Question about Empire BF-10 Mid-Size Heater
Empire uf-30-1 can you use natural gas in unit buy just changing the burner orifice size
  • 455 Answers
NO! You have to change the pressure spring it the gas valve and the pilot orifice also.SET it @ 3.5WC.
Posted on Sep 16, 2010
Tip
Changing your gas appliance from natural gas to LP or vice versa.
You have an LP gas stove which you really like and would like to take to a new home but the new home has a natural gas hookup. Since natural gas is already available it would be convenient to be able to use it. Can you convert your unit over to work on natural gas?
Yes it is possible to convert any LP gas appliance to natural gas or from natural gas to LP. The only difference is the size of the orifice used in the burner.
LP gas is composed of a much larger molecule than natural gas and requires a larger orifice to output the same amount of gas as a natural gas unit at the same setting. Therefore if you used an LP stove on natural gas it would produce too much heat and burn rather intensely. If you used a natural gas stove on LP it would not have much flame at all. You can see the problem. The solution is also obvious. You need the correct orifice.
Changing the orifice is easy. It is located in the middle of the burner and unscrews out of the unit. Install the new one the opposite way. Do not overtighten it.Usually the burners are made of soft metal and can strip easily.
The parts you would need are available at most good appliance stores but I would recommend the following site http://www.repairclinic.com . The parts will be cheaper at repairclinic. They have parts for almost any brand and a great search engine. They also have excellent videos showing how to make the repair.
Thanks for using FixYa and for the great rating.
hardrocko
on Dec 10, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Conversion of Kenmore Elite Gas Range 790.7523 from Natural gas to propane.
each burner has a natural gas jet or (orifice) as you pull them out, one atb a time. You should be able to color coordinate them at that point. the jets will be at the end of each gas line right before the burner. and each burner gets one. I haven't seen the model you are referring to. but the ones i have changed out in the past, usually the hole is the same size for all the burners no matter the size of the burners. I hope this helps. good luck with it!
Jun 17, 2015 | Kenmore Kitchen Ranges
Convert lp natural gas
To convert a lincoln LP gas oven to a natural gas, you actually first of all need to buy from the supplier an orifice ment for natural gas and change. The difference in the orifices could be in the size of orifice aperture.
The orifice i'm talking about is located in the burner assembly. you got to dis assemble the burner so as to get to it.
After that you need to adjust the main gas manifold when the oven is on. The adjustment must be done such that the pilot flame is not yellowish
Jan 28, 2014 | Lincoln Ovens
I have a older 40,000 BTU 3 burner natural gas deep fryer. I would like to convert to propane gas. The orifice number is size 32. Do I need to get different orifices to convert? The serial number is...
Hi there.
Burner orifice size for propane gas is number 55. You have to replace all burner orifice with this size if you want to use the fryer with propane gas. Pilot burner orifice should be replaced with propane pilot orifice.The gas valve spring should also be replaced with propane spring kit. The difference between the two spring is the natural gas spring is lighter or thinner compare with the propane gas valve spring.
Regards.
Jul 13, 2011 | American Range AF40 Deep Fryer
I bought a Char Broil 2 burner model 463243911 with the natural gas conversion kit. This kit provide just one orifice, thus my question is: where I need change the orifice considered that this model has...
The conversion kit has one orifice for the side burner. The two maim burners are sized for natural gas once the LP orifices are removed. Joe
May 01, 2011 | Garden
Empire Mod#UH-1250-1FSP Ser # K49789WR Heater has been switched from LP gas to natural gas. I need proper orifice size to complete.
need to notify empire their specs for their natural gas should have the answer the kit or conversion unit should have had the part -it might not need to be changed--but if it does info needed is size of heater btu's size of line what kit/gas valve unit ur using
Jan 25, 2010 | Empire Heating & Cooling
Converting aan LP oven to gas
In most cases the pressure regulator has to be changed or adjusted. The orfices on each burner, oven, broiler and surface burner may need to be changed also. Sometimes they can be adjusted. Sometimes the threads on the pipe are different also. This is to prevent accidental connection to the wrong fuel. The big difference is the gas pressure. LP is usually around 10 - 12 lbs and natural gas is usually around 3 lbs. Properly adjusted you will like natural gas much better than LP as it is slightly hotter. The information will be in the instruction book and also on the Jenn air web site. Whirlpool owns both Maytag and Jenn aire so check all sites. The conversion kit is usually less than $50.
Apr 20, 2008 | Equipex PZ-330 Electric Single Oven
Empire BF-10 Mid-Size Heater Logo
176 people viewed this question
Top Empire Heating & Cooling Experts
paulcarew
rudyjoe
Level 1 Expert
Dan Webster
Dan Webster
Are you an Empire Heating and Cooling Expert? Answer questions, earn points and help others
