flawlessly for the last 61/2 years. Recently, and randomly, the unit will shut off and produce a code "12" on the remote control. We have cleaned the filter and checked the gas pressure.(Noritz requires 8.5-14 WC for propane and we have 10.5 WC). Any help would greatly be appreciated. Thanks in advance. Phil Santore Bethany, CT
    President:
  • 2,777 Answers
The error code "12" indicates a serious issue inside the unit. The most common error is 11, which is related to pressure in the unit, and usually just requires you to turn off and on the unit a few times and it is resolved. However a 12 is an indicator of a much more "serious" problem in the unit. It is not specific to a single issue, but I recommend you call Noritz to see if they have any advanced troubleshooting available that only a Noritz technician would know about. If you get this message this morning, try their Atlanta office as it should be open by the time you get this: 770-422-8120 However their main number is in California, at 714-433-2905.
However I do believe this unit will need servicing, and they can help set that up for you.
Thanks
Tim
Posted on Sep 16, 2010
  • 2,272 Answers
Every Noritz tankless water heater has a minimum flow requirement which must be detected in order to activate the heater. If your water heater shuts off during usage, check to see if your filter is clean. Verify that gas, water, and power are supplied to the heater as well. . Also be aware that in residential situations, higher set temperatures may cause you to use less hot water as you mix your cold and hot supply to comfortable temperatures. If your set temperature is above 120°F, try lowering the set temperature of the water heater to ensure that you are meeting the minimum flow requirement of the water heater while tempering.-----------------The gas pressure is not regulated.The error code 12 is related to gas pressure regulator. You have to check the gas at the regulator thats on the fixture. (you do have a regulator on the heater?) The set point should be marked on the regulator body. You have to leave all the other gas fixtures on or you might get a false reading.install a Pressure Regulator in the line to the Hot Water heater just below the unit.And then check.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
  • raj somaiya
    raj somaiya Sep 18, 2010
    Please keep updated with the results.
    Thanks.
Have been running extremely hard water thru our Noritz NR98-DVC for a couple of years. Unit is not functioning properly. What, if any, damage could result from using this hard water? Could there be
Replace single-handled faucet cartridge, and see if hot flows to that faucet again.
http://waterheatertimer.org/Crossover.html
Exposing tankless to hard water causes reduced efficiency within a few months, and can cause Total failure of parts within two years.
Do not expose tankless to more than 11 grains hard water.
Here is research pdf conducted by water softener industry comparing tankless andf tank-type:
http://waterheatertimer.org/pdf/Battelle_Final_Report.pdf
To possibly solve problem temporarily, install softening system, delime tankless unit using white vinegar. Delime yearly. It is fun for whole family. And who doesn't like a project schedule.
http://waterheatertimer.org/pdf/Rheem-De-lime-tankless.pdf
To solve problem long-long term, install tank-type gas water heater from local box store for $350.
Oct 12, 2012 | Noritz NR98-DVC-NG Natural Gas Indoor...
I have a nortiz 063-s tankless, and it won't stay on...I'm thinking it's the computer, please help
There are several things I would look for:
-Flashing burner light (indicates an error code)
-Trying flowing more hot water. In the summer alot of times you'll flow less hot water because your cold water is warmer. If you flow additional hot water at your shower, it will ensure the unit stays firing
-If the unit doesn't fire at all, you may have debris in your cold water filter or a stuck flow sensor. Call tech support to help you with cleaning a flow sensor.
May 29, 2010 | Noritz 6.3 Gallon Residential Tankless...
Noritz remote controller "RC-7646m-1" seems to need to be restarted several times throughout the day. Usually what happens is out of nowhere, it'll just lose it's temperature reading (at usually 140), and...
You are actually getting a 90 error code. This error code occurs if the unit is dirty and overheating. I'd recommend contacting a servicer to clean your heater with compressed air. They'll need to remove the fan motor and manifold plate to fully clean the burner chamber and heat exchanger.
Jan 21, 2010 | Noritz 6.3 Gallon Residential Tankless...
First it takes over two minutes to get hot water 30 feet away. Then when it's finally hot and adjusted to a comfortable setting in the shower, it only lasts maybe 3 minutes. And in the same room, the...
If the unit is functioning properly, then you need to contact your utility company to see about upgrading the size of the gas line and meter to your house, and possibly the lines IN th house. It may be cheaper to go back to a tank type water heater despite the potential energy savings with a tankless.
Oct 09, 2009 | Noritz 6.9 Gallon Residential Tankless...
Leaking Noritz water heater.... I have a Noritz N-069m water heater. When i purchased the unit 3 years ago, i was told that if i installed a water softner unit it would void the warranty. A year and a half...
Check your water pressure and the diagnostic codes on the controller to see if there is computer failure or another problem with the unit. send me an e mail i might be able to help im a nortiz certified service tech scott@bridgeplumbing.net
Jul 27, 2009 | Noritz 6.9 Gallon Residential Direct Vent...
Noritz tankless water heater/dishwasher not hot enough to clean
You are doing everything you can. Your dishwasher probably isn't drawing enough hot water to activate the unit so opening the faucet and flowing more water will activate the unit. Just try to adjust the flow from the faucet to a point it, plus the draw from the dishwasher, will activate the unit. This will come with trial and error as I am sure you have already experienced. Also, open the dishwasher when it does get filled and check the water temperature. You might have the unit set at a low discharge temperature. Do you have a touchpad to control the water temperature adjustment?
Feb 17, 2009 | Noritz 7.1 Gpm Natural Ng Gas Tankless Hot...
Noritz tankless water heater not producing hot water
I called Noritz error code 16 is a overheat problem. Noritz say's to flush your coil with vinegar or CLR.
Use a small pump to recirculate the CLR or vinegar through the system for 45 minutes and flush with fresh water. This worked for me.
Jan 04, 2009 | Noritz 6.9 Gallon Residential Direct Vent...
Heating & Cooling Logo
259 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
