Question about Acer Aspire 5315 Notebook
My acer 5315 won't open up in regular mode and I can't start the acer erecovery management i want to clean the laptop.
    President:
  • 2,291 Answers
Use registry cleaner reg in out and then try
Posted on Sep 20, 2010
Is there a reset button on the acer aspire 5315-2153 laptop?
Restore and recovery The restore and recovery features allow you to restore or recover the system from a factory default image, from a user created image, or from previously created CD and DVD backups. You can also reinstall applications and drivers for your Acer system. 1 Press + or select Acer eRecovery Management from the Empowering Technology toolbar to start Acer eRecovery Management. 2 Switch to the restore and recovery page by selecting the Restore button. 3 Select the backup point you would like to restore from. You can also choose to recover the system from a factory default image, recover from a previously created CD/DVD or reinstall applications and drivers. 4 Follow the instructions on screen to complete the process.
Nov 26, 2010 | Acer Aspire 5315-2153 Notebook
Factory reset my laptop
NOTE - you will lose all your data and any installed programs if you do a full factory reset. the process will restore your PC back to how your purchased it
This link will explain how to factory reset the PC using Supplied recovery CDs if you have them http://support.acer.com/acerpanam/desktop/0000/Acer/Veriton5100/Veriton5100faq19.shtml
This link will explain how to factory reset the PC using the ACER eRecovery if installed on your PC
http://support.acer.com/acerpanam/desktop/0000/Acer/AspireE360/AspireE360faq67.shtml
If you do have the eRecovery hidden partition installed:- How to recovery your system from bootup
  1. Locate the Alt key, to the left of the space bar, and F10, on the top row of keys.
  2. Power the system on.
  3. When the system is powered on, tap the Alt and F10 keys together at the same time when the Acer splash screen appears.
    It should state "Please wait a moment..." with the Acer logo in the upper left hand corner.
  4. At the eRecovery Management menu it will ask you how to restore.
  5. Click on the restore option you would like to use.
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Apr 03, 2010 | Acer Aspire 5315 Notebook
I need to restore my factory defaults to it
Look for "Acer eRecovery Management" in your start menu.
That will help .. Thanks
Oct 25, 2009 | Acer Aspire 5315 Notebook
Forgotten password on my Acer eRecovery Management
If you fully formatted the hard drive then most probably you have cleaned the PQservice division which might had recovery data; you can check this with the help of Computer Management console in Windows. It is in Windowssystem32compmgmt.msc. Also check the Disk Management and see what partitions you still have. Acer eRecovery Management won’t work if there is no default partition i.e. There should be E or D partition in order to run it.
Try www.download.com Here you might find your required software or else you have to ask the supplier to fix this problem for you. Hope this helps!
Sep 07, 2009 | Acer Aspire 5520-5908 Notebook
Erecovery acer 5315
You can "try" to stop the process from starting by unchecking the appropriate box under boot menu.
go to RUN, type MSCONFIG, check the startup tab.
Hope this helps.
Jun 15, 2009 | Acer Aspire 5315 Notebook
Acer 5315 laptop ''eRecovery'' issue
That is because the D drive was the recovery partition, you cannot make another, instead of giving the os disk to the consumer they put it on the Drive. Now that is gone.Call Tiger and ask them if they can help you. They will need to reinstall the operating system, unless you have another disk. You can try going into the cotrol panel and removing the Acer prprietary software that is causing the problem, but be careful what you take out, there are several programs like vista manager that we could have recommended to remove nd optomise your system, but I fear it's too late for that now,If you can get into safe mode on bootup, you may be able to restore the os.
Mar 20, 2009 | Acer Aspire 5100-3357 Notebook
Try going into the start menu, click run, and type in "msconfig" - without quotes. When that comes up, on the right hand side of the screen should be a tab labeled "Startup". Select that, and scroll through the list to see if the eRecovery is an option - you may be able to deselect it. Also check under the "Services" tab - it may be located there(If you check the box under the services list labeled "Hide Microsoft", it makes it much easier and safer to find/edit active startup services)
Feb 10, 2009 | Acer Aspire 5315 Notebook
My laptop wont go to desktop on startup.
Here is what you need to do
1. Power on the machine
2. At the white ACER BIOS screen, hold the “Alt” key and press the “F10” key simultaneously to start Acer eRecovery
3. Once eRecovery has loaded, you can cancel the process and now your laptop should boot normally or you can click “Restore to Factory Default Settings”
4. Click “OK” to continue .
5. From here, the eRecovery process will update all the data on the C: drive and restore a fully functional factory image (approximately 10 minutes).
6. Once eRecovery has run, press “OK” to reboot unit
Jan 19, 2009 | Acer Aspire 5315 Notebook
How do i restore my lasptop to the factory settings
To restore your acer to its factory installation status (formats C: and removes all data) press ALT and F10 repeatedly on first boot. This should take you to the acer restore program which is partioned onto the hard drive.
Alternatively use the acer e recovery program to create a set of boot disks which will allow the same operation.
Nov 25, 2008 | Acer Aspire 5315 Notebook
Acer Aspire 5315 Notebook Logo
49 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
